Question about Kenmore 24032\24036 Top Load Washer
Kenmore "80 Series," model #110.28812790
It ran one load today fine, but on the second load, it did not fill with water, only went straight to agitation, then to spin if I left it long enough.  I let run through a full cycle, but same results, nothing was "reset."  Any water level or temperature, any cycle choice and the result is the same: only agitation (mine and the machine) followed by spinning.  Does this sound terminal or is it a part swap?
Thanks in advance
Tom
  • markmaximus1 Mar 14, 2008
    my kenmore 80 series washer does all the cycles but doesn not spin. Is it a quick fix or should i call repair man?
  • 291 Answers
Sounds like it may be in you pressure switch sounds like it is stuck on full... like you have a full tub or water..
the white part with the hose is the pressure switch
Kenmore ck on full... like a full load of water is in the tub
Posted on Oct 27, 2007
My washer will not spin or agitate, but will fill & drain
with it empty need to look at the bottom of the unit and see if the pulley and belt setup is bad.. my sisters un it broke the pulley and hers is newer..seems they dont make them to last anymore..
Feb 08, 2014 | Washing Machines
Kenmore series 80 model 110 wont stop filling!
There is a clear plastic hose that runs from the load selection switch to the side of the washer drum. This hose connects the fill sensor to the load switch. without it being in good condition and connected properly the washer won,t get a signal that it's full.
May 09, 2013 | Kenmore Washing Machines
I have an Amana Top Load Washer Model Number ntw4800vq1 The washer shakes violently during the Spin Cylce. It will walk across the floor. I took the console off and removed the outer shell. I checked...
Hi
for the question of water comming in the spin cycle, yes its normal we call it a spray rinse. For the shaking check your leveling and also make sure that the back leveling feet when lifting back of washer up and down that the foot mechanism is functining.
Hope this helps
Mar 27, 2011 | Amana Washing Machines
My WHDSR109J8WW Top Load Washer will not agitate or spin. When to the spin cycle something clicks as if trying to spin but does not. Checked belt...fine. Did the reset motor troubleshoot...did not help....
hi Jlove.
Washer Fills but Does Not Agitate. If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts..
Washer Doesnt Agitate or Spin
Top Load Washer will not agitate or spin Google Search
Dec 13, 2017 | GE Washing Machines
Not getting any water?
very strange problem.. there is a unit within the washer that does not allow it to start agitating untill the water is at the level desired. its very clever name is water level indicator valve the valve must be jammed closed there fore the washer thinks the barrel is full of water and goes strait into wash cycle. i would say replace the w/l/i and youl be fine
good luck
Jul 12, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
I have a Kemore 80 series washer model not filling properly
Check the inlet hoses for plugged screens at the faucet ends. The screens are usually replaceable if you can't get them clean in a white vinegar/hot water solution. Check the inlet ports to the washer for similar screens. Hope this helps!
Mar 17, 2010 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
2,452 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
