Question about Samsung 46 in. LCD HDTV
Cuts off and on and makes terrible noise
It will often take the tv 15-45 minutes to come on..it sometimes comes on with a faint picture behind a lot of noise and makes a squealing sound but will finally start after some time of cutting off and on...it also seems that one of the HDMI inputs does not work most of the time and we have to switch locations for the input
    Problem Solver:
  • 13 Answers
Yeah, you most likely have the same TV I do. I changed the capacitors and it kind of helped.. I discovered the problem is with humidy and rainy days! Is your TV near a window? I ordered a screen power inverter but just moved the TV upstairs and away from excessive humidy and its been fine ever since. I might still put the inverter in eventually.
Posted on Jan 13, 2014
lukster
  • 217 Answers
SOURCE: HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Posted on Jul 20, 2008
SOURCE: no picture but has sound
your bulb has burnt out
Posted on Sep 09, 2008
SOURCE: HDMI Problem
check your owners manual tv. my tv has 3 hdmi input.your tv manual will tell you which one to use. make sure you select the correct resolution. 1080p/720/480 etc. oh...make sure you have hdmi cables too
Posted on Dec 08, 2008
  • 4090 Answers
SOURCE: Samsung ln t4665f : Power Light On , No Picture : Clicking Sound
there is a soloenoid type switch that fires the TV up this has failoed. its like a neon or fluoresecent tube that has a faulty starter switch light tries and tries but never quite makes it when it does get going it has that purple smear in the tube. that is the simple explanation for your problem. part is about $60 labor is unkinown as i am not in USA but looking at some of the rip off charges I am glad i dont have the bill
Posted on Aug 20, 2009
  • 4 Answers
SOURCE: Samsung LN-T4661F - When I turn the T.V. on, it
In this case, I believe it is the power supply board; more specifically the capacitors are failing. When you have the clicking problem and the long boot up times this has generally been the issue.
When you have video display problems such as shadows and lines that go away after warming up it is usually the LVDS cable and T CONN board going bad.
I had the shadow and line problem and replaced both the cable and board for $120 and that fixed my problem. Since I had the TV apart, I went ahead and replaced the capacitors so I wouldn't run into that later. You can find the parts numbers for the LNT4661F cable and board below. You can find links to you tube ( Part 1 & 2) to show how to replace the capacitors. Good luck.
Samsung A/S-T CON BOARD BN81-01312A
Samsung Lead Connector LVDS BN39-00883A
YouTube (Part 1) http://www.youtube.com/watch?v=Mm51C_RDIZE
YouTube (Part 2) http://www.youtube.com/watch?v=BNHHrgX_6cs
Posted on Dec 18, 2009
My Samsung DLP Tv turns off after about 3 minutes. What needs to be replaced?
i think it could be trip switch in the back of tv it should be a little blue button you can try put a bit of tape over the button it might work and if its that you can order a new one i put tape on mine and its still working
Feb 21, 2016 | Samsung HLS5086WX/XAA
TV clicking on and off with colored screens and noises, not power supply capacitors this time.
Sounds like a main board fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 20, 2014 | Samsung LN46A630 46 in. LCD HDTV
My Mits 62"initially has no picture and loud noise until warms up
all of these tvs had bad caps.. that is probably your issue, as they can cause lots of symptoms.
here is my tutorial on this
http://www.fixya.com/support/r5069371-mitsubishi_led_keeps_flashing_green
Let me know if I can be of further assistance.
Jun 13, 2010 | Mitsubishi WD-52525 52" Rear Projection...
The fridge is working fine but there are intermmitent noises from the motor? How do I trouble shoot this problem?
lot of them do it sometimes you can just shack it a little and it stops. there is nothing wrong . maybe the rubber on the compressor got moved a little. if oyu have moved the unit.
Sep 21, 2009 | Fisher and Paykel Active Smart E522B...
Tv cuts off and on no picture or sound
Most TV shut downs like this are HEAT related.Try increased cooling with a fan blowing into it to test this on yours.If it works leave the fan running or repair with a nice little but strong computer fan placed behind the unit..
Aug 17, 2009 | LG 32LG30 32 in. LCD HDTV
My tv is making a high pitched squealing noise...its killing ears
holy god i know i know i know i know it IS torture. My tv had the same problem and i had to live with it for over a year and a half... i have spent several months searching for answers of what causes this terrible sound, but the only answer i know if is a sledge hammer. sorry, but i had to give away my tv and purchase a new one.
May 31, 2009 | Sharp Televison & Video
Temporary losing picture
CHCK THE OPTIONS MENU SEE IF IT HAS A COLOR CONVERSION OPTION ,,TRY THAT,,ALLIGN THE COLORS
May 14, 2009 | Pioneer SD-582HD5 58" Rear Projection...
My Sharp Room Air conditioner (Mod.AF-S120FX-A) when it's starts
Most likely the terrible noise you hear is the compressor starting... Sometimes it is louder than when its runs continuous. Just make sure if the unit is shut off allow a few minutes for the freon to equalize before restarting the unit. Its possible that the Compressor is going out, But as long as it cools and the noise goes away after a minute or so, i wouldn't worry about it to much.
Apr 29, 2009 | Sharp AF-S120FX Air Conditioner
Loud screeching noise when it powers on
sounds like picture bulbs maby %30 i think it may need to go in for a check up they can pin point the problem hope ive been somewhat helpful thanks viper
Dec 31, 2008 | RCA Televison & Video
When initially turned on the picture jumps around for several minutes
"Fonzie-ing it" ? It's terrible that I understood what that meant. lol
Sounds like the tuner has a bad solder joint. You may need a Repairman.
Geno
Jan 24, 2008 | Toshiba 52HMX84 52" Rear Projection...
Samsung 46 in. LCD HDTV Logo
49 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
