Question about JVC Car Audio & Video
What is the wiring from receiver to 5channel amp
U only connect ur remote wire from the unit which is the blue with wite line and goes to ur remote on the amp and the two rca jacks white and red...the rest is pwr from batt and ground from somewhere in ur car..metal...
Posted on Jan 04, 2014
5channel amp 6 speakers how do i wire amp to speakers. channel 5 is a sub channel which i do not have my amp is a polk audio pa1100.5
if it is a 5.1 channel amp wire the center speakers together into the same port. wire the two front speakers in the or der that they would appear on the amp (such as left front speaker to the left front speaker terminal on the amp etc.) and do the same for the rear speakers. and all you should have left is the sub-woofer channel in which you do not have to worry about.
Jun 03, 2011 | Polk Audio Car Audio & Video
How can i set my reciever to power my amp
Hi, I'm not sure I understand your question, but the receiver has preamp outputs on the back. Connect these to the amp input using a stereo RCA cable. You must connect the amp to accessory power at the car's fuse box and use a fuse small enough to protect the wire. To size the fuse and wire, check the max power used by the amp. Use the blue wire from the receiver to "turn on" the amp. There is a connection on the amp for the head unit's blue wire. Make sure you connect the amp's ground with a wire as big as the power wire and make a solid connecting to the chassis. Please let me know if you have more questions, and thanks for using FixYa.
Mar 01, 2011 | Kenwood KDC-1028 CD Player
If i turn the power on , it switch off by it self and the power light flicker red
The set powers off because there is a cut off by the error amp which controls the main relay to switch off for safety from burning out any circuits. It could be failure of the output drive/ the short in the speakers or failure of the error amp section. It is tricky to find out the actual fault because you will have to keep testing by elimination, disconnect power output section, preamp section, and check if this releases the power switching.. Helpful? Good day
Jul 08, 2010 | Denon 3991095008 Rc1068 Remote...
I have a hi fi system of separate components - amp/receiver, cd player. Occasionally when listening to either radio or cd a pop or bang (a bit like a gunshot) is heard and the amp switches off. Is the...
Make sure the speaker wires are not touching at the back of the receiver or at the speakers. Make sue the cable(s) connecting the two is not damaged or shorted. If the wires are ok then the amp/receiver is the problem. Possible bad capicitors are the problem in the amp.
Jun 17, 2010 | Sherwood RV-5050R Receiver
Ive got a 5channel zeus z7oo & im hooking up
if i were you i would put the switch to 4ch and the run one sub from ch1-2 bridged and then ch3-4 bridged. I would have to bet this amp is stable only to 4 ohms bridged with so many channels
Mar 19, 2010 | Hifonics Zeus Z700 Car Audio Amplifier
R556 resistor needs replaces need to know where i can get this at cause no one in the area sales or knows about them cause where this amp is older and they have updated all the resistors, plus like to know...
The only way I know how to is to send it in and have them fix it. I am in the same boat with my kicker amp. They wont sell the parts by them selves. If they did that they could not charge you a ton of money. Or if you can find someone with the same amp and that is willing to give you the part.
Mar 13, 2010 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Where do i connect the power control wire to ? I have a kenwood amp kac 7202, I'm connecting it to a stock cd receiver in toyota corolla 2004
Hello sophnettliss,
Most stock receivers do not have a dedicated amp remote lead and your 2004 Corolla is no exception.
The amp remote can be connected to any switched and fused 12V + source including the OEM receiver accessory wire which is the gray wire in your receiver harness.
Hope this helps.
Oct 02, 2009 | Kenwood KAC-7202 Car Audio Amplifier
I have a jesen ka5 5channel amp plus mono and i dont know how to hook up the subs to the mono
Ok, you're going to choose 1 set of inputs for the subs on the amp (I usually use the low or rear which ever has more settings) Now in the output side you're going to use the positive side of the right side speaker and the negative side of the left side speaker (you can switch left or right as long as they are opposite sides). Lets start with the negative wire connect it to the negative input on one of the subs, connect the positive wire to the positive input on the OTHER sub, then get an extra wire to connect the inputs not used on both subs. Adjust settings in amp and radio and if it doesn't sound good use negative and positive outputs from one single output (only left or only right) Hope this helps.
Oct 01, 2009 | Jensen Car Audio & Video
My name is Noah. I have a Volfenhag zx 7150 2 channel amp, and I was wondering if I could use this amp to run my mids and highs. And if yes, how would I run the wiring?
Hello violentj_1_u,
Yes, the amp can be used to power normal speakers on 2 channels.
The best way to wire the amp to a stock receiver (head unit) is to use a pair of wiring harnesses, one the standard harness that plugs into the vehicle wiring, the other a "reverse" harness that plugs into the stock receiver.
First remove the plug from the receiver and plug in the "reverse" harness. Run the speaker leads from the reverse harness to your amp inputs or to a line output converter (LOC) and RCA's to the amp. Then run the amp speaker outputs to the standard harness speaker wires. Plug the original receiver plug into the standard harness and splice the remaining wires, 12V constant, 12V accessory, ground, illumination, etc, together. Connect the 12V switched wire to your amp remote terminal.
Hope this helps.
Aug 25, 2009 | Car Audio & Video
Eclipse PA5532
I do think you can knowing your Amp is 5channel and 960watts,Yes you can goto radio shack for the potentimeter or goto your local audio store and buy a equalizer So you don't over power your Amp
Nov 22, 2007 | Eclipse PA5532 Car Audio Amplifier
Car Audio & Video Logo
104 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
