Question about New Home HF-106
My thread keeps jamming in the shuttle race - New Home HF-106
  • New Home Master
  • 7,365 Answers
Try a new needle
try a different bobbin and make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the top thread take up lever
Posted on Jan 27, 2014
Singer Futura XL-580 thread tangles on underside.Machine makes a loud "clicking" sound.Was doing free motion quilting and got a jam. Changed needle,changed bobbin,and rethreaded both top and bobbin.
Sounds like there might be some thread stuck in the bobbin shuttle area. Refer to the users manual for your machine to see how to disassemble the bobbin shuttle and race to check for thread. It would be a good idea to put a drop or two of sewing machine oil on it while you have it apart.
Aug 21, 2017 | Singer Sewing Machines
Bobbin shuttle fell out
About 8,950 results (0.69 seconds) Search Results
    Inserting the Janome Front Loading Bobbin Case - YouTube
    ? 1:46
    https://www.youtube.com/watch?v=Mz7-k4G9HFg
    May 8, 2013 - Uploaded by Janome Canada
    Learn how to insert a front loading bobbin case. It's easier than you might imagine. Janome ... Janome HD-1000, Beginnersewing machine.
    How Do I Fix My Sewing Machine: Troubleshooting Your ...
    www.craftsy.com > Blog Home > Sewing Blog
    Nov 7, 2014 - Well, I've been teaching on Janome machines for about 6 years, and I ...Take the Trouble Out of Sewing Machine Troubleshooting! ... has fallen out of the take-up lever, which can happen if the machine was jammed along the way. ... of thread through the bobbin winding tension at the top of the machine.
    Bobbin Case Keeps Falling Out of a Sewing Machine ...
    www.thriftyfun.com/Bobbin-Case-Keeps-Falling-Out-of-a-Sewing-Mach...
Feb 09, 2016 | Janome Hd1000 Sewing Machine
The upper thread becomes jammed inside the lower track of the shuttle. What can I do?
Try a brand new needle. Change thread. Make sure the needle is installed facing the correct direction and is pushed all the way up. The upper tension may be too loose.
Short of that, could be the machine's timing is off.
Dec 16, 2015 | Euro-Pro Shark by Euro Pro Sewing Machine
Bobin will not thread up..does not turn
Refer to the manual for removing the bobbin case and race/shuttle. Clean the area. Read the instructions to be sure the race/shuttle is properly reinstalled.
If the bobbin remains jammed, a service tech will need to look at it.
Mar 10, 2010 | Sewing Machines
I need to know how to clean and oil the machine
From the Sears Kenmore manual:
Using a small brush, remove the lint that accumulates in the shuttle area and around the feed dogs.
To Clean the Shuttle Area:
  1. This area must be kept free of dust, lint and occasional tangled thread. Raise the needle bar to its highest point and remove the bobbin case.
  2. Push levers of shuttle race aside and lift shuttle race cover and shuttle out.
  3. Clean the shuttle race with a small brush.
  4. Put a drop of oil on the center pin of the shuttle and shuttle race.
Jan 25, 2010 | Sewing Machines
My machine is a Brother XL5600; I think I am having a shuttle hook problem. When I lower the sewing needle to "catch" the bobbin thread and pull through- it won't catch and pull through. I have changed out...
Hi
Thanks for using FixYa. The upper thread could be tangled. Remove the thread completely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine according to the directions in the manual.
Place a spool of thread on a spool pin and check the upper threading.
Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
Also please check that the bobbin is installed in its case rightly. Needle thread is too tight. Hold the thread lightly to keep the end from going down into the shuttle.
The needle could be thread incorrectly. Thread the needle eye from the front to the back.
The needle could be bent or improperly inserted and install a new needle with the flat side of the needle facing the back.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | Brother LS-2125 Mechanical Sewing Machine
The needle does not pick up the bobbin thread
Hi!
There may be so many reasons due to which the needle does not pick up the bobbing thread like---
The upper thread could be tangled. Remove the thread commpletely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine. Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race. You could be holding the needle thread too tight. Hold the thread lightly to keep the end from going down into the shuttle. The needle could be thread incorrectly. Thread the needle eye from the front to the back. The needle could be bent or improperly inserted. Install a new needle with the flat side of the needle facing the back.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 08, 2009 | Euro-Pro 9105 Computerized Sewing Machine
Machine problem
Hi!
There are so many reasons due to which the thread is not picking up from the bobbin like:
The upper thread could be tangled. Remove the thread completely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine. Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
The needle could be threaded incorrectly. Thread the needle eye from the front to the back.
Do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 01, 2009 | Bernina Activa 130
Singer Merritt 2430
Hi!
There could be several reasons due to which the thread keeps bunching up underneath.
It may be due to tangling of upper thread. Remove the thread completely from the machine, use correct size spool cap for the size of the thread spool, re-thread the machine, now remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
Please rate the solution as FixYa and revert for any clarification.
Thanks
Rylee
Apr 23, 2009 | Janome 6019QC Mechanical Sewing Machine
Kenmore 385. 11607 needle jams into shuttle or shuttle race
I had the same problem with cleaning and jamming and this might sound silly, but when you're in the middle of trying to fix it remember to look up see that it is threaded up top. I did everything the pp's suggested and when they didn't work I realized the top thread wasn't still threaded around the tension thing anymore. After rethreading it, it worked fine. But I DID reduce the amount of thread on the bobbin at the same time as Drazil suggested.
Dec 17, 2007 | Kenmore Drop-In Bobbin 505S-21BH...
New Home HF-106 Logo
99 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
navapistol
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
