Question about XM Radio Car Audio & Video
Check antenna error with Hyundai Sonata 2013 - XM Radio Car Audio & Video
SOURCE: check engine light and how to diagnois and reset 1999 Hyundai Sonata
I had same problem and my repair shop just replaced a sensor in the tranny. Said it was a defect by Hyundai,but they won't recall it.
Posted on Oct 21, 2008
SOURCE: 2004 Hyundai Sonata Error Code P0171
Replaced Mass Air Sensor, but had to find someone to clear the error code P0171.
Posted on Mar 20, 2009
SOURCE: how do you reset the check engine light on hyundai sonata?
Just disconnect your battery for a couple of minutes.
Posted on Jul 20, 2009
  • 417 Answers
SOURCE: Hyundai Sonata 2006 - Check Engine light came on.
"Fuel system too lean at idle". It's an air/fuel ratio that is not correct, possibly a vacuum leak somewhere. Or a leaky exhaust pipe. Could be related to intake manifold gasket. Somewhere, air is getting into the engine.
I suggest taking it back to the dealer under warranty. I think Hyundai is 10yr./100k for the original owner. 5yr./50k if not. Ask first if covered, and ask why not id not covered.
Posted on Apr 10, 2010
MNfisherman
  • 11896 Answers
SOURCE: check engine warning light is on 2001 hyundai sonata
Purge Control Valve Problem
The "Purge Control Solenoid Valve" is the "Purge Control Valve".
Rough idle is a typical symptom of something amiss with the purge control portion of the evaporative emissions system. It could be the valve itself is not operating correctly, the evap canister (vapor canister) may be leaking, or full of raw gas instead of vapor, or maybe even the purge control valve is getting a faulty signal from the ECU.
The soleniod is checked by applying a voltage to it and checking to see if it closes, or opens (I'm not sure if its un-energized state is normally open, or normally closed). If the valve is bad it is a no-brainer to replace.
The vapor canister can be removed and checked to see if it is full of raw gas (not supposed to be), but checking it for leaks is a bit involved, and probably requires equipmet not normally owned by a home mechanic. Vapor canister failure on cars with a lot of miles is common. Replacement is the fix.
Of course if the ECU is not sending a purge signal to the valve correctly, figuring out why may proove difficult, and possibilities could even include a faulty ECU. I expect this is unlikely though.
It's a $20 part. I first would change pcv valve because it can give same error if it's plugged up. You can always remove it and shake it. It should rattle around real easy. If not, it should be repalced
Posted on Apr 17, 2010
Why won't it start?
Hyundai Sonata Questions - My Hyundai Sonata won't start ...
www.cargurus.com > Questions > Hyundai > Sonata
CarGurusMar 5, 2013 - My Hyundai Sonata won't start, everything comes on when the key is turned but no ... it is in park and until I jiggle the shift until the light does come on it will not start. Was in ... My 2009 Sonata has been "perfect" with no issues.
2009 Hyundai Sonata turns over but will not start ... - CarGurus
CarGurusJun 16, 2013 - 2009 Hyundai Sonata turns over but will not start, sometimes. - 70000 kms.
Car wont start? - Hyundai Forums : Hyundai Forum
www.hyundai-forums.com/nf-2006...sonata/139435-car-wont-start.html
Mar 14, 2012 - 10 posts - ‎4 authors
2009 Hyundai Sonata GLS 2.4L I4 AT - Slate Blue ... If you turn the ignition to on, not start, do you hear a humming coming from the rear? 2010 Not starting. Fuel Pump? Starter?
Apr 1, 2012
Car Won't Start - Break Pedal Hard !
Mar 4, 2011
2007 Sonata Won't Start
Jan 4, 2011
Car Cranks But Will Not Start
Jan 16, 2008
More results from www.hyundai-forums.com
Jan 01, 2016 | 2009 Hyundai Sonata
Timing belt noise? Coming from passenger side, checked tensioner and harmonic balancer. Any ideas?
Hi,sprey a little water if sound goes away then you should ajust belt or replace.
Mar 17, 2015 | 2004 Hyundai Sonata Antenna, 04
It's cold outside and my 2013 Hyundai sonata won't start
Its most likely a worn down battery. They get even weaker when its very cold outside. I'd get a jump or connect a charger to it.
Feb 20, 2015 | 2013 Hyundai Sonata GLS
How to reset the oil life light on 2013 Hyundai Sonata
o reset the 2013 Hyundai service interval, please follow these instructions to reset/setup:
1.Start the engine.
2. If a service is due the display will show "Service required".
To reset this message, press the SELECT/RESET button (left
pointing arrow) on the bottom right of the steering wheel for more
than 1 second.
3. The service interval will be reset to the default setting.
*The service interval feature has to be turned on and set by
the user by accessing the SERVICE INTERVAL menu. Press
the MODE button (rectangle icons) on the bottom right of the
steering wheel to highlight the SERVICE INTERVAL menu.
Press the SELECT/RESET button to access the menu and
use the DOWN arrow to turn the SERVICE mode on and
set the applicable interval.
4. Turn the ignition off and then start the engine to verify the
indicator has been reset.
- See more at: http://oilreset.com/2013-hyundai-santa-fe-service-interval-reset/#sthash.MniBNaqR.dpuf
Nov 30, 2014 | 2013 Hyundai Sonata Limited
Low tire pressure just came on (2013 Sonata SE) Hyundai service said take to Discount and make sure all tires @ 35 psi's and light should go off after 10 min's..no such luck
Are they trying to avoid warranty work? Go back and badger them into fixing it. Dealers can be notorious scammers. But that's just my opinion.
Oct 01, 2013 | 2013 Hyundai Sonata
Replace motorized antenna with a standard antenna on a 2004 Sonata
Antennas come with the cable
Remove the broken one first ,then
all your questions will be answered
Feb 08, 2013 | Hyundai Motor 2004 Sonata
Check Antenna comes on when I try to use the XM radio. It is a Sonata 2011
It means the system does not have any antenna signal. Check the antenna wiring.
Sep 10, 2012 | 2011 Hyundai Sonata
Car Audio & Video Logo
19 people viewed this question
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
Electro Med Services...
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
