Question about Audiovox MM50PKG2 Car Video Player
Where do i hookup the brown,violet and grey wire too on the audiovox MM50PKG2, Im installing the audiovox mm50pkg2 headrest monitors in my car
Don't know where to hookup the brown, violet and grey wire too
I have an urban audio works 7 band equalizer. i have a spx pro audio amplifier and an alpine cd reciever model cde987. the equalizer is not installed. could your please tell me where to wire in the blue,...
INPUT: Yellow (left front), violet (left neg), green (left rear), Blue (right rear), Brown (right neg), Gray (right front)
OUTPUT: Front Left pos (green/red) neg (green), Front Right pos (gray/red) neg (gray), Left Rear neg (brown) pos (brown/red), Right Rear neg (white) pos (white/red)
dfsanchez@yahoo.com
Mar 14, 2011 | Car Audio & Video
Need a radio wiring diagram for a 97 Nissan Altima i found one on line but it wasnt nothing like the colors of the wires in my car.
red = 12v ignition/acc
yellow= 12v battery/memory
black = ground
blue = power antenna
blue/white = amp turn on
black/white = amp ground
orange = illumination
orange/white = dimmer (+)
orange/black = dimmer (-)
brown = mute phone
speakers---
grey = right front positive
grey/black = right front negative
white = left front positive
white/black = left front negative
violet = right rear positive
violet/black = right rear negative
green = left rear positive
green/black = left rear negative
Dec 30, 2010 | Car Audio & Video
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
NEED STEREO WIRE COLORS FOR 1988 BMW 735I
red = constant live 12v
brown = negative ground
violet = ignition live 12v
white = electric antenna (rear screen)
the speakers will be twisted pairs, i can not remember which is left and right but the grey stipe and brown strip are negative the others are positive.
If in doubt get a pro to install for you as you could cause damage if you connect wrongly.
Nov 25, 2009 | Car Audio & Video
I need wire color codes for a 2009 Ford ranger basic radio. Installing an aftermarket stereo.
I took my time to find this for u please show your thanks with a "FIXYA" rating.
2009 Ford Ranger Car Stereo Installation Guide
Car Radio Battery Constant 12v+ Wire: Violet/Red
Car Radio Accessory Switched 12v+ Wire: White/Red
Car Radio Ground Wire: Black/Yellow
Car Radio Illumination Wire: Blue/White
Car Stereo Dimmer Wire: Green/Red
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): White/Violet
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Orange
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Blue
Sep 30, 2009 | 2008 Ford Ranger 2WD
Wiring diagram for a Clarion CZ109
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Aug 29, 2009 | Clarion CZ109 Car CD Player
Speaker hookup
Use the speaker wire outputs on the wiring harness on the back of the radio. The RCA outputs are for using an external amplifier, so you do not want to use them. The speaker wires should be color coded. The front speakers are normally grey and grey with a black stripe for one side, and then white and white with a black stripe for the other side (left and right sides)
The rear speakers are violet and violet with a black stripe and the other rear is green and green with a black stripe. All the solid colors are the positive speaker output and the wires with the black stripe are the negative speaker outputs.
These speaker outputs are on the same harness as the power connections to power up the radio. I believe that it has more than 10 wires on it. I am not sure what socket you speak of that is 10 pin and has speaker outputs. The speaker outputs alone are 8 wires, so the harness will have more than 10 wires. It also has the yellow wire for constant 12 volts to keep memory, the red wire to connect to 12 volts when the vehicle is on, and the black wire for the ground. Then it should also have a blue wire for use with an external amplifier to turn it on or to use for a power antenna to turn it on. You may also find several other wires on it like the orange for illumination and brown for muting the radio when a phone is in use. Those last few wires do not need to be used unless you want them for a specific purpose.
Jan 24, 2009 | Sony CDX-GT420IP CD Player
Installing a aftermarket stereo
This should get you going:
The 2 Blue with a Yellow trace are the POWER wires
The Grey wire is the ACC
The Pink wire is Frontt Left +
The Violet wire is Frontt left -
The Green wire is Front Right +
The Blue wire is Front Right -
The Black wire is Rear Left +
The Yellow wire is Rear Left -
The Red wire is Rear Right +
The White wire is the Rear Right -
The Brown Wire is the GROUND
The Black with a Red tracer goes to the auto antenna
The Pink with a Blue Tracer goes to an aux amp, if you have one.
Oct 16, 2008 | 1992 Toyota Celica
Installation of headrest dvd
yes the screen has to sandwich the material from the headrest to hold it in place.....
Oct 10, 2008 | 2006 Audi A8
Automax 7 band car equalizer
hola, first have tranlate for spanish a english, mira yo tengo el mismo ecualizador, las entradas son (input) el rojo (red) es (+) y el negro (black) (-), el verde (green) es el canal izquerdo (left) y el gris (grey) es el canal derecho (right) eso es toda la entrada, los comunes o los negativos de las salidas del stereo no se conectan (las salidas del stereo tienen que conectarse como si fuera un sistema de solo 2 bocinas a la entrada del ecualizador), las salidas (output) serian azul (blue) comun izquerdo (L-),blanco (white) izquerdo frontal(+ front L), cafe (brown) izquerdo trasero (+ rear L), naranjo (orange) comun derecho (R-) ,violeta (violet) derecho trasero ( + rear R), amarillo (yellow) derecho frontal (+ front R)
para que quede mas claro
input:
red (+)
black (-)
green (L)
grey (gris) (R)
output
Right
violet (Rear)
yellow (Front)
orange (-) R comun
Left
brown (Rear)
wihte (blanco) (Front)
blue (-) L comun
ojala que este post aun te sirva, saludos desde Chile
Jan 27, 2008 | Pyramid 403G 7-Band Car Equalizer
Audiovox MM50PKG2 Car Video Player Logo
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
