Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
Cylinder are not all firing on polaris 96 xlt triple
Hi i got a 1996 polaris xlt 600 triple and i put all new plugs in today and only two cylinders are firing sometime only one does i switched the plugs it has compressin and suggestion of what could be wrong thank you
  • bobalix Jan 02, 2014
    Hi lucas shepherd, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Does the engine have one carburetor or three?
  • 4 Answers
NOTE::theres a bolt to drain gas from bottem of each cylinder under exaust manifold drains fluid from crankcase if fluded
Posted on Jan 09, 2015
  • 3 Answers
Change coil the one not sparking
Posted on Jan 03, 2014
hotrodtod38
  • 141 Answers
SOURCE: polaris 500 xc backfiring through carbs, running on 1 cylinder
timing or cam
Posted on Feb 15, 2009
SOURCE: 96, polaris 600 xlt # 3 no fire
The problem was contaminated pump/fuel. Disassembled carbs and pump, inspected and cleaned, engine runs like new. Thank you
Posted on Feb 20, 2009
SOURCE: head light and tail dims when idleing and driving
Lighting coil is bad. Take off flywheel and replace the lighting coil. Should solve your problem.
Posted on Jan 05, 2010
  • 35 Answers
SOURCE: 1997 Polaris XLT Triple. Do I really need to pull
I have 1995 and a 1997 XLT. i have rebuilt the recoil on the 95 and all it takes is the few bolts to take off the cover and take the pipe off. if the 97 is any thing like my dads 94, you may have to pull the engine up a bit, the bottom left bolt cant fully be backed out with out hitting the side of the belly pan retainer, all it takes to pull the motor up is one nut in the back of the motor mount, and one bolt off the front, and it will tip up enough
Posted on Feb 17, 2010
  • 35 Answers
SOURCE: I have a 1996 polaris xlt with weak spark. I put
you just make a ground, and pull the engine over, if it is weak spark all the time, it is probably the coil, there isnt a meter, its just feel, if its running like ****, replace the coils and see what happens, this happend to me
Posted on Feb 19, 2010
Should all pistons be at the same position - 95 polaris xlt triple
by the same position do you mean top dead center , the answer to this is NO if all the cylinders (2-4) are at TDC then the pistons would have to fire all the same time , I doubt this be enough to rotate the crank shaft thru one revolution, this is the simple reason that they invented the simple 30* Vee engine (millions of em) as this is the perfect angle to produce a circular motion in a crank shaft
Feb 02, 2016 | Winter Sports
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Jan 04, 2016 | Cars & Trucks
Polaris_xlt coils and there wiring positions and were they all go
I will check ,im waiting on an xlt to arrive for repair this week or next.
Oct 27, 2011 | Polaris New Genuine Polaris Snowmobile...
I have a 1995 polaris 600 triple it fires but does not want to keep running seems like not getting gas it will fire on full choke off it wont even fire
CHECK THE COMPRESSION OF THE ENGINE, IF IT IS AT ABOUT 120PSI AND DOES NOT HAVE A DIFFERENCE BETWEEN CYLINDERS OF 15% THAN CHECK YOUR FUEL PUMP. YOU DO THIS BY REMOVING THE SPARK PLUGS AND FUEL LINES TO YOUR CARBS AND PULLING IT OVER. IF FUEL COMES OUT OF YOUR LINES THAN THE FUEL PUMP IS GOOD. THAN I WOULD CHECK YOUR CRANK SEALS FOR LEAKING
Dec 24, 2010 | Polaris New Genuine Polaris Snowmobile...
Horsepower output from a 95 polaris xlt 600 snowmachine
A 1995 Polaris XLT 600 snowmobile has a class-leading 120 hp.
Dec 23, 2009 | Polaris New Genuine Polaris Snowmobile...
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
589 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
toddgilbert
toddgilbert
Todd Arndt
Todd Arndt
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
