Question about Black and Decker USA Black & Decker SB1001B Single-Burner Portable Buffet Range
SB1001B dosent work
I cant turn it on when i plug it up the light dosent pop on there are no switches on appliance how do i turn it on
My light in the fridge went off so I bought a lightbulb the same amp and specifically for appliance and nothing would anyone know weekday it could be.
You didn't say what type of refrigerator.
It could be that the switch in the door frame is not working or is stuck.
May 02, 2015 | Refrigerators
My washer is just dead.
Check to see if the main panel circuit breaker is popped by switching it off and then back on again and there should be some resistance when switching it back on again. Next you would need to check the outlet by plugging something like a light that you know works into it and then check the washer plug and wire cord to see if there is a problem there and if no success there you will need some present who knows more about appliances and can check internally in the appliance.
Sep 08, 2014 | Maytag Neptune MAH7500WH Front Load Washer
My nikon D60 and the pop up flash dosent work
the flash pivot on the release side of the flash has a small cylinder that operates the flash up switch. If that cylinder is broken off or the pivot is pushed in so the switch doesn't close, then what you describe happens
pop up the flash and remove the two screws underneath, and you can pry off the cover - gently - to check the switch
Mar 16, 2013 | Nikon D60 Digital Camera
Red light is not turning on
I had the same problem. It came from a small mechanical malfunction in the switch inside the cooker.
To fix it I had to :
- unplug the cooker
- unscrew the 3 screws from the bottom
- open the mechanical switch (red and black plastic box inside the cooker)
- reassemble the switch (copper tabs and spring... this part needs some patiente and dexterity skills)
- close the cooker with the 3 screws
It seems to work again now. Sorry for my bad english... I hope my solution is still understandable.
May 03, 2011 | Cuisinart CRC-400 4-Cup Rice Cooker
My ps3 wont turn on help
try unplugging the power cord from the ps3 and putting it back on. if that doesnt work, your console might have kicked a breaker in your homes breaker box. on the ps3, always turn it off by the the back power switch.
Aug 22, 2009 | Sony Playstation 3 (PS3) Console
My Lyra Dosent Turn On
sir u need to recover ur dead digital player and how its work follow me!!
1/ try to download a flash tool from the main site of ur product
2/visit this and keep uuuuuuuuup
Aug 14, 2008 | RCA Lyra RD1072 MP3 Player
Light on dash board not working
On a Buick Rendezvous there is a very peculiar little switch that pops out of the headlight control knob, simply press th middle of that knob and another rather long skinny knob will pop out. To make the lights brighter turn that knob clockwise to dim turn counterclockwise.
Jun 17, 2008 | 2003 Buick Rendezvous
No power wont turn on
The Slight pop will be when the cors plug contacts the plug on the TV, and just a warning it is very dangerous to yourself and detrimental to any electrical appliance if you do this. when plugging in you should make sure everything is switched off before doing so and once all cords are connected you can then turn the power on. As to your problem I think you may have cooked your power supply inside your tv. You may need to have a technician look at it and diagnose for you. Hope this Helps.
Feb 13, 2008 | Televison & Video
Black and Decker USA Black & Decker SB1001B Single-Burner Portable Buffet Range Logo
63 people viewed this question
Top Black and Decker USA Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Black and Decker USA Kitchen Range Expert? Answer questions, earn points and help others
