Question about HP Office Equipment & Supplies
Hp 2430tn grinding noise
Grinding noise, not the fuser or gears associated
Soulvisitor
  • 1113 Answers
SOURCE: gear that drives the fuser unit
Yes one can replace it but it aint no easy job, entire frame needs to come apart, I always change the whole L frame, but gear is available, set aside half a day, take pics or purchase the service manual, it still takes me 40 mins to change a frame on one of these, and you will need to go that far then some to get to just the gear in frame..
7deadab.jpg Link to part number/price/purchase of fuser drive gear
Not such a easy job, you have been warned from one who knows OK
Good luck
Posted on Jan 09, 2008
Bubbabear64
  • 2794 Answers
SOURCE: "machine gun clicking" sound - fuser drive/motor gear area
Sometimes the clicking noise can come for the developer cartridge or the drum. you can carefully take them out and see if they turn freely.
Posted on Aug 12, 2008
mickspaceNET
  • 115 Answers
SOURCE: Lexmark C720 grinding noise & fuser damage
From the site of your Picture, you need a new fuser unit.
The coasting is peeling off... that is not good. And I will bet you get allot of paper jams.
To replace the fusing unit is not hard to do. For the most part taking the covers off the machine and getting them back on is the hard part... Let the fuser unit cool down before you touch it..
Just remember to unplug the machine, Electronic Static Discharge is not good for the Boards in it, touch the metal chassis before you touch the boards if you don’t have a wrist strap) get your self a table and some room to work and take your time.
Take the toner cartridges out
I would do a maintenance kit while I had it apart. (rollers, transfer rollers etc)
Vacuum it out; clean it while you have it open.
(Warning toner and developer is very fine, you might need a vacuum with a micro filter on it, other wise it might go every where)
The service Manual has details on how to do all this. If you follow that you should be ok.
You could try to get all the parts to Fix the fuser unit, but it is easier and faster, cheaper to replace the whole thing. Some places offer a core exchange.
If you need any assistance let me know...
This is from Lexmark
http://www.lexmark.com/lexmark/product/home/605/0,6970,204816596_846034106_306769501_en,00.html?tabId=1
These are various other places that offer parts and supplies.
http://www.innovone.com/~tsa/
http://www.all-laser.com
http://www.p2gcentral.com
http://www.precisionroller.com
Posted on Oct 27, 2008
SOURCE: HP P3005 making grinding noises
You need to change out the 3 lower gears and then you should be finem Part numbers " RU5-0955, RU5-0960, RU5-0962, " You can google those and your get what you want. that should take care of the grinding noise. I had the same issue.
Posted on Aug 03, 2009
  • 81 Answers
SOURCE: how to replace fuser drive assembly on HP laserjet
http://www.feedroller.com/Store/Service%20Manual/HP%20LaserJet%20P3005%20Parts,%20Service%20Manual.pdf
Hi, this is a link to the service manual for this printer. It may help you with replacing the part
Posted on Jan 01, 2010
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
Hp 4345 has error code 13.20.00 paper jam in tray 2 and also has a grinding noise by the fuser how can i fix it
The printer may need a "swing plate" replaced to solve the fuser noise. Remove the fuser and look at the black gear inside the printer on the left side. Do the teeth on that gear look worn ? If so that gear (swing plate) needs to be replaced. Its a hard job to do. Can you turn the fuser gears with it out of the machine without them skipping ? The tray 2 jam may just be worn rollers in tray 2 or a stuck sensor. Good luck !
Aug 06, 2013 | HP LaserJet M4345 MultiFunction Printer
Grinding noise
"Swing plate assembly" (RM1-0043-020CN) need to replace to avoid grinding noise. ..Note: Only professionals can perform this activity..
Jan 23, 2013 | HP LaserJet M4345 MultiFunction Printer
Hp laserjet 5200 grinding noise from left side
front, rear ? I'd say fuser assembly gears or drum on toner cartridge; check the gear teeth on the toner cartridge's drum.
Dec 20, 2012 | HP LaserJet 5200 Printer
I have a Hp LaserJet 2430tn and its telling me there's a jam in the back but when I open it i can't see a jam. does anyone know what could be wrong?
hi
if you have not replaced the maintenance kit (fuser + rollers) and the toners were replaced at least 2-3 times, its time for a fuser replacement
p/n you need is H3980-60001
Jan 16, 2012 | HP LaserJet 2430tn Printer
I have a HP Laserjet P3005dn and when it prints it is making a load grinding clicking noise. The paper comes out fine just the noise is the only problem.
The grinding on this model is caused by one of the gears that interfaces with the fuser wearing down. In the process it pushes the bushing on the fuser out of position. Replacing the fuser may resolve your issue, but you should really replace the fuser and the gear. When you take out the fuser you will see an assembly of 4 gears on the inside-left of the printer. The bottom-right gear is the one that needs to be replaced.
Feb 23, 2011 | Office Equipment & Supplies
Why is my hp laserjet 2430tn printer making noise when i print
This is a common problem with these printers after they do over 60,000 pages & up to 150,000 pages. It is caused by a bush wearing in the fuser assembly ( the heated area where the paper passes through and then exits out of the printer ). You will need a new fuser or if you are capable of repairing the fuser, purchase the bush from a parts supplier.
Feb 11, 2011 | HP LaserJet 2430 Printer
Hp laserjet 3005 making loud grinding sound when inialising
The problem is the fuser and gears associated it with it.
The mose common solution is to replace the fuser assembly as well as the 4 gears inside the unit where the fuser touches those gears.
This solution works about 85% of the time.
thanks adi
Jan 26, 2010 | HP LaserJet P3005n Printer
this is a problem that HP refuses to acknowledges. Its caused by the gear that meshes with the main fuser gear..it wanders to the right as the printer prints. we are checking into a fix for this, since we are getting no cooperation for the manufacturer, Canon or HP. Canon makes the print engine
Apr 01, 2009 | HP Hewlett Packard LaserJet P3005 Printer
24 people viewed this question
Seeker5211
Seeker5211
