Question about HP Office Equipment & Supplies
When I put a doc on the glass to copy -the print has a black vertical line down the page. When I print from computer to print - it works fine - there is no line of ink. Can I fix this myself? What would u reccomend
  • c_loth May 22, 2009
    My problem happens with I feed a document through the upper tray, not lay on the scanner glass. Gives me a black line down the center of the page when it prints the copy.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 166 Answers
A long black line on scanned images is usually caused by a piece of trash on the scanning mechanism.
Look at the scanning arm (the thing that moves when you scan something) and then see if it has any trash on it. If it looks good then you may have a mechanical malfunction in that part.
Let us know hat you find.
Posted on May 21, 2009
  • computerscot May 22, 2009
    You can probably fix this yourself then. Lift the scanner glass lid and look for a piece of trash on the little strip where the paper passes over the scanner head. What happens is this:
    When you scan from the scan glass the scanner head moves and scans the piece of paper. When you scan from the tray the scanner head stays still and the paper moves over the scan head. Why does this matter? If you have any trash laying above where the scan head "parks" while scanning from the tray then it shows up as a black streak because the scan head is not moving. So look under the lid. On my particular HP model it actually has instructions for cleaning this piece. What model HP do you have?
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
HP Officejet Pro 8600 vertical lines on all copies
I had the same problem; it happened with the first copy I tried to make directly from the printer's console - but only with the Black ink function - with the same original on the flatbed glass I then tried the Color function and it worked fine. But when I tried the Black copy function, the strong vertical lines appeared again - about 7, evenly spaced across the page and running the entire length of the page.
Nothing about cleaning any part made sense: the printer was brand new, out of the box, the color ink function worked fine to copy; so did making scan copies. It was only the black ink mode in the copy function with the original on the flatbed glass that produced the vertical lines.
What cleared it up was shutting it down, removing and re-inserting the power cord the other way, i.e., turning it around (which might have nothing to do with the outcome) and Voila! - no vertical lines with the black ink copy function - Go figure...
May 29, 2012 | HP OfficeJet Pro K8600 Printer
Hp cm2320nf prints 2 black lines vertical all the way down pg 1/2' apart
Remove cartridge observe on cartridge drum finds any vertical toner line? replace cartridge, as well as check all cartridges same manner...if found replace them..If its only on copying: clean flat bed both glasses..with glass cleaner..
Feb 02, 2012 | HP Laserjet CM2320nf All-In-One Color...
When I use the feeder either for scanning or copying, the page has a black vertical line . When I make normal copies or print outs it is fine, only the feeder makes the black line. Thank you
Under the Automatic Document Feeder is a small glass.
This glass becomes dirty, creating lines on the page.
open up the scanner cover and clean the glass
Feb 17, 2011 | HP Officejet 6500 Wireless All-in-One...
Copies are being printed with a line vertically down the side of the page. Only happens when copying using the hopper.
If it's a thin, sharp line, it's just a blob of ball-point pen ink on the scanner glass. Lift the lid, and you'll see the narrow strip of glass that the scanner uses when you feed a document through the feeder. Clean that with a rag dampened with window cleaner, or, better yet, alcohol. Even a dot of ink too small to see will show as a solid black line on anything you copy, scan, or fax via the doc. feeder.
Don't use so much cleaner that it runs under the glass.
Nov 10, 2010 | Brother MFC 7420 All-In-One Laser Printer
Black vertical lines on copies and scans from auto
This means the read area is dirty. Clean the glass with glass or lens cleaner at the area where you place the head of the paper if you wanted to lift the cover and scan a page without the autofeeder. There may be white out or toner stuck to the glass. This can be removed with a glass blade.
This answer assumes that prints from the computer are fine...
Apr 03, 2010 | HP Officejet 6500 Wireless All-in-One...
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
Vertical black line on side of copies only when using autofeed
Clean the small piece of glass on the flat bed. Should be on the left side of the flat bed when you lift the doc feeder.
Apr 11, 2009 | Canon Office Equipment & Supplies
PAPER PRINTING OUT WITH BLACK LINES AND MARKS
When coping I have a black line down the left side of the page. This only happens when I'm copying NOT when I'm printing off a document from Word or the Internet on my computer. How can I get rid of this black line?
Aug 14, 2008 | Office Equipment & Supplies
HP 3050 Black Line
I was getting a verticle black line and I had to clean the glass, the long white bar above the glass, and the white and black rollers before my problem was solved.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
330 people viewed this question
Seeker5211
Seeker5211
