Hi I have a ferroli DOMIcondens F 28 boiler it was fitted 3 years ago and keeps changing between A02 fault and A01 is it worth getting this looked at or just cut my losses and get a new boiler any hel
It is also dripping water
SOURCE: Is Ferroli Optima 701 a condensing boiler?
fraid not its pre condensing and my advice would be to chuck it in the sea
Posted on Jan 08, 2009
  • 13 Answers
SOURCE: hi,i have a vaillant turbomax
Which turbomax, as there a two different models. The more modern one, with the brass CPL diverter valve, located at the front left of the boiler, was very prone sticking & jamming, this would restrict flow through the hot water circuit in the boiler, and cause cycling. Vaillant actually modified the diverter. You can identify, if it is the old type, as there is a very small hole in the middle of the diverter on the old ones, probable no more than 1mm-2mm wide. The modfied one, is much bigger approx 5mm wide. If old type, replace as this usally sorts the problem
Posted on Mar 03, 2009
  • 9 Answers
SOURCE: fault code ( nocn ) on a ferroli boiler
if nocn is on the time clock then check the wiring to time clock and if all good then it is the time clock at fault and will need repleacing
Posted on May 04, 2010
hvac1960
  • 2133 Answers
SOURCE: Vokera 24/28 Europa Combi Boiler Water
Check sensor whether fix in proper place.
Posted on Dec 02, 2010
SOURCE: ferroli optimax he 31c. brand
it is either your pump is not running or blocked [ debris from installation ect ] or your diverter valve is stuck partially open allowing a little water to pass into the heating system [ usually first rads on system ] it runs for a short while and cuts out because your overheat stat is kicking in because of poor circulation [ it is only running around the primarys in the boiler where it quickly reaches the over heat limit ] temp tends to rise approx 1 deg per second a clear indication of circulation problems.
solution GET RID OF THE FERROLI
Posted on Jan 09, 2011
Ferroli boiler
You should have 12psi for boiler to operate properly. Sounds like first you have a leak in your sytem. Second sounds like pressure reducing valve is not working properly.
Dec 19, 2013 | Plumbing
How do I set the timer on my ferroli f28 boiler...no instructions with boiler
http://www.wickes.co.uk/content/ebiz/wickes/resources/images/pdf/DOMIcondens%20F28B%203540S920.pdf
Jan 06, 2011 | Heating & Cooling
Fault code f26 ferroli optimax 25c how to reset
There is a parameter on the pcb to change would take 30seconds to do. Never replace ur pcb for these faults. Hold down reset untill u see t5 press reset 1 more time it will then say p01 press the heating temp button until u see p02 press the hot water temp button until it changes to numberv2 and that will fix ur problem
Dec 25, 2010 | Heating & Cooling
Ferroli boiler 31 che will not light up when hot water switched on notice in windowe says no ca or no co
are you getting no ca or no co on the time clock? if so change the time clock
May 16, 2010 | Heating & Cooling
I have the A01 fault on my Ariston micro Genus HE 32 MFFI combi central heating boiler.. I've cleaned all the electrodes etc. it does spark correctly etc, and can't see it shorting out but fails to ignite...
image_bubbleanswer_02.gif image_bubbleanswer_03.gif image_bubbleanswer_04.gif the A01 fault code is nearly always down to the pcb, 99% of the time in fact, its a common fault, but not common enough for ariston to be responsible for boilers out of the warantee. you can normaly check this yourself, while the tap is running check if the electrodes are still sparking even after the gas had lit, this means the pcb is not detecting the flame and trying to relight. eventualy it will lock out with a A01 code, if u reset it might work for a short time but eventualy u will get to the stage where it will no longer resart.
if your handy you can replace the pcb yourself, there is someone selling them on ebay for £85 thats a steel, its half the trade price never mind retail
Mar 27, 2010 | Heating & Cooling
Ferroli boiler error code A3
boilers need a certain amount of water pressure to operate as specified--there may be a pressure regulator valve, allowing a certain amount of water to your boiler, and when water is drawn elsewhere, there may not be enough getting to the boiler---this is one possible solution, but there are easily 20 more, and that is where a trusted plumber is worth it's gold...very difficult to diagnose most plumbing problems without being onsite
Mar 03, 2010 | Water Heaters
Hi i get fault 28 on my vaillant boiler
F-28 is a common error for my vaillant. I have had this problem serviced at least 10 times (all under warranty). It is an ignition problem and can be connected to a number of things. I have had the starter electrodes cleaned only to later have them replaced(4 times). I just had the "panel" replaced yesterday (looks like a motherboard or electronics panel). This is the second time to have this replaced. All of these things can give you an F-28 error message. I have an atmotech pro and have had ongoing F-28 issues for two years. They are looking at venting/air issues as well to see if this is the problem. douglas
Dec 20, 2009 | KDS Valiant 6380iPTD-01 Notebook
Ferroli optimax 31c
Here is a link to the manual.It shows fault codes.
http://www.ferroli.co.uk/Product_Documentation/Domestic/Optimax_HE_31_C_Manual.pdf
Please rate this solution.
Jan 16, 2009 | Heating & Cooling
Ariston A01 fault combi boiler
its not definately the pcb. change the detection sensor first( £3.20p). if this doesnt fix a01 fault then change the main pcb(£145).
Oct 29, 2008 | Water Heaters
My parents have a Vaillant Ecotec 831 boiler. Has continually broken down ever since it was fitted nearly 2 years ago. The guy who fitted it keeps coming out and it works for a few days then packs in...
Get vaillant to look at it. It could be installation fault. Their advise is impartial and they can advise if boiler can be repaired.
devinder
Corgi engineer
Oct 14, 2008 | Heating & Cooling
Heating & Cooling Logo
107 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
