Question about Noritz N-069M-DV, N-084M, and N-084M-DV Pipe Cover
Noritz N-069M DV CA constantlyfreezes below 10C out of ideas and may gobc to tank any ideas
As the title says the war heater constantly frezes below -10C it is installed indoors.I had this problem for about 9 years he first time with the rep's help it was decided to replace unit and reposition unit further indoors.Same problem freezes bursts the valve water leaks everywhere. Cold air seems to be coming in thinking of installing Z vent with backflow damper one at the exit and one closer to the exhaust and wrapping the venting with heating coil. Is it doable, recommendable? Noritz has tried but no luck nobody else wants to touch it. Exhausted, exasperated and fed up any last ideas before I throw this wonderful machine for freeze free zones in the trash.
  • bobalix Jan 02, 2014
    Hi Rino Amoruso, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Are the exhaust and intake both vented to the outside?
5 Suggested Answers
snap101
  • 117 Answers
SOURCE: leaking noritz water heater
Check your water pressure and the diagnostic codes on the controller to see if there is computer failure or another problem with the unit. send me an e mail i might be able to help im a nortiz certified service tech scott@bridgeplumbing.net
Posted on Jul 28, 2009
  • 323 Answers
SOURCE: I have a new Noritz N-069M and need to have it
Black gas pipe is definitely the best,
PG&E will likely have a list of qualified contractors they will be happy to share with you.
Posted on Nov 06, 2009
SOURCE: I have a noritz n-069m-dv. it is coming up with a
I had the same fault code. Noritz told me it was a Bypass Control valve that was blocked from shutting all the way. It is located inside the unit on the bottom right there is a small motor with two wires attached to the bottom of the valve... these wires could possibly be not contacting... I resolved the problem by tapping somewhat strong on the valve with a hammer with a type of punch... i was lucky the tapping unstuck the valve.... i would reccomend if you can't resolve tis simply get a tech who knows how to work on this... there are two gears inside that are keyed by marks on them... be sure that they go back right if you dissasembe this valve. Good Luck...
Posted on Jan 08, 2010
senor8
  • 73 Answers
SOURCE: noritz tank less propane water heater, no out going pressure
There's a filter on the cold water side of the unit. You'll notice a black, plastic, cylindrical component directly below the unit on the cold water line pointing to the left. If you shut of your water and unscrew that cap, there will be a filter attached to the other end.
If the filter is clean, I'd recommend calling tech support for help. You might have an error code.
Posted on Aug 01, 2010
How difficult is it to convert a N-069M Noritz from natural to LP?
It is not very hard, you can contact Noritz directly or a local distibutor to get a LP gas valve and change it out with the natural gas valve. It takes about 10-20 minutes. just make sure you check for leaks before starting it back up.
Jan 11, 2011 | Noritz N-069M-DV, N-084M, and N-084M-DV...
Tank will not turn on when sink hot water is turned on
Do other faucets in the house work ok? if so the kitchen faucet may not be creating enough water flow to trigger the noritz. The Noritz have a flow meter inside of them (depending on the year they where made, older units require 3/4 GPM, newer models require 1/2 GPM). If the kitchen faucet is not turning on the hot water, you can check the angle stop and make sure it is open all the way. Also check the aerator on the faucet to make sure it is not plugged and restricting the flow.
Jan 02, 2011 | Noritz N-069M-DV, N-084M, and N-084M-DV...
Where can I get parts for N-069M and N-063S Heater
Parts can be ordered directly from Noritz. Simply contact them and they will guide you through the process.
Jul 01, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
I opend Drain Plug on my Noritz Unit N-069M and didn't find filter on it. Where I can buy that filter?
The filter is frequently stuck in the filter hole on that model. Look for a black plastic washer with a circular hole in the center; that's the bottom of the filter. You can remove it with a screw driver. Put the screw driver in the circular hole, turn it at an angle, and use it as a lever to wrench the filter out.
Jun 21, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
Got a noritz elvkoo3 heater shuts off and i get a code 90
the 90 code indicates the unit is overheating and needs to be serviced. I'd recommend contacting a servicer to clean the unit with compressed air and perform a descale.
May 06, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
Noritz Tankless gas water heater making load roar when the Hot water is turn on
Sounds like gas pressure is too high..not set properly or exchanger is clogged. Best to get technician out there for this one. Could be dangerous
Apr 08, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
I have a noritz n-069m-dv. it is coming up with a trouble code 66. Any ideas?
Dec 31, 2009 | Noritz N-069M-DV, N-084M, and N-084M-DV...
Noritz 069 error 11
error code 11 is an ignition problem. make sure your gas pipe is sized properly, if your on propane check your tank and make sure it's not low or when it's running take the cover off and look in the flame window and make sure it's an even flame if not you probably have a gas control valve problem
Aug 06, 2009 | Noritz N-069M-DV, N-084M, and N-084M-DV...
Noritz N-069M-DV, N-084M, and N-084M-DV Pipe Cover Logo
37 people viewed this question
Top Noritz Plumbing Experts
Kyocera HP Expert
paulcarew
Muzammil Razzaq
Muzammil Razzaq
Are you a Noritz Plumbing Expert? Answer questions, earn points and help others
