Techko sh79005 user gear replace
How do I unjam it?
Sometimes the only effective way to unjam a shredder is to turn it upside down (with power disconnected) and pick out the jamming material bit by bit. It is a tedious, messy job.
Aug 12, 2015 | Techko SH1524CP Shredder
I have a privay Guard model PS-029/MB and I have a brocken plastic gear, can I find this part online?
I have the same problem. The gear that the motor drive shaft touches has been shredded to pieces. when contacting the second gear. The secondary gear is plastic and absolutely WILL shred itself to pieces over a short lifespan (<5yrs) because metal vs plastic is a losing combination.
Feb 02, 2011 | Techko Identity Guard 6-Sheet Strip Cut...
Motor runs but the shredder does not move. It appears jammed but we have taken out what paper we can.
If the motor runs but the cutting shafts do not turn then most likely a gear has been broken/stripped inside. You will have to open it up to see which gear and then contact the manufacturer for parts.
Jan 17, 2011 | Techko SH4105PF Shredder
New gear drive cog needed for c505pz shredder please
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Mar 19, 2009 | Techko SH2106PA Shredder
Gear missing teeth
Good luck, Tom
May 26, 2008 | Office Equipment & Supplies
Huge paper jam ( piece of a checkbook)
Throw it out and buy a new one! staples won't replace this unit and your gonna have to take it apart and clean the gears.
Also tell your employees to stop reversing the drive gears with paper inside the bucket it only reverses the flow and jams the unit.
I would buy a cross cut shredder next time.
Hope that helps.
Jan 19, 2008 | Techko SH1524CP Shredder
Need Information:
Good luck, Tom
Oct 09, 2007 | Techko SH2106PA Shredder
37 people viewed this question
k24674
jasbo
jasbo
