Question about Toshiba 52HM95 52" HDTV Projection Television
I have a hitachi 46f500 projection tv will not work on my new dital antenna
  • Toshiba Master
  • 3,446 Answers
Can you explain please. also check the aerial cable use a meter and check that the Arial is wired in right . as sometime it will be down to the Arial than the tv. even a thin peace of the coax cable may be touching the live in the Arial this will make you not get a signal. if the tv was fine before then i would say the arial wire is the fault.
Posted on Feb 26, 2014
Hitachi 46f500 46 in problem double picture end two collor
This is symptom of convergence output chips failure in rear projection tv, replacement of convergence output chips will fix the problem.
Chips/ IC replacement requires soldering work in circuit board, if you are not familiar with electronics stuff fixing an soldering work, call local tv repairman to help you.
Thanks.
Oct 26, 2010 | Hitachi 46F500 46" Rear Projection...
My Hitachi 46F500 TV will not adjust either manually or in magic focus mode......it has green lines across top of screen and some red tinting in the picture ......is this a gun issue or mirror in need of...
Replacing the lamp will do the job. It is the lamp that is faulty not the gun or the mirror.
It will cost just a few box to get a new lamp.
Take care and good luck
Oct 10, 2010 | Hitachi 46F500 46" Rear Projection...
I have a Hitachi 46F500 tv and the red crt bowed
I just had the convergence replaced and have a great picture
Aug 16, 2009 | Hitachi 46F500 46" Rear Projection...
No picture, no sound, blinking l.e.d.s
when rearprojection tv's don't power on and you get a blinking light. it means the bulb needs replaced. the cheapest place to get a new ulb should be ebay. good luck.
Feb 10, 2009 | Hitachi 46F500 46" Rear Projection...
My wife let the Wii remote and broke the front plexi-glass.
You can find a new Hitachi replacement protective screen and screen assembly for a model # 46F500 from a major Hitachi distributor at the following links:
Hitachi 46F500 Replacement Part Screen Assembly
Hitachi 46F500 Replacement Part Protective Screen / Ultra Shield
Feb 03, 2009 | Hitachi 46F500 46" Rear Projection...
Hitachi 46F500 will not recognize a Playstation 3
It is my understanding that the 46F500 HD Ready only goes to 1080i and for Blu Ray you need 1080p. There are no ports for this format.
Nov 17, 2008 | Hitachi 46F500 46" Rear Projection...
Hitachi 46F500
Having yellow and blue shadows outlines show up on picture.
Oct 03, 2008 | Hitachi 46F500 46" Rear Projection...
Hitachi HDTV Model 46F500
replace convergence amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2008 | Hitachi 46F500 46" Rear Projection...
Toshiba 52HM95 52" HDTV Projection Television Logo
16 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
