Question about Ariston Technologies AWD120 13 lb. Washer / Dryer Combo
Margherita 2000 ab95 manual
What is a good setting for a normal wash?
5 Suggested Answers
  • 353 Answers
SOURCE: Need User Manual for Ariston Margherita 2000 AB 40
Temperature control or speed control for spin
Posted on Dec 15, 2009
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Posted on Jan 23, 2010
SOURCE: Problem : Water leaking out from under washing machine
NOTE. PLEASE UN-PLUG THE UNIT FROM THE ELECTRICITY SUPPLY BEFORE ATTEMPTING THE FOLLOWING JUST TO BE SAFE:-
Problem may be due to a blocked dispenser hole. Completely remove the dispenser unit and check for blockages in the hole where the water goes in. If you cant see anything immediate, take the top off. (Remove the 2 self tapping screws on the back holding the top on). Looking at the unit from the front. look inside where you took the top off and locate the rubber hose that connects the dispenser unit to the drum (it's a tight space, but if you look inside , front left you will see where the hose connects to the drum). Remove the hose and check for blockages. (The hose just pushes into the drum). Let me know. I had a similar problem and found that somebody had shoved a sock and pair of knickers down the water dispenser hole. This was also causing the machine to make a loud noise when spinning. Have you also checked the filter in the bottom right hand corner of the unit ? You have to remove the kick panel to get access to it.
Posted on Mar 01, 2010
rickead1
  • 1998 Answers
SOURCE: I have an Aristom Margherita
on most machines you can unscrew the lower panel and remove the lower panel and reach up along the right side (if your facing towards)and pull down on the pull cord that is attached to the door lock assembly this usuually frees the door and enables you to get to clothes stuck on the inside and you can usually fix this by removing the front door panel and replacing the door lock assembly message me back your model number and i may be able to find you a schematic or lead you in the cheapest direction in obtaining your part to your machine And please remember when our chat is concluded to rank how this opinion has helped in your appliance situation. I await your reply thanks again Rick
Posted on Dec 30, 2010
I can't stop the dryer from coming on Ariston AL128D, I just want to wash
Hi there, the F button on your washing machine (see manual http://www.gebruikershandleiding.com/Hotpoint-Ariston-al-128-d-margherita/preview-handleiding-431405.html?page=0004) is the clue. if pushed in it won't dry. don't know why, but by trial and error this seems to work
Sep 12, 2012 | Ariston Technologies AL128D Margherita...
I want circuit board for aristone margherita 2000 model ab95 and software and how can i install it
Sorry, this FixYa Washer Forum does not supply service centre numbers, engineers, spares, software, installation instructions or prices; it is just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
You will either have to search in your local telephone directories OR stay on line and search for '(make) washer service' for instance or '(make) washer spares' and hope that you can find someone reasonably local.
Sorry again ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 05, 2011 | Washing Machines
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Jan 20, 2010 | Ariston Technologies Washing Machines
Aristin Margherita 2000, motor is silent after I put the clothes
turn the wash temperature dial to zero,
if it starts to wash it could be a faulty thermostat,
if that wont wont work it could need new brushes in the motor
Mar 15, 2009 | Ariston Technologies Ariston AWD12 Front...
Our Ariston Margherita 2000 AB95 Sounds like a jet plane when spinning Is it worth fixing?
hello chels_z
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your Ariston Margherita 2000 AB95 Sounds like a jet plane when spinning
And asked me Is it worth fixing?
That depends how old the unit is?
Let me know what the results are.
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Sep 24, 2008 | Washing Machines
Programme Selector knob keeps turning. - Airston Margherita AB95
turn knob to solid dot then leave it for a little while to reset then turn it onto the desired cycle
Jun 02, 2008 | Washing Machines
Washing Machines Logo
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
