Question about HP 5510 4-in-one Printer
Board is Dead
I have a HP 5510. The problem is that when i showed it to Printer Repairer they said that its board is dead. is there any way to bring it in a working condition?
  • Anjum Nisar May 26, 2009
    no i bought in 2004-5,and its not in warranty. i want to know about is it board repairable or not.
    Guru:
  • HP Master
  • 829 Answers
Hi.
Speak to the dealer you have bought , if its under warranty get replaced.
Posted on May 24, 2009
Dead LPT1 port
You have checked everything. At from between 3 to 20 dollars though, I would just get another LPT card. You dont have to install anything in form of programs.
Mar 17, 2014 | IBM Computers & Internet
Looks like dead. when powering on, control panel shows "self test" and then nothing shows up on the panel and printer is dead.
Try to reset the memory on your HP Officejet. Do the following:
  • Turn off the power to the HP Officejet and unplug the power cord.
  • Hold down the "# + 9" button.
  • Reconnect the power cord and continue holding the button for another five seconds.
  • Turn the HP Officejet on, and the memory should be reset.
If this won't work, you can try to upgrade the firmware but you can only do this if the printer is still detected by the Computer. You can check control panel and see if the printer is listed as "online" or "ready".
If the above steps won't work. Your printer is deem defective and needs to be replaced. You can try calling HP support for more info. Here's their US number: 1-800-474-6836
Hope this helps.
Jul 07, 2011 | HP Officejet 5510 All-In-One Thermal...
We have purchase several desktop PCs for the offfice use.. theres r lot of common issues.. 1.most of the time system gets corrupted in a sense, system get restarted over and over again without prompting...
NO OS stated why skip that? XP,? SURE ITS CORRUPTED ALL ARE NOW. and will get works, dead now for 3 years at MS.
the coin cell battery is dead if time clock fails.
for sure the clock in BIOS screens !!!
the NIC chip, or the Ethernet chip can be on board
or an actual NIC, nic means network interface card.
SR2150NX (HP retired this for support)official.
10 years old at least.
some came with VISTA is it VISTA, be nice to say.
does have this old slow chip
Integrated 10/100 Base-T networking interface
on board, or has addin board, open case look?
see what board added,? like giglan card?
the HP site clearly shows this chip
Realtek RTL8100
the driver can be had at realtek
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=6&PFid=6&Level=5&Conn=4&DownTypeID=3&GetDown=false#1
I run a system PCI sniffer to get all chip true names,
no screw driver need no mag lens to read chip tops.
or here
http://driverpacks.net/driverpacks/windows/xp/x86/lan
27million drivers now, happy hunting.
3 ways to get them here. (HP, chip maker, or way3 seen here)
http://www.pcdied.com/Drivers.html
the first chip to get working with PC that runs
is what RTL8100, but you cant because its dead LAN.
so only at a PC connected to the web can you get it
and move it to dead pc. dead LAN.
(called sneaker net in the old days) sneaking PC to PC.
Aug 30, 2017 | HP Compaq Presario SR2150NX PC Desktop
My hp monitor is totally black it was working last night. i tried to unplug and replug it in and it came on for a few seconds then went black again
A lot of time people have the impression that the monitor is not working when in fact the computer is not booting its lighting up but nothing else so its stays on a black screen.
One way to know is by opening your speakers or plugging head phones, if you hear windows open or any windows sound the problem is the screen.
You can also unplug the screen from the pc and turn the screen on most of the time the screen while show a disconnected warning on the screen if that comes up the computer is defective.
Oct 29, 2010 | HP Computers & Internet
The laptop doesn't boot. Its dead. I tried connecting the charger, but it doesn't shows any signs of charging. It doesn't even show the laptop is charging.i.e no led is lit when charger is connected.Please...
Hi.
If it is completely dead check the voltage at power adapter DC contacts using a multimeter.
If there is voltage within 0.5 Volts from specifications, then try starting the laptop with no internal battery. A shorted battery may cause the laptop not starting.
If battery and adapter are OK, then the problem is the DC socket in the laptop motherboard. The laptop must be taken apart and the solder joints soldered back. This is a delicate job and must be done by an experienced repairer.
In some case the whole power circuit or the main board may be faulty. Testing is done reading Ohms at DC socket solder joints on main board (or power board, depending on model).
Regards.
Ginko.
Aug 09, 2010 | HP Compaq Presario V5204nr Notebook
The Copy, Fax and Scan buttons are flashing (all at once) and when I push one to select the function it says busy ? Its a Hp officejet 5510 all in one printer.
pritner is dead , you can try a reset by the steps below.
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
If it does not work then , you have to go for a new printer.
Apr 08, 2010 | HP Officejet 5510 All-In-One Thermal...
Monitor just quits,
you posted to a wrong place, to an empty stop, its not a response post at all. but....
old old VS19 , with CCFL inside, (oops)
the OSD is dead, proving the monitor is dead.
the CCFL laps are bad or the board is a bad.
not all boards (PCB) fail for caps, unless,made in the bad china cap era....
i buy my caps at Mouser ,x10 better quality btw.
there is more to this board than just a cap
photo is of early L1503.
best place to look is get a used board from Ebay.
HP does not sell this board now, its LEGACY.
nor do they sell or offer schematics (lacking that very hard to fix)
those 2 black rectangles below are the CCFL high voltage generators. ether can fail. and CCFL is dead.
use a flash light to the screen yet , while pushing the Menu key there
for the OSD display to show up???? if it does then the CCFL parts
are bad. dead backlight.
Aug 04, 2017 | HP vs19 19" LCD Monitor
L7780 has died. I unplugged the ethernet and the whole thing died
return under warranty....sounds like power supply or main board died.
Jan 28, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP printer 4700
The printer's memory probably catastrophically failed if it never makes it past power-on. Or the logic board is toast. So maybe call HP technical support and present them with the idea that the memory or main system board is dead. They will probably refer you to someone who will gladly take your money.
Another option, if the printer is still under warranty you could ship it back to HP and have them fix/replace it.
Sep 19, 2008 | HP LaserJet 4700 Printer
Officejet 7317xi witherror message Ox866a7a16 is dead.
Its time to retire this machine unless you can find an inexpensive replacement main board. We have used boards.
Inkworks
May 16, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP 5510 4-in-one Printer Logo
Seeker5211
Seeker5211
