Question about Sony Audio Players & Recorders
Fix speed and pitch problem sony ps-t15 turntable
Trying to adjust the pitch for an album and the turntable sped up and can't be slowed down
    Master:
  • 434 Answers
The pitch control need to be cleaned. You will have the remove the bottom to do this. It will require servicing. It could also be PCB board that that controls the pitch or a bad motor.
Posted on May 29, 2014
dunnbiker
  • 8546 Answers
SOURCE: Sony PS-LX250H turntable speed adjustment on underside, how??
Great detective work.
Let's collaborate on this for the benefit of others who may have the same problem.
L.IN should be the point at which the Lead-In groove on the LP would be, where the tonearm will drop to play an LP
RET should be the point at which the tonearm will lift up and RETurn to its rest at the end of the LP
That leaves us with SW. If your source is right this will affect the Speed. I can't imagine what the W stands for.
Since this turntable lacks the traditional strobe light and dots along the platter rim for determining if it's on target speed-wise we have to improvise and make a Strobe Disc.
It has radial marks on it and you place it on the turntable like a record. The lights in your room running at 60hz will make it appear to be stationary if the speed is correct; slowly creeping CW if too fast; CCW if too slow.
Here's a link to a PDF from which you can print your own disc... http://www.extremephono.com/ftp/60Hz.PDF
Here's what you do. Lay the trimmed Strobe Disc on top of a record while it's playing one of the outer tracks. This is because the stylus imparts some drag so we want to factor it in.
Then adjust the screw exactly one turn Clockwise and note how the speed has changed. Trial and error should get you to where you want to be.
Posted on Apr 05, 2009
smjdragonfly
  • 79 Answers
SOURCE: how do I adjust speed of Sony turntable model PS
Try a skinny flat screwdriver, like one you fix glasses with. Lemme know. Please rate me
Posted on Jun 18, 2009
lesliemurphy
  • 69 Answers
SOURCE: my pioneer PL990 turntable, the pitch wavers.
try cleaning the inner ring on the underside of the actual turntable platter and also the motor spindle using isoprynol alcohol or use neat clear spirits like bacardi/vodka with cotton wool etc. if black residue comes off either the platter or the motor spindle that will be residue from the old belt that could cause the fluctuation in speed? good luck.
Posted on Oct 04, 2009
  • 5 Answers
SOURCE: sound wavers (speeds up and slows down)
you need to replace the Pitch controls. I'm presuming it is a sliding pitch control. Use the Red start stop lights that reflect on the rotating wheel. put the pitch in center 0. does one row of the dots on the wheel stay completely still.now just turn it up op down a bit until it starts to move the dots slightly. now watch the dots now while there moving. Do they fluctuate they should be smoothe. do this on both decks to find out which one is fluctuating.
Posted on Nov 07, 2009
SOURCE: turntable will not hold pitch,speeds up or slows down.
they arte direct drive though so smirf617 how will that help ?
Posted on Aug 05, 2010
Adjust pitch not working on PS T1 Sony
Try looking underneath the turntable. There might be two speed presets one for 45 and one for 33. They could be covered up by stickers.
Jun 04, 2014 | Sony Audio Players & Recorders
Sony Turntable PS-T33 stops turning
first check if its loosing elasticity in the belt or coming over, you want the belt to be in good condition and not worn out. after checking that you also want to check the mechanisms that drive that and check voltage on psu
Mar 01, 2013 | Sony Audio Players & Recorders
My records that are 33 and 1/3 don't play at that speed on my turntable. they sound more like a 30 speed, what do I do
Hello Rosie,
Some turntables have a pitch adjustment feature which allows you to speed up or slow down your records. The adjustment controller is usually a slider or a wheel somewhere on the turntable and is usually labelled "Pitch" "Adjust / Adj" or "Pitch Adj".
Please check for this feature on your turntable then get back to me if you are unable to find it. Please include the brand and model number of your turntable.
Hope this helps.
Regards,
BElectric
Aug 17, 2011 | Audio Players & Recorders
I have a Sony PS-LX210, and need to adjust the speed. Going by the music it's played, it's just a bit slow on 33 RPM (I don't know about 45). I find no external adjustments, but there are some trim pots...
According to anything I can find online, like any decent turntable it has a manual pitch control. Unfortunately, I can't find a manual or even a good close-up picture.
This is the best one I've found.
http://www.neowin.net/forum/topic/652451-post-your-vintage-tech/
What's that rectangular slider-looking thing at the front right edge?
Feb 10, 2011 | Sony PS-LX250H Turntable
I have a Sherwood PD - 913 R and the pitch seems to be spinning out of sync which makes the RPM"s not right for 33 or 45 speeds, any help on what could be the cause is appreciated. There is a pitch...
The turntable motor might be the problem, if the grease is old it becomes hard causing the turntable to run slow, by your description we can rule that out since you indicate it runs to fast. therefore it is the voltage that powers the motor with a regulator "keeps voltage constant" or the motor itself will be the problem. The pitch control allows a small change in speed when required.
Dec 30, 2010 | Audio Players & Recorders
Sony PS-LX250H is running slow from time to time notibly when playing slower songs like John Denver 33 albums.
Replace belt of turntable to fix speed issue. Part number is as follows:
421549201... BELT
Available in Sony Part Store for $10.31
Download user manual copy from Sony Support as belt replacement procedure is written in manual.
Thanks.
May 17, 2010 | Sony PS-LX250 Turntable
Sony Belt Drive Turntable Platen speed
Check for grease on the platter or anywhere in the mechanism. Sometimes somebody has messed around with the speed preset, there might be two. You could try adjusting them. Sometimes they are found on the underside of the turntable, covered up, or they will be on the PC board of the deck.
Jan 08, 2010 | Sony PS-LX250H Turntable
Turntable will not hold pitch,speeds up or slows down.
try replacing the drive belt with brand new one and see if this improves the situation
May 27, 2009 | Philips gemini XL-500 II Turntable
Slow speed
What model do you have?
It could be a few things. It may be as simple as an adjustment to the pitch control (if your table has one), it could be the pitch control itself or something more serious.
Is it Belt-driven or Direct drive?
[J]
Nov 06, 2008 | Technics Audio Players & Recorders
208 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
