Blower wont turn off when heater kicks off
My heater kicks on fine but blower wont turn off and it only happens when the heater is on not the a/c the a/c kicks off when its supposed to not sure if its a sticking relay or what
  • 156 Answers
This could be normal. Modern furnaces run the blower for awhile after the flame goes out in order to gain efficiency by using up the latent heat in the exchanger.
Posted on Jan 24, 2014
On my 2007 buick rendezvous, my blower quit working
The blower motor is behind the glove box, sit in the passenger side seat and kick behind the glove box a few times real hard with your heat on high, the motor might kick back on, I had a Buick and the same thing happened
Dec 13, 2016 | 2007 Buick Rendezvous
Eb20b/ electric furnance/ blower wont shut-off after heat kicks out, got to kill breaker , runs all the time, installed new thermostat, no change?????? Its cold??????
Check the thermostat and make sure the fan switch is set on "Auto". If it is set on "ON" the blower will run constantly.
Jan 31, 2015 | Heating & Cooling
Heater wont start;don't hear blower motor
there are a variety of causes for this. any one of the safety systems may have detected a fault and thus wont let the heater run. if there is no electricity, the heater wont run. if there is insufficient water flow, the heater wont run.
Jun 02, 2014 | Hayward 100,000 BTU Pool Heater H100ID1 -...
I have a coleman 7956c856 direct vent forced air furnace it ignites fine but the blower wont kick on
main fan should come on once furnace has heated up to supply hot air to the house. make sure proper voltage going to the fan. fan relay in board may be shot
Jan 29, 2014 | Goodman GMS90703BXA Heater
Heater fan wont turn on
first check the fuse for the blower fan. if ok check if there is current going to the fan plug on top of the passenger kick panel or behind the glove compartment if there is current change the blower fan and the fan resistor next to it.
Jan 09, 2014 | 2004 Dodge Caravan
When i turn my heater on (blower) my car tries to stall out. What can cause that to happen?
most likely your ac compressor is locked up. see if you can disconnect ac compressor clutch at compressor. if problem goes away, you can use heater without any problems..
Dec 15, 2012 | 2004 Dodge Stratus
Heater wont turn on
So the blower doesn't turn on using any spped fan correct? This would most likely be the blower motor. Go under the dash on the passenger side and remove the kick panel and you should see the Blower housing. Remove the small bolts and verify nothing is in there or if it is seized.
Dec 06, 2012 | 1999 Buick LeSabre
Coleman evcon presidential heater won't kick blower on.
Sounds like the automatic fan control is not working it cuts in on temp rise . It may be dirty on the back of it as you said you had a smell of dust burn
Jun 17, 2017 | Coleman Heating & Cooling
Lochinvar DVN051 Water heater, I checked voltage on transformer, fine, checked pressure seitch, fine, blower runs fine, gas is on and stat clicks when I rotate it and kicks the blower os, I checked th
Copy following link for troubleshoot by type of gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Also: Scroll up on same page for Pressure Switch heading.
Lochivar is made by Bradford White I believe.
Same troubleshoot page has link to Bradford White service manuals, and service manuals posted by AO Smith, in case this product is through one of their subsidiaries.
Rheem does not make this product, good thing for you because Rheem doesn't post service manuals.
Sep 09, 2012 | Honeywell Water Heaters
Chicagao electric fireplace heater doesn't work
MY HEATER NOT WORKING,BLOWER AND LIGHT COME ON NO HEAT
Oct 25, 2008 | Heating & Cooling
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
