Question about Zanussi 18 in. ZDT5052 Slim-Line Built-in Dishwasher
Stops mid-cycle, rinse&hold LED flashes
Hello, my Zanussi ZDT5052 stopped working just the moment I was preparing her cleaning (dishwasher cleaning solution). It drains water, takes fresh one in, rinses for a 10 seconds up to a minute and a half, and then stops. It buzzes quietly and just does nothing. And after another 10-15 minutes it stops completely, leaving RINSE&HOLD LED flashing - indicating that there supposedly is some water inlet problem. And it is filled with water up to the level of the heating element (which itself doesn't look damaged). I checked the aquastop inlet hose - leak indicator doesn't show any leakage in the hose (I wasn't able to unscrew the hose and check it's filter though, yet). I drained water using half of the RINSE&HOLD cycle. After removing spraying arm, both filters underneath it, pump covers and drain outlet covers, there is still water on the bottom of the water sump (up to half the diameter of drain outlet). I cleaned all syphons, transparent hoses under the sump don't look clogged. What should i check next? Is there some valve [b]locked, maybe? Help, please.
2 Suggested Answers
SOURCE: Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Posted on Jun 05, 2008
Zanussi tempoline not working, son twisted nob mid cycle it then stopped and wouldn't drain. Now not doing anything! Any ideas? I assume its a error code flashing up
The first step of a dishwasher is a drain / rinse drain. I would turn the dishwasher off at the socket, turn the nob to the off position only turn this in a clock wise direction IE: the direction the nob would naturally move. Turn on back at the wall and start as you would normally. The dishwasher will empty the water out in its first step then should cycle through as normal.
Feb 08, 2013 | Dishwashers
Clean button won't stop flashing and it won't start, got interrupted mid cycle.
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Feb 05, 2011 | Kenmore 24 in. 17039 Built-in Dishwasher
I have a Zanussi DX6453 dishwasher. Water will
Try tipping the dishwasher back to see if any water drains out from below if there is water present then the anti-flood device is energised and stopping water coming into the unit.If it works now after resetting then there is a leak under the machine that needs investigating.You can try going into the diagnostics to read the alarms.If you hold in the first and third button from the left on programmer,whilst holding in then press the on/off button then when the lights start racing release these 2 buttons.You should now be in the diagnostics,now press the first button once and count the flashes of the end of cycle LED.If this button is pressed 2 more times it will give the previous alarms.1 flash could indicate fault on inlet water and valve.2 flashes drain circuit blocked.3 flashes anti-flood device.8 flashes faulty circuit board.Make sure after reading alarms to switch off unit then on then off to reset.Then go back into the diagnostics as before to reset alarms but this time press button 2 from left all LEDS will flash after exit as before.
Hope this helps.
May 15, 2010 | Electrolux Dishwashers
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
My Zanussi dishwasher wont run a programme
Hello Paul, The first thing to try is to clean the filters at the rear pipe(s) that connect to the main water supply. It is quite common that when the water-flow is impeded, the programs may stop with flashing lights depending on the rate/amount of blockage.
So, pull out the unit and disconnect the rear pipe and give the in-line filters(s) a good going-over. Please let me know if this does the trick...
Best Regards,
Peter...
Aug 11, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
ZDT5052 flashes quickwash light
Tarvi...I don't know what the problem is...hard to diagnose these things. If the unit is working correctly, I suggest that you simply cut the power for a few minutes and then restart it. That may clear our a trouble code.
Dec 06, 2007 | Zanussi 18 in. ZDT5052 Slim-Line Built-in...
Zanussi zdt6252 stops on 'Rinse & Hold' midway thru Wash Cycle consistently...
The problem here is being caused by Blocked Filters in the Water suppoly In line/pipe. There are two(2) filters in this line, at the water connection point and at the Washer connect point(one at each end). If these filters become blocked, then the result will be a restricted water In-Flow and hence the Rinse & Hold Status. Disconnect the Water-Supply pipe and remove the plastic filters giving them a thorough cleaning before replacing them. All will be rectified by this action. Peter...
Jan 02, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi 18 in. ZDT5052 Slim-Line Built-in Dishwasher Logo
50 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
