Question about HP PSC 1315 All-In-One InkJet Printer
Print cancelling I am using HP PSC 1315 Printer. Today I gave a print, but output has not come and it is not cancelling and deleting from spooling. please help me.
Try restarting the PC & Printer.When u restart it the former pages will be printed. Also,try updating the drivers. If these dont work,connect the psc to sum other machine to see whether ur own machine OS is not the culprit
Posted on May 22, 2009
Cannot delete a print job
restart the computer
while the computer shows the BIOS message, turn it off, wait 2 minutes. Turn on again
Apr 01, 2010 | HP PSC 1315 All-In-One InkJet Printer
My hp psc 1315 all in one. only scan and nor print
Hi
No problem I have just put one on my website for you
You can download a driver from my website then you can use the driver to set your printer up.
Just click on this link and it will download for you, and it is best to save it on your desktop so you can find it.
Click Link = XP http://www.4all2sell.com/driver/HP-PSC-1315-XP32Bit.exe
Click Link = Vista http://www.4all2sell.com/driver/HP-PSC-1315-Vista32Bit.exe
Ones you have downloaded just double click on it to run it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks All files on my website are only there for a limited
Feb 23, 2010 | HP PSC 1315 All-In-One InkJet Printer
I have HP 1200 psc I have a document that will not delete therefore I cannot print anything at all I have tried switching off everything - no luck - can you help?
From Printers and Faxes window
1. Right click the printer icon for your HP 1200 PSC then select "Set Printer Offline".
2. Right click again the printer icon then select "Cancel All" print jobs.
3. Once it's cleared, right click the printer icon again and then "Set Printer Online".
Or, restart the computer and the printer.
Oct 23, 2009 | HP PSC 1315 All-In-One InkJet Printer
Print job stuck in printer que
Try to power off your computer and printer and let it stay for 5 minutes. Then turn on your printer and computer to see if pending print jobs we're cancelled.
If the problem still there, you can kill the spool process running on your taskbar. Press control + alt +delete button to open the task bar and delete the process from the processes tab.
Aug 30, 2009 | HP PSC 1315 All-In-One InkJet Printer
I cancelled a print an hour ago and it is still deleting
turn off the printer
go to the computer and click on start>>control panel>>administrative tools>>services.
select print spool and right click to stop it.
now opne the printers and Faxes. open the printer properties and delete all of the print jobs.
go back to the service and restart the print spool, and turn on the printer.
Jun 07, 2009 | HP PSC 1410 All-In-One InkJet Printer
Will not print
FIrst delete the que. Make sure that the printer is the default printer under Printer/Faxes
This can found under the Start button or in control panel.
If it is default then use ctrl/alt/del to bring up the task manager and close off spooler.exe or spool.exe and reboot pc. Then try to print again.
May 20, 2009 | HP PSC 1315 All-In-One InkJet Printer
I have deleted my hp psc 1315 printer, my Compaq
go to hp's website and download the software for your printer it's really easy and doesn't cost anything.
Mar 01, 2009 | HP PSC 1315 All-In-One InkJet Printer
Printer will not cancel print job
Sounds like the printer spool is frozen.
Assuming you're using WinXP and logged in as an administrator (or with admin permissions)
START
Control Panel
Administrative Tools
Services
Locate the "Print Spooler"
Right click on this and choose "restart"
This will restart the print queue and will probably try to print the job again or delete it properly. If it tries to restart, just right click on the printer job and choose cancel again..
You may need to repeat but that should at least get you back up and running with other print jobs again.
Jan 25, 2009 | HP PSC 1410v All-in-One Printer
HP PSC 1315 Printer frozen in "deleting" mode
It seems a Problem with the Print spooler.
You can try a print spooler refresh>
Go To Start> Run> And type services.msc> Ok
In the services window locate for print spooler> And bouble click on the same> It will open the print spooler property window>
Now Bellow service status you should see the Stop Tab highlighted> Click on the same (you will see a small winow popped up and it will close)
Now you will see Start Tab Highlighted> Click on start ( And you will again see a small winow popped up and it will close)
Now stop should be highlighted.
You can try this steps a couple of times untill you see STOP highlighted.
Then click on Apply or Ok and close all the windows and try if it does any better..
IF NOT YOU CAN TRY THIS.
Go to printer and faxes and right click on the printer icon and left click on properties> Go to Advanced> And here you will see ckeck mark on: Spool print documents so program finishes printing later.
Now Select: Print Directly to te printer that will uncheck Spool print documents so program finishes printing later.
Now click on apply and ok and try printing.
If it is better than keep the same settings.
If not you may have to do a complete Print spooler cleanup.
Good Luck
Sep 28, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp 1310
plz switch off your printer and delete all the printer jobs pending.then restart your pc and start printing, if the problem is not solved then uninstall your printer and reinstall it.
Jul 02, 2008 | HP PSC 1315 All-in-One Printer...
HP PSC 1315 All-In-One InkJet Printer Logo
85 people viewed this question
Seeker5211
Seeker5211
