Question about Kenmore 43142 Front Load Washer
My front loading kenmore 43142 washing machine is very noisy and there is grease on the clothes. I need instructions to change the bearings please.
  • 2 more comments
  • robertowooll May 21, 2009
    These instructions do not go as far as changing the bearing, please advise.
    Robert
    The instructions I got did not go far enough - I need instructions to go a little further and replace the bearings.
    Please - do I have to pay for this advise, because it does not answer my question ?
    Robert.
  • robertowooll May 22, 2009
    Please can you answer my question as it was posted - Do I have to pay if you do not help me ?
    What does scorn mean ?
    Robert.
    Top Expert:
  • Kenmore Master
  • 75,814 Answers
This problem is always caused by the tumbler bearings being worn out, this is the noise and the grease, the grease is from the sealed bearings, when the bearing fails the grease goes out through the grease seal which is damaged by the worn bearings.
Go to this site for parts and further specific info on repairing your machine
http://www.repairclinic.com/0047_11.asp
Posted on May 22, 2009
    Sergeant:
    Champion:
  • 219 Answers
well my friend the bearings is replaced by accessing the bottom side of the washer, and is a not a simple repair.So i will advice u to take the help of a mechanic as u might not be able to repair it and more can damage it more.
Thanks!
Sandy
Posted on May 21, 2009
  • Sandeep Gupta May 21, 2009
    I'm sorry to inform you it's a bearing, the machine is ready to
    be replaced. Those usually take 2 people about 1 /12 to do. The bearing
    is not a separate item. You need to replace the back basket and then
    the drum assembly since that is the shaft that gets scorn. Usually this
    always happen to machines that people do not use HE soap in or use too
    much soap. This is way too common and usually cost about $600 in parts
    only. I wish there was a better way but un-less it's under warranty, we
    never usually fix them becuase it's chepaer for a new machine.
    Sorry
    for the bad news my friend
    Thanks!
    Brigadier General:
  • 3,917 Answers
Please refer to the link bellow which would give you a detailed procedure how to get the bearings replaced.
http://www.applianceblog.com/washers/Rear.pdf
and if you are looking for a pictoral instruction you can refer to the link bellow:
http://www.applianceblog.com/washers/RearBearingV6.pdf
Thank You
My kenmore he2t 8540911 drum will not spin.all of the time and leave the clothes wet.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 09, 2011 | Kenmore 43142 Front Load Washer
I have a Kenmore [2005]front load washer that vibrates severely when in high spin and is quite noisy. I have had the top panel, back panel, and bottom front kick panels off and I can not find any obvious...
you may need to change the bearing on the drum easy way to check is while the door is open try to manually spin it with your hand if you hear a grinding sound then the bearing is gone
Nov 05, 2010 | Kenmore 44102 Front Load Washer
Brown marks on clothes. I have put the machine on a boil wash with nothing in it. washed all pars of machine and it is still happing, Please help
Does the drum sound noisy when it spins if it does then I would suspect the bearings are badly worn and the grease from the bearing is getting inside the drum.
Hope this helps.
May 16, 2010 | Zanussi FJD1266W Front Load Washer
Works fine but very noisy during spin cycle. took back off and turned drum by hand. Bearing very rough. Took out bolt in center of the back of the drum . Cannot remove pully to get to bearing.
The pulley will come off. You will need to use a pry bar or wheel puuler to remove it. It take a some pressure to remove this, but it will come off.
Just work with it.
Jun 01, 2009 | Kenmore 43142 Front Load Washer
I AM REPLACING THE BASKET ASSEMBLY ON MY KENMORE FRONT LOAD WASHE
The shaft on the spin basket assembly is not lubricated. The shaft is inserted through the sealed bearings located in the rear outer tub shell. Placing any grease on the shaft would end up in your wash and damage your clothes.
Apr 03, 2009 | Kenmore 42822 Front Load Washer
Grease on clothes
Check to see if you have movement up and down on the inner tub like a bad bearing or loud roaring noise when turning by hand if so your bearing in the back of the unit has washed its grease out and the back of the outer tub will have to be replace the bearing in factory pressed in sorry that is a hard job and not a cheep one good luck
Mar 29, 2009 | Kenmore 43142 Front Load Washer
Kenmore Front Load "tumble action washer"
Our Sears repair guy says the tub bearing needs to be replaced. Get a new washer? Don't buy another Frigidaire...
Jun 20, 2008 | Kenmore 43142 Front Load Washer
Bearing noise
You have to remove the outer tub assy from the cabinet then split the halfs, We're told the the bearings are part of the rear tub housing. You might be able to press out the bearings
Feb 11, 2008 | Kenmore 43142 Front Load Washer
Stained clothes
there no grease in ft loading washer possible cause fabric softner
Feb 03, 2008 | Kenmore 44102 Front Load Washer
Front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Sep 18, 2007 | Kenmore 46462 Front Load Washer
Kenmore 43142 Front Load Washer Logo
73 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
