Question about Toys
Gyropter w6625 blades don't rotate quite fast enough to lift
3 Suggested Answers
richroth
  • 9472 Answers
SOURCE: Lower blade does not turn as fast as top blade and
Use the screwdriver that is supplied and removed the right side of the body. Check the gear on the motor shaft had slipped up the shaft and was not meshing with the bottom rotor gear. slide the motor gear down into postion, and install the right side of the body.
Posted on Dec 26, 2010
bayyagg
  • 1672 Answers
SOURCE: gyropter not lifting off after full charge
Mostly all the micro copters problem are the battery and the the pinion gear that's been worn out.
Check both of these part. Battery should at least gives out 350 mili amp. and the gear should touch the propeller shaft gear at the bottom of the copter.
Get a lithium ion battery for more power and longetivity.
Hope that helps!
Posted on Nov 22, 2011
My Gyropter will not ascend? Blades run at full speed
Sounds like the battery is not charged fully. Mine did that after I pulled it out of the box. Let it charge for a while longer.
Chaio!
Dec 09, 2012 | JCPenney Gyropter RC Helicopter
My S107G Metal Series will not take off just sits and spins how can i fix
If there are two blades that turn in opposite directions, perhaps the blades are reversed. If that is the case then they are pushing the helicopter down instead of up.
Sep 09, 2012 | SYMA Toys industrial New Syma S107 Mini...
Can someone tell me what might be wrong with my son's rc helicopter? It spins on the ground but does not lift off. It is a double horse volitation 9053.
it might be the controller that is broken. but it might be if he crashed it too much it could be broken. i had the same problem with my heli but i crashed it a couple times and now it does the same as yours hopefully im some help for u
Dec 09, 2011 | Toys
Gyropter not lifting off after full charge
Hope that helps!
Nov 20, 2011 | JCPenney Gyropter RC Helicopter
Toro 22inch recycler mower Cut the lawn fine last week (wet grass) This week very hard to pull the pull cord Too tight to pull fast enough to start engine Any ides?
hi there
have you checked and removed any built up grass/ mudd from the blade/ bell housing ?
does the blade turn freely after this ?
remove the pull start cover assy does the engine rotate freely ?
make sure the blade brake is not stuck on ( if these units use them )
if no check your oil level ?
if you have no oil reading on the dip stick you could quite possibly have siezed or partially siezed your engine
make sure you have not hydraulicd oil into the combustion chamber ( this raises compression )
to the point where it has too much compression and oil will not compress and causes a loc near tdc
take look and let me know
cheers pauly46
May 27, 2011 | Garden
My parents bought a Propel RC 3-Channel Remote Control Gyropter for christmas like a month ago at JC Penney. When I tried to make it fly I noticed that the lower helix was not rotating. So I have not been...
I solved this same problem by removing the canopy and realigning the helix shaft with the motor gear. The small screwdriver provided will work. Be careful of the front white LED light when pulling the canopy off.
Dec 27, 2010 | JCPenney Gyropter RC Helicopter
My gyropter will not shut off. The blades keep turning when the power is turned off.
definetly a short circuit some were in the copter itself
There pretty good about returning those items they can be a lot of fun good luck james
Dec 26, 2010 | JCPenney Gyropter RC Helicopter
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
