Question about Hotpoint Washing Machines
Washer drier lights flashing programs stop after a few minutes
Hi I've got a Hotpoint BHWD129 washer drier that is about 18 months old. I hardly use the thing, once a week at the most for the washer and I've used the drier a total of about 20 times. Yesterday after washing a load i emptied half of the items out and put on the drier - after about 4 minutes the drier stopped and the lights on the front panel started flashing. This model has 5 buttons in a horisontal line (1200/600) (Extra Rinse) (Super Wash) (Eco Wash) (Start/Pause) all of these lights are flashing at the same time. There are also 6 additional 'program' lights that run sort of vertically but which don't have buttons assigned to them - these light up depending on what program has been selected. These lights just stay as they should be when the other lights are all flashing. I've looked all over on-line and come to the conclusion that all 4 lights flashing is error code F15 - "Dryer element relay faulty". Although it could also be F15 - "Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked." depending on if I have an EVO1 EVO2 EVO4 or standard model. My first puzzle is how do I find out which I have? I think it's EVO1 as there is a /1 at the end of the model number. Then next puzzle is what do I do to repair it? I'm pretty confident with all things electrical, I'd even be happy replacing the relay - but where is it? I've found 4 relays on the main circuit board but how do I know which of the 4 is the right one? Any advice or guidance is very much appreciated. Thanks in advance.
4 Suggested Answers
  • 183 Answers
SOURCE: Flashing Lights on Ariston A1636 & Won't progress to rinse either
Suggest checking for a faulty heater. Regards Engineer
Posted on Jul 29, 2007
SOURCE: GE WCVH6260 Front Load Washer
I removed the three screws, and lower cover cleaned the few pennies, screws and nasty gunk build up from the filter. The wash machine seems to function as it did prior to the clogged issue. Thank you everyone !!!
Posted on May 31, 2009
SOURCE: Front Load Washer - Error F30
my maytag mdg5806 aww
just works few second and then goes
can help me?
Posted on Sep 03, 2011
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Same problem
Power it off at the mains for 60 mins and then rety. If it still does the same then call in a repair man as it is most likely thatthe main controller board is faulty and needs replacing.
Sep 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Washing Machine (W540) stopped working, LEDs flash....?
You must get the filter out, as there is a very good chance that this is the prob, keep unscrewing it and try to move it about, then screw it back in again , and then out again, hopefully this will dislodge whatever it is that is holding the filtter in.
Plz rate thiese comments.
Thanks.
Dec 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius
I have a hotpoint aquarius washer/drier. I don't know if this will solve your problem but I know with mine, this almost always happens, the only way I can get it to start is by firmly pushing the door a few times around where the lock is, once I hear a little click inside it will start ok. I presume its because it wont start as it isn't registering that the door is closed, the only time it does not do this is if I literally slam the door really hard. Hope this helps you!
Sep 13, 2008 | Hotpoint Aquarius WF000 Front Load Washer
There is a series of lights flashing on my Hotpoint BWD129 washer/drier. The lights flashing are the 'door locked' light as well as the 'super wash' and '1200/600' lights. This coincides with the machine...
hi there,
i had similar problem . there is a blockage in the fllter , probably a small sock. the filter is at bottom right hand at front of machine .
turn anticlockwise to open.
regards
big eck
Aug 04, 2008 | Hotpoint Washing Machines
Hotpoint dishwasher bci450
Here are the eco related error codes for your washer..
1)Light 3 (eco) flashes. Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
2) Wash indicator lights 3 + 5 (eco + pre) flashing rapidly. Filter is clogged. Pull out the filter and clean it.
3)Runs for approx. 3 minutes and then stops. Lights 3 + 4 (eco and fast) flash. Probably caused by being plumbed into a hot rather than cold water supply. The incoming water is hotter than required for the wash which causes the machine to cut out. Plumbing the machine into a cold water supply will fix the problem with no apparent long term problems.
May 23, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
WF540 - Won't work and rinse hold and wash enhance lights flash?
Hi ya, just a quick suggestion, have you cleaned the filter on the front of your machine?? My machine did this and it was only when i cleaned the fluff and the 5 pence pieces from this filter it stopped, Hope it helps
Dobby
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Lights flashing but machine not working
hi there i would check the connections to the heater and ntc both can be found behind the lower inspection cover at the rear, UNPLUG FROM MAINS FIRST AS LIVE PARTS EXPOSSED BEHIND!!!
Feb 08, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
23 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
