Question about Briggs AND Stratton Intek Briggs & Stratton Vertical Engine 21 HP INTEK OHV 1 x 3-5/32 331877-3036 331977-0001
Hard hitting on compression stroke when starting
Reg battery wont turn over after hitting compression stroke. put on charger and will start. New 410cca battery. Is there a compression relief valve? If so how to fix. I am old school mec and not up on newer stuff.
  • 3 Answers
If its the 21 or 20 hp OHV single briggs. Adjust vales to .004. The cam also has a decompression that breaks, Causing hard start. So if valves are adjusted and u still have problem. "Could" be cam, remove bottom cover and inspect cam. new cam about 75 to 100 bucks.
Posted on May 21, 2014
  • 2,239 Answers
Most Briggs deco vaves are internal and pretty reliable, the valve clearances are very important, if the exhaust valve clerance is too wide the valve lifter will not work, if there is no adjustment yoy would have to fit a new service valve and re do the clerance by removing material from the valve stem
Posted on Jan 05, 2014
Craftsman LT1000 riding mower hard to turn over
Make sure carb is not dumping gasoline into cylinder causing a hydraulic lock
Jul 29, 2014 | Craftsman Garden
18.5 hp lawn tractor will not turn over when on compression stroke . If you move it a little by hand past compression stroke it will start.
Sounds to me that you have a weak battery and is not putting out enough cranking amps..Takes more cranking amps during compression strokes to start than in down stroke...That is why you are able to start it in the down stroke less amps needed to turn motor over..
Jun 28, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Jd#la115 does not turn over past compression stroke
I'm guessing a "weak battery" is the problem. Sometimes a fresh new battery can make a piece of equipment run "like new"..... Also, you might make sure battery is high enough capacity... If all this does you no good, I'd guess you have a "tired" or worn out starter...
Nov 19, 2013 | Garden
Scooter has new battery, new spark plug, and catch new gas. Turns and turns but wont
IF it is a 2 stroke engine the problem will probably the 2 crankshaft seals are hard are no longer allowing crank pressure when the piston moves down hence you will not get a charge for the next compression stroke.
Mar 03, 2013 | Motorcycles
Hello i have a 14.5 hp murray riding mower well when u take the spark plugout the motor cranks over just fine but when u put the spark plug back the motor will only hurn a half turn can u plz help me
You might have interferance with the piston, is the spark plug is too long? If it is the same as original, then the flywheel key may be sheered and causing the spark to be out of time and firing before reaching full compression. \
Other than that, a weak battery or starter could be insufficient to overcome the compression and allow it to start.
To test this, put a jumper or charger on the battery, then by hand rotate the engine backwards until it gets to hard to turn by hand, this will be on the exhaust stroke. When you try to start from this position, there may be enough momentum to overcome a weak starting system. (Mine has the exact same problem)
junkl
Dec 15, 2012 | Murray Garden
Briggs 17hp intek overheadvalve on a john deere L100 has developed a hard start hard spin on compression stroke. new battery new starter
hi there
pauly46 here
if engine seems to labour when trying to start as if too much compression ?
try adjusting to in and ex valve clearance to 0.003" inlet and 0.005" ex
inlet valve is the bottom valve, and has a alloy push rod. ex valve is top valve and has steel push rod ( as viewed from the front of the machine with rocker cover off ) )
note rotate engine with plug out to tdc compression stroke , then rotate it down the bore on power stroke by 1/4 inch ( 6.35 mm ) this is the point for setting in / ex valve clearances
manual says 1/4 pst tdc on compression stroke - this eliminates decompressor lift from the setting
cheers hope it hepls
May 01, 2011 | Briggs & Stratton Garden
The starter turns the motor over very slowly, but motor will not start.
If the engine is turning over too slow, the engine will not start. Try either charging the battery first or attach a charger while starting. If it is still turning slow, the starter may be drawing too many amps and need to be replaced.
Feb 15, 2011 | Parks Optical 13.5hp Briggs And Stratton...
2003 crf 4 stroke. has compression. no leaks. engine sparking. fuel system fine, plug wet. engine wont start?
Gotta start with the simple things...
How do you know the compression is fine? Since you did not give a compression reading I do not know what method you used to test the compression.
How do you know the fuel system is fine? The plug is wet with what? Could it be water?
How do you know the spark is fine? Have you used a spark tester? Or did yuo use the spark plug on the side of the head? Did you know a bad spark plug can still spark under regular condition but wont spark under compression?
You left out valve timing- its a 4-stroke.
First put in a new plug. Then see if it hits on a prime ( see my tip on diagnosing a small engine).
If you have double checked all the basics and are sure we have fuel,compression, and ignition and it still wont start then check your flywheel key and valve timing.
Jan 02, 2010 | 2003 Honda CRF 450 R
How to find tdc on 95 ford escort 1.9
Using a compression tester in the cylinder all the way to the pass side, turn the engine over by hand until you see pressure rise. This gives you the start of the compression stroke. Remove the compression tester. (If you don't have one, put a finger the the spark plug hole and wait until you feel pressure. (Do not use the battery to turn it over, only do it by hand.) Once you are starting the compression stroke, put a thin but long screw driver or anything straight but easy to put in the spark plug hole.int that first cylinder.
Again, turning over by hand, turn it until the screw driver is at its highest point. You are at TDC.
Hope this helps
Oct 18, 2009 | 1995 Ford Escort
Briggs AND Stratton Intek Briggs & Stratton Vertical Engine 21 HP INTEK OHV 1 x 3-5/32 331877-3036 331977-0001 Logo
583 people viewed this question
Top Briggs AND Stratton Intek Garden Experts
Dennis Key
Dennis Key
wadingriver
wadingriver
jdthefixer
Are you a Briggs AND Stratton Intek Garden Expert? Answer questions, earn points and help others
