Question about Maxtor Hard Drive
Pc does not recognize slave drive
I have a maxtor basics 3200 external hd which stopped functioning. i removed it from its case and intalled it on the primary hd ribbon cable inside the pc. it appears to be spinning but it is not recognized. i checked the "disk management" section it is not showing up there either.
PS: I have many files on this drive and do not want to lose them...
FYI: i removed the jumper, i am running an HP a250n with Windows xp.
Any help would be greatly appreciated.
Jim
  • jgpalumbo May 21, 2009
    that did not work. i did not see the slave as being recognized. next steps?
    OK. my problem is that i am not sure what the proper jumper location would be to use it as a slave. i saw a jpeg diagram on the web but this model was not listed. should i try to install the jumper across the top 2 pins horizontially?
  • 13,433 Answers
Look into the computer bios / setup and see if the drive is detected there.
to get into the bios or setup press the button indicated on the screen right when you turn the computer on, it can be either F1 F2, f10, del, space, esc depends. it should say on the screen.
Posted on May 21, 2009
  • Ekse May 21, 2009
    seems it worked perfectly thats exactly what we needed to find out, the computer is not detecting the drive at all, its either faulty, not working or the jumper is set wrong, make sure that the drive is set as salve or master, and if there is another drive in the same cable it must have the other settings, you can't have two masters on a cable other one has to be master and other has to be slave.
    adjust the settings untill its detected in the setup / bios if its not detected at all, its a goner.
  • Ekse May 21, 2009
    should read on the label of the drive, the jumper settings I mean. you can look for its settings online with its brand and model, etc.
I had the same issue with my Maxtor 3200. I called the company and went through all the steps the tech support told me... but if your computer doesn't recognize the drive, you cannot perform any steps to completion. None of my 3 computers that had MS SP3 would recognize the external hard drive. I read the suggestions on this and many other sites that it could be the a/c adaptor and thought no way.
I took the a/c adaptor to a company that checked the voltage and that was the issue. The a/c power adapter did not have a steady stream of electricity, which made the computer not recognize the external hard drive.
I spent $40 on a new a/c adapter, plugged it in, plugged in my USB and it worked. All my computers now recognize it. I am so glad I saw this message board! It had ALL my videos of my 6 year old since birth!
I am going to transfer all my video files to another hard drive, not a Seagate or Maxtor. Email Seagate/Maxtor and tell them they need to inform their customers that it might be the a/c adaptor instead of saying it is corrupt and "sorry"!
Thanks to all that responded with this solution. To bad the manufacturer will not inform their customers that it could be an issue with the adaptor and send them a new one!!
Posted on May 22, 2009
I have Windows XP with service pack 3. My system no longer recognizes the Maxtor 3200 external hard drive. Do I need to get an updated driver to the hard drive? When I first connected the Maxtor HD. ...
When you plug in via USB, does the USB recognize it and not display as HDD? If that is the case, then it's probably disabled somehow. Access Computer management, and check from there.
If that doesn't work, try on a different computer. If it doesn't work, your HDD has gone faulty. And if you recently changed your board, make sure you have a high speed USB port.
May 24, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Basics 320 GB external harddrive cant be recognized
There's a good chance the shop you bought the drive from didn't have SP3 installed. For some reason, SP3 has an issue with USB peripheral devices. Windows has created a patch to rectify the problem. Click on the link below and install the "Fixit" patch to enable your PC to recognize your HD. Best of luck.
Greg
http://support.microsoft.com/kb/925196#fixit4me
Jun 18, 2009 | Maxtor Basics Personal Storage 3200 Hard...
No power in my Maxtor 3200 external HD
Maxtor hard drives have sometimes have problems. When you say it didn't work, can you here the drive spinning? Do you feel a G effect if up pick up the drive? Are any lights on? If all these are no then the unit is dead. Now all may not be lost. This drive may be able to be slaved to another and then accessed to remove your data. Do you have the capability of removing the drive from the case and slaving it to another CPU? If not then the unit needs to see a reputable repair person.
Apr 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Fried my maxtor 3200 external hd
The drive will have to be slaved to another drive in another machine.
Apr 09, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
How can I open the Maxtor Basics 500GB case??
See this link:
http://www.computer-aid.com.au/blog/2009/02/17/how-to-take-apart-a-maxtor-basics-external-35-usb-drive/
Mar 28, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor external hard drive stopped working
How is it connected ? USB?
If you start w/o Maxtor connection is your PC starting correctly?
Is issue showing when you connect USB cable on working PC?
Jan 04, 2009 | Acer Extensa 4620 Notebook
Maxtor 3200 backup drive not recognized in my computer to access
http://forums.seagate.com/stx/board/message?board.id=PersonalStorage&message.id=510
Re: whishels
Options Options
eltigre
New Visitor
eltigre
Message 23 of 61
Viewed 3,676 times
My Maxtor 3200 died also. I took the following steps to get it running again.
(1) Remove plastic box from around unit. Carefully stick a screwdrive in the case division and pry it apart. It is not easy, but do will finally come apart.
(2) inside you will find a perforated metal box. There are two screw on each side of the box. Remove and separate the two halves.
(3) there you will discover that inside is just an ordinary Maxtor hard drive like you would buy in the electronics store. Attached to the HD is a PC board. There are 3 screws holding the PC board down. Remove the screws and carefully remove the HD and PC board.
(4) unplug the powere plug and the IDE interface from the HD. Now you have a HD that you can install in your own case (as long as you have a desktop unit and not a laptop).
(5) I installed the HD in an empty slot, connected the IDE cable that was already there (between the CD and IDE interface), plugged in the power plug, fired 'er up, and voila, works like a champ.
I suspect that the problem is in the interface (PC board), since the only thing I did was remove that from the equation. Hope this helps
Kudos! Thanks!
09-09-2008 09:36 AM
Dec 31, 2008 | Maxtor BASICS Personal Storage 3200...
Maxtor 3200 200GB
The HDD has either failed or requires initializing.
May 30, 2017 | Maxtor Personal Storage 3200 (U01E200) 200...
My pc dose not come up my maxtor basics external desktop hard drive
What OS are you using? Windows 98SE does not always recognize exterrnal hard drives. Try the external HD on a computer running Windows XP and see if that works. If it works on WinXP and not Win98SE or possibly WinME the External HD is good.
May 06, 2008 | Maxtor Hard Drive
New Maxtor 3200
Hi, This is a common problem with external storage. Based on your post/description: 1. Your laptop does not recognize the external hard drive via its USB connection - try on a different computer - if it is still a no go, then it's not a PC problem; 2. Try replacing the cable - again if a no go, so it's not an interface/cable problem; 3. That leaves you only with the PS3200 itself as the possible at fault. An external hardrive would consist of 2 main parts, the electronic board and the hard disk itself. The board seldom (if ever) fails. Its function is to provide conversion/interface from the SATA/IDE connectors of the HD to the out USB/Firewire. The HD more often than not fails. Most external storage uses a standard HD inside the enclosure. Your possible options: a. Claim warranty/replacement; b. Replace the HD only; c. Physically remove the HD and connect it directly inside a desktop either as IDE or SATA and run manufacturer's diagnostic and/or third party recovery software; d. Seek services of professional data recovery firms (if data/files are mission critical); Hope this be of some help/idea. Post back should you need further information. Good luck and kind regards.
Sep 02, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Hard Drive Logo
233 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
