Question about Fusion Fus37 dvd 37 LCD TV
Do I have an optical pug for my fusion 37 in tv as an option
Do I have an optical outlet to use as an option to the red and white inputs. Bose sent me one but I can't find a place to plug it in sooooooooooooo fustrated!!!
  • Fusion Master
  • 9,639 Answers
Look where all the connectors are located on the tv to see if there is a place marked "Digital Audio Output" If there is then remove the rubber port cover and plug in the optical cable. If there is no digital output, then you cannot use that feature on the Bose
Posted on Jan 06, 2014
Testimonial: "Thank you!"
I have a Bose Cinemate II and an NTSC/PAL AVOL television. I am in Germany. I want to connect the audio, but the TV only has a VGA slot, and I can't figure out how to get them together.
tv model number? does the tv has Audio Out. from tv out to bose input. could be optical or rca type whichever is available.
i think you can use the headphone out but you might need an adapter plug (male, sized to fit) then splits into two male rca plugs (left & right) which will be plug into the bose audio inputs.
if the bose has coax input (digital), better use this.
Oct 07, 2015 | Televison & Video
How to hook up a DVD DIGITAL PLAYER, VCR , Bose Cinemate 2 to 1 DIGITAL ,PHILIPS5704D/F7
Connect the optical output from your TV optical out to the optical input on your Bose system. From that point on, any audio that is sent to the TV from any source or input will be played back on the Bose system.
Jul 11, 2014 | Televison & Video
How to hook up a DVD DIGITAL PLAYER, VCR , Bose Cinemate 2 to 1 DIGITAL SPEAKERS to a PHILIPS
audio out from tv optical to with optical cable to analog converter and then with RCA white and red to receiver .
I am trying to hook up a Bose surround sound to my fusion 37 tv and cannot find the correct audio outputs
There should be a pair of audio outs marked Audio Out / Monitor Out. May be close to the digital out port.
Jan 02, 2014 | Fusion Fus37 dvd 37 LCD TV
How do I connect the Bose solo to my television
At the back of the Bose Solo are three different audio inputs. Optical digital-IN, coaxial digital-IN and Cinch (RCA) (white and red) analog audio-IN.
You should check if your TV has an optical digital-OUT, coaxial digital-OUT or an Cinch analog-OUT connection. you need at least one of these three connections. If not, there is no possibility to connect your Bose Solo to your TV. If you use a SETOP-box to watch TV, you could check if it has one of these audio outputs. If it has, you can connect your Bose Solo the your SETOP-box.
Aug 30, 2013 | TCL L32D20
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
How do i hook my bose cinemate system to my lg tv?
If you lg has Optical Output, Which is a 20.00 Toslink Cable, You hook the cord into the Tv using the Optical Output Port then run to the optical in or DIGITAL In on the Cinemate, If you don't have the option to run optical Check for Red and White Monitor Out from the TV and Run into Red and White on the Cinemate.
Dec 15, 2009 | Bose Cinemate Digital Home Theater System...
How do i get my playstation 3 to connect to my bose 321 system?
Very simple. Red and White RCAs into any available input on the back of the 321. If the PS3 A/V cable can't separate the audio from the video (yellow RCA) by length of cable then get an RCA extension.
You can also connect this digitally with an optical cable (better sound) but you need to assign the optical cable to an input from your system menu. Your system menu can only be displayed on the TV from the video out of the 321. Go to "media center" and then down to "optical source"
May 30, 2009 | Sony PlayStation® 3 (60 GB) Console
I want to hook up my bose speaker systerm to my new vizio tv
Real easy, get a RCA audio cable (red and white ends) that is long enough to go from the tv inputs to your receiver inputs. Plug one end into the audio out on the back of your tv, then plug other end into input on your receiver (tv, cd or vcr). Now everything going to tv will output to receiver also. You may have to go into the TV menu and under audio, set audio output to fixed. Then you can change the volume on your receiver which is best way to go.
**Advanced** If your TV and receiver has optical capability you can use an optical cable instead.
Good luck,
Mar 23, 2009 | Vizio VW42LF 42 in. LCD HDTV
Connecting external speakers
You want to connect to the two marked H below:
Entire manual can be downloaded here:
http://www.hitachiserviceeu.com/scripts/userguide.php/L37V01E_EN.pdf
Mar 19, 2009 | Hitachi 37 in. LCD TV
Fusion Fus37 dvd 37 LCD TV Logo
32 people viewed this question
Top Fusion Televison & Video Experts
Lawrence Oravetz
ray gallant
Are you a Fusion Televison and Video Expert? Answer questions, earn points and help others
