Question about Samsung ML-2510 Laser Printer
Light on. Exclamation mark within a triangle. Printing fine and clear. What does tis symbol mean?
A light is on my printer (Samsung ML-2150). It is an exclamation mark within a triangle. It is printing fine and the connections are good Is the toner low? What does this symbol mean?
    Problem Solver:
  • 11 Answers
This light is indeed designed to indicate a low toner condition. Its coming on is triggered not by the actual level of toner in the cartridge, but by a software process that estimates toner use. If you are inclined to refill your own cartridges, you can use install a glass fuse in the little clip on the back of the toner cartridge that will reset the counter, and turn out the light, otherwise the light will stay on. The reset process will blow the fuse, so a new fuse is needed each time a cartridge is refilled. Leaving the light lit does not hinder the operation of the printer, so as long as there is still sufficient toner to print, the printer will operate normally.
Posted on Aug 17, 2009
Appear duplex jam at display samsung ML-2150
Lubricate all gears and shafts inside the machine. There is an idle gear on the top back motor "where the paper comes out" the nylon it is made of shrinks causing the gear to seize on the shaft resulting in jamming. Super glue the fuser output rollers to their shaft. the rubbers on the output roller expand and slip when heated (usually after printing a large document) printing one page then resting/cooling down the problem doesnt occur. the idle roller on the duplex feeder also breaks off.
Jan 06, 2011 | Samsung ML-2150 Laser Printer
Green exclamation light on Samsung ml 2570
pls. go control panel check administrator tools check service cleck see printer spooling stop & start than check ur printer
Mar 16, 2010 | Samsung ML-2570 Laser Printer
Black streaks on paper ML 2150 laser printer
Black streaks usually mean that toner is baked on. Pull out the old cartridge, if it has a lot of toner, vacuumn it out (unplugged of course), and then replace it with a new cartridge.
Apr 28, 2009 | Samsung ML-2150 Laser Printer
Black streaks on paper on samsung ml 2150 laser printer
Could you describe these marks for us please.
Are they small specks or blotches? Bad Toner Cartridge
Are they lines:
Horizontal - Transfer Roller or Charge Roller
Vertical - Bad Toner OR Bad Fuser.
Note: A bad toner cartridge can render all of the parts listed here useless. Check for build up or lines on the cartridge reflective drum. Avoid light, as with film.
If they are a mix of both, the device needs to be cleaned with a can of compressed air. You must remove the cartridge, paper tray(s, and fuser to create clear path.
Apr 28, 2009 | Samsung ML-2510 Laser Printer
Flashing triangular light with the exclamation mark inside it.
Clear the printer queue on the computer (double-click the printer icon in the tray or in the Printers and Faxes folder and cancel all documents listed). Then power off the printer and disconnect the power - remove the paper from the paper tray until you have the printer memory cleared as to not waste paper.
Jan 22, 2009 | HP LaserJet 1320 Printer
I have a Samsung ML 2510 printer. It was printing just fine and then the red light below the triangle with the exclamation in it came on. When I send jobs to the printer nothing happens. I have checked...
Toner in your catridge might be over. Turn off printer. Click Start, settings, printers and faxes. Make sure it is your default printer and double click on it. Cancel all the pending jobs. When everything is deleted close the box and turn the printer on and continue your job.
Dec 17, 2008 | Computers & Internet
Error message w/Samsung ML 2150 Laser Printer - Engine LSU Error
Your Laser unit at the top section where the paper exit is faulty. You have no choice but to change it.
Nov 11, 2008 | Samsung ML-2150 Laser Printer
Samsung ML-2510 Laser Printer Logo
1,528 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
