Question about IEC Centra-MP4R Centrifuge, Table Top
Replacing brushes on thermo iec centrifuge - IEC Centra-MP4R Centrifuge, Table Top
I have a IEC Centra-MP4R Centrifuge. The door will not open when I press the open button after a completed run. Does anyone know how to fix this?
I know nothing about the device, but it reads like you forced the door into a wedged position and it's stuck there. I would gently pry at it to get it past the "wedge", then study the mechanism to see whether the actual latch is broken, or just out of position.
Please click the Comment link to respond.
Mar 21, 2018 | IEC Centra-MP4 Centrifuge, Table Top
Got a used machine, opened it up to troubleshoot, and the unit is missing the fuse, and the ceramic spacer to prevent shorts to the housing is loose. Which fuse does the machine take? The housing indicates...
so use one a little larger 20amp -30amp .
and use hot glue to help fix the spacer , you can fill the space with the glue too because it is an isolator also
Mar 20, 2015 | IEC CU-5000 Centrifuge
I have a Delta Model 23-660 that won't start anymore. For awhile, if I gave the wheel a spin by hand it it would start, but not not at all. I'm assuming brushes? If so, what brushes would it take? The...
  • there is also an
  • centrifugal circuit inside one- side of the motor electricfield (not in the spare parts to see or order) that could have a problem but first measure the capacitor
  • There are no brushes used its an induction motor. with start capacitor and an centrifugal switch. that was when you give a swing to the grinder the capacitor you needed has an 8 or 10 microfarrad 250 volt AC to start i think but be shure the start centrifugal is in good order and the capacitor together.
  • Delta 23 660 Type 1 Grinder Parts
Feb 27, 2015 | Delta Grinders
Why do my brake lights stay on when the car is off?
Bad swiitch or short in wiring. Your brake lights will work with the car off when you press the brake pedal.
Oct 18, 2014 | IEC BRAKE SWITCH ASSEMBLY Part for...
Hums andwill not drain and do final spin
Probability is you have a blocked pump. That humming noise you are hearing on the spin, is the pump motor polling as it cannot turn. The machine will not spin until the water is out. This is the safety function of the pressure switch. Centrifugal force would otherwise cause the water to be forced out of the machine from places like the dispenser draw and flood your laundry.
Regards
John
Jan 30, 2014 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Service manual
Try this... I've found a few sources online but most require membership in their particular user forums. This pdf is the operation manual, but it has a fairly comprehensive maintenance section that I believe may contain what you need.
https://www.artisantg.com/info/PDF__546865726D6F5F49454343656E747261475038525F4D616E75616C.pdf
Dec 03, 2013 | IEC Centra-GP8R Centrifuge, Table Top
To remove motor to renew brushes
Most washing machine motors have no brushes. They are induction motors. And they are made so cheaply that they are welded together hence they cannot have the bearings or many other parts worked on. They may have a centrifugal switch that can be rebuilt or replaced.
Nov 28, 2013 | Washing Machines
Brake switch location
were is the brake light switch on a 04 work hours chassis
Feb 15, 2013 | IEC BRAKE SWITCH ASSEMBLY Part for...
IEC Centra-MP4R Centrifuge, Table Top Logo
82 people viewed this question
Top IEC Science & Laboratory Experts
S J Parkin
S J Parkin
ray gallant
Tom Chichester
Are you an IEC Science and Laboratory Expert? Answer questions, earn points and help others
