Question about Jenn-Air Refrigerators
Jenn air jbl2088wen ice on evaporator - Jenn-Air Refrigerators
TampaNative
  • 778 Answers
SOURCE: Ice and water hook up for Jenn-air JSD2789GEB
The water coupling is usually located at the bottom rear of the Fridge and will require an installation kit (easily obtained at your local Home Improvement Store) and tapping into an existing copper cold water pipe (the kit will/should includes the line tap).
Posted on Apr 26, 2008
worldvet
  • 859 Answers
SOURCE: JENN-AIR BLOWS WARM AIR
Towards the bottom of the freezer is the water diversion tray for when it defrosts. It is usually made of glass but may not be. Lift that up an see if it is blocked by frozen water ice blocking the cold air vent that recirculates and also feeds into your refrigerator.
If this doesn't help wait long enough and one of the other experts on the site will help you. If it does solve your problem I wouldn't be too surprised as I've seen this so many times.
Well, regards and good luck,
Worldvet
Posted on Jun 02, 2008
docjohn174
  • 943 Answers
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Posted on Sep 17, 2008
  • 13 Answers
SOURCE: The ice maker in my Jenn Air refrigerator stopped working.
Check that there wasn't a clog in the line after replacing the filter. Make sure you get water going to the solenoid, if so, it may either be a clog in the solenoid or a fluke that it's no longer working.
Posted on Sep 10, 2009
SOURCE: My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Posted on Feb 13, 2010
How can I force defrost a jenn aire refrigerator jsd2695kes
Check manual to see if there is a manual technique for activating the defrost timer cycle. If not, and you are in rush, remove back cover of freezer, and after unplugging unit use hair dryer to melt the ice built up on the evaporator.
Nov 26, 2013 | Jenn-Air JSD2695KES Side by Side...
Jenn-air refrigerator not freezing or making ice
Before you go crazy just defrost the unit over night and then turn it back on. Possible e that the evaporator froze up due to the open door..Let it stabilize for at least a day and then check to see if all is copacetic.
Sep 14, 2017 | Jenn-Air Refrigerators
First the refrigerator portion lost cooling but the freezer was fine over time the freezer esentially turned into a refrigerator. It is no longer making ice or keeping things frozen, but is about as cool...
the evaporator coil is frozen over and cant release cold air due to this,defrost the unit remove rear panel inside freezer and troubleshoot the defrost heater and thermostat and also make sure the fan near this coil is running, on the evaporator coil as,you cant blow cold air thru a coil covered by ice
Jul 02, 2011 | Jenn-Air JSD2789GES Side by Side...
Model JS42SEDBA Jenn-Air built in fridge. Every few months we get ice build up around the evaporator fan. It is not easily accessible so we can not clean the build up. Short of calling a technician to...
I have this exact problem as well. Have replaced so many parts I'm at the end of my rope with this. Can somone please help!? var fctb_tool=null; function dL3xtGT_mvAT(t) { fctb_tool=t; start(fctb_tool); }
Jan 08, 2011 | Jenn-Air JS42SEDBDA Stainless Steel Side...
My Jenn Air Model No# JSD2789DES Refrigerator does not stal cold and freezer is not freezing anything...I noticed in the back of freezer the wall was covered in ice. It was working fine the other day...
Ice building up in the freezer is not good, it means that your defrost heater is not working.The purpose of the defrost heater, as the name implies, is to prevent ice from building up on the evaporator that is inside the freezer compartment. The heater and/or thermostat failure is responsible for the ice building up in the freezer. Replacing both of is recommended, but if the heater shows continuity with an ohmmeter, just replace the thermostat; if in doubt, replace both of them and your refrigerator should be back to normal. Do not forget to clean the refrigerator condenser fins.
Dec 12, 2010 | Jenn-Air Refrigerators
JCD2289AES jennair fridge refridgerator side is not cold but the freezerside works
The fridge side is not getting enough cold air from the freezer side. This could be due to a few things. The vents from the freezer is blocked, or the evaporator fan/motor has failed, or the evaporator coil is iced up due to the defrost circuit failure.
To check which is the problem you will need to empty the freezer to you can get access to the panel that covers evaporator coil. After removing the panel check to see if the fan is turning, also note whether the evaporator coil is iced up. If it is iced up, then the defrost circuit is failed. The problems usually are a failed defrost heater, defrost timer or defrost thermostat.
Aug 12, 2010 | Jenn-Air Refrigerators
Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2010 | Jenn-Air JCD2389G Side by Side...
Water is leaking out the bottom of my brand new Jenn Air French door model JFC 2089 HE. Why?
likely a lot of condensate has been collecting in the catch tray, and it hasn't been able to evaporate off. You may have to slide the fridge out, and empty the tray by hand.
Nov 02, 2009 | Jenn-Air JFC2089HE French Door...
ice maker?
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
15 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
