Question about Ricoh Office Equipment & Supplies
Display screen says: door/covers open close covers of relay unit??
The display screen on my Ricoh Afcio super G3 copier says: door/covers open close covers of relay unit. I have opened and closed every door I could. Also I looked in the manual but there was no reference at all to the relay unit. Machine won't do anything. HELP!!!
  • 2 more comments
  • shannonpower May 26, 2009
    This is a Ricoh Aficio 350. Other than its reference to the relay cover there is no indicator as to where this open door/cover is located. Its exact message is as follows: doors/covers open....close covers of relay unit. no flashing icon.
    Thank you, I hope to hear back from you soon
  • shannonpower May 28, 2009
    I tried this.........no luck. There are buttons that are pushed when the covers are closed, but I am unclear on what you mean when you say that the cover may have come un-clipped? I don't see any thing that holds it closed.
    Just to be sure I am looking at the correct covers, they are located under the top area where the control panel and such are located? and they flip up to the left and right...........am I looking in the right place?
    I appreciate your help........please keep trying, I cannot afford to have someone come out to look at this.
    You were right the first time. It was the button that the door is supposed to hold down on the left side of the machine!! I think maybe when I tried it the first time I had the other cover open, so the massage did not go away. I also un-plugger and re-plugged in the connectors on the back of the machine.
    Thank you so so much for all your help. I didn't want to put a bunch of money in this machine, nor did I want to buy a new one. You are my hero!!
  • Anonymous May 11, 2010
    Please provide the model number, "super G3' is the faxing method the machine utilizes, not the model. The model number will be a 3-4 digit number. and also does it indicate with a flashing icon on the display (if applicable) as to the cover that is open, or any other info you can provide?
I believe the "relay Unit" on that machine is the section that transports copies to either the finisher (if installed) or the exit tray on the LEFT side of that machine. Sometimes neither of these units are present, but the relay unit may still be installed.
There are 2 flip up covers on that section (left and right), and you will probably see that one of them (usually the left one) has come unclipped, or perhaps the plastic clip that holds it closed is broken. If you flip up this unit. You will see a black button at the back end that is engaged when ther unit is closed. If you simply pree this button with your finger, hopefully the message will go away - this may at least help you troubleshoot what is causing the "cover open" message). Even if the clip is broken, it is often just a matter of seating the unit correctly so that the switch is engaged when the unit is closed. There is also the same switch on the right cover that could be causing the problem, but this cover doesn't sem to get damged as often.
I hope this helps. Please let me know.
Posted on May 26, 2009
  • Anonymous May 28, 2009
    Yes, you're looking in the right place. When I said "unclipped", I should have said "unhinged", But when you open them, it would be obvious if that was the case.
    There is also a third cover on the right side that allows the pages to exit in the middle of the machine. Is it closed tightly?
    You could also try re-seating the plug connectors of the unit.
    Turn main power (red switch) "off", then look into the middle of the machine where the relay section is located. toward the back of the machine, and on the right side, you will see a flat cover (kind of triangular in shape) that has a release tab (sometimes the cover is not installed and the connectors are visible). Remove this cover and unplug the 2 connectors, then re-connect, and power on machine.
    Note: It might be easier to do this from the back side of the machine.
    If this doesn't help, please let me know if you have either the upper, middle exit tray installed (above the "relay unit") and/or a finisher (sorter) on the exit end of the machine, or even an exit tray. In other words, do your copies normally come out the left side of the machine, or into the middle (on top of the "relay unit")?
  • Anonymous May 29, 2009
    anytime....happy to help :)
Used toner bottle is full
I'm going to assume you typed the model wrong, and that it is a 1035 like the header states. If this is the case, the used toner on these is inside the transfer belt unit.
Open the duplex unit if equipped, then open up the right-side door. Attached to the door is the transfer belt unit, as see below:
602d8058-7b67-4449-895f-e01b266fd371.jpgLift the lever as shown, then lift unit out of machine. There is a panel with 6 screws near the bottom of the unit, remove all 6 screws and remove the cover. Be very careful, this thing is going to be FULL of used toner, and will make one HUGE mess if not disposed of properly. Once emptied, put cover back on, re-install unit, close doors, and you should be good to go.
Jun 09, 2013 | Ricoh Aficio 1035 Copier
Can power on
Check the fuses.Blown fuse conditions
FU1 - 6,3A Doors/covers open is displayed.
FU2 - 6,3A Doors/covers open for the finisher is displayed.
FU3 - 4A paper end condition.
FU4 - 6,3A SC 121 is displayed.
FU5 - 6,3A one of SC302 or SC403 or SC405 is displayed.
FU101 - 15A no response.
Fu 102 - 8A no response.
FU103 - 1A normal operation,optional heaters do not work.
If FU or 102 is the problem,verify the main motor and the fusing unit heater lamps and thermofuses.After change the problematic fuse removal the fusing unit and turn ON the copier.
Apr 18, 2013 | Ricoh Aficio 450 Copier
My Ricoh aficio 450 copier shows a error that says: close door for relay. I have closed all the covers and doors and still get the same error message.
The relay door is the door on the lower right side, below the duplex unit. Check this door -- it may not be closed all the way, or the actuator (the piece of plastic that sticks off the door and is the part that blocks the sensor) may be broken. If neither of these is the case, the sensor may be bad.
Mar 30, 2011 | Ricoh Aficio 450 Copier
On my Ricoh aficio super G3 the toner wont load after replacing, the cartridge rotates but wont load
FYI "super G3" is the type of fax that is in your copier, not the Model of the Ricoh. Did you remove the steip after you put the toner in?
Aug 20, 2010 | Ricoh Office Equipment & Supplies
Describe how to remove a hard drive from Ricoh Afcio 2045
Remove the back cover, It should be located directly on the right of the machine. Just requires a phillips screw driver. REMOVE POWER FIRST .
Jul 26, 2010 | Ricoh Aficio 2015 Copier
I HAVE A PROBLEM WITH MY COPIER,NASHUATEC D435.
Enter in the service mode(SPmode),open the front cover and turn OFF the copier.Unpluged the machine,wait 10sec.amd pluged ON.Before clean the thermistors and thermofuses in the image fusing unit.Close the front door and turn ON the copiers.
Feb 08, 2010 | Ricoh Aficio 450 Copier
Door/covers open
dear sir; check it out on the side door left hand side (if you face door) have piece plastic door switch actuator isn't broken, change door !
Dec 26, 2008 | Ricoh Aficio 450 Copier
The copier is a Ricoh Afcio 350
SC 326: Laser synchronization detector board cannot receive the laser beam.
Replace the laser sync detector, Part No. A2935310.
Or try the following solution;
Open the front cover and remove the brown inner cover - 2 screws.
The black unit after the inner cover is the laser unit. There are 2 screws securing the laser unit - loosen them.
Tighten the right securing screw while jacking up the right side of the laser unit with a screwdriver.
Tighten the left securing screw and put the inner cover back on.
If SC 326 is still indicated after the above procedure, replace the laser sync detector or the whole laser unit.
Good luck and please rate me, thanks.
Apr 05, 2008 | Ricoh Aficio 450 Copier
Problem with Aficio 450 door cover sensors
I post a solution for this problem see: www.fixya.com/support/t2748127-false_door_open_reading_aficio_350
May 07, 2007 | Ricoh Aficio 450 Copier
617 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
