Question about PANDIGITAL Office Equipment & Supplies
Need help with a Kodak Personal scanner
I have a P811 Personal Photo Scanner and the calibration card was missing. I contacted Kodak who then directed me to you for help. Is it possible to get ahold of a calibration card for this product, please? Monique Kogan kogankosmider@yahoo.com
    Top Expert:
  • PANDIGITAL Master
  • 45,018 Answers
Kodak is passing the buck. You would think that they could provide a calibration card for their own scanner.
Posted on Jan 02, 2014
4 Suggested Answers
  • 16 Answers
SOURCE: i have a Kodak i620 color. All of a sudden the red
What does the KDS Log say? find it in the SVT info tab and save it for more info. its probably your ultrasonic sensors dirty or faulty. good luck
Posted on Sep 24, 2009
SOURCE: need drivers for iconvert photo scanner
says it does, link below.
http://www.ambir.com/ambir/ambir-support
Posted on Feb 14, 2010
SOURCE: pandigital mini photo scanner pictures have white lines on them
have a pandigital scanner that worked great for about 500 pics then lines stared to show up, tried cleaning and calibrating but did not help, decided to take apart and found that the glass on the surface of the scan part was dirty, cleaned the glass and put back together works perfect, took about 10 minutes to fix
Posted on Jul 13, 2010
My Kodak P811 scanner will not pull the paper thru.
I would check it there is a kodal service Hodak scanner service centre nearby to be honest...the last thing you want to do with a quality photo scanner is put it back together incorrectly. But I am cautious when it comes to electronic devices.
Jul 19, 2015 | Kodak P811 8x10 Personal Photo And...
How to calibration kodak i2600?
To calibrate you need to use the Scan Validation Tool and a sheet of white A4 paper but you will need a daily key to allow this , Contact your local Kodak Alaris dealer they will usually give you a code
Jul 16, 2015 | Kodak i2600 - Document scanner - 8.5 in x...
Scanner Model is Kodak i4200. Whenever I scan a document in Color Mode the background is filled with BLUE color. This doesn't happen when I scan in B/W mode. Can you please help ?
If you are talking about a blue tinge Try turning on background smoothing in the driver under adjustments that may sort it or adjust the brigtness and contrast a little if that doesnt solve it Image calibration is the next step you will need to contact Kodak as its not a user function
Jan 09, 2015 | Kodak i4200 - document scanner
What is calibration sheet,and where do i find one?
Hi, the calibration sheet being referred to was sent with the printer, it's a piece of cardboard ( white with one corner missing). Please check the packaging if you still have it, otherwise borrow one from a friend. All the best.
Oct 15, 2014 | Innovative Itns-500 Film, Slide, Photo &...
Pictures will not go to my memory card on my pandigital kodak p811 personal photo scanner. I have tried a different card and it still does not work
pilipino ba 2 , try mo linisin nang dry cloth or dry paper ung area whre you plug in the memory card make sure its clean because it might be the area whre the memory card is plugged .is not working .Is there any error message .Make sure the card is properly plug in .
May 22, 2011 | Office Equipment & Supplies
Scanner Error
Some electronic equipment such as printers and scanners need to be "calibrated".
I recommend you follow the directions and allow the Scanner to calibrate. This may result in better scans and for printers, better printouts.
Mar 30, 2009 | Kodak I660 Flatbed Scanner
Microtek ScanMaker 8700 - 'kdsinput internal error'.
try this:
http://support.microtek.com/knowledgebase_1/kbdtl.php?request=KB-00007EP&vw=1
Aug 04, 2008 | Microtek SCANMAKER I900 Flatbed Scanner
I280 won't scan!
ImageCalibration means the cameras don't get enough light during their self test.
Please check the following points:
Are both lamps on or one lamp in case you have a single page scanner?
Are the imaging guides (the clear sheets above the cameras) clean?
Are the little white tags on the imaging guides present?
One tag on each imaging guide.
Without this small white tags the cameras are not able to check themself.
For emergency you can apply a small white paper or white insulating tape instead of missing tags to test the scanner.
If the lamps are light, both tags are present please calibrate the scanner with the kodak calibration sheets. You will find the calibration menue in the scanner validation tool. You can get this tool from the Kodak home page.
Jul 15, 2008 | Kodak i 280 Path-Through Scanner
My kodak easyshare5300 is printing black picture
Hi-
If your product is still within the warranty period from KOdak then you can call them up for some step by step troubleshooting to help you with your problem and as well they can replace the printer if defective.
Try this first
Calibrate your printer, then print a demo sheet.
  1. If paper is in the photo paper tray, remove it.
  2. Load photo paper into the photo tray.
    1. Fan the paper to keep the sheets from sticking together. IMPORTANT: Do not overload the photo tray.
    2. Load a maximum of 20 sheets into the photo tray, with the Kodak logo facing up.
  3. Calibrate your printer.
    1. Press Menu.
    2. Select Calibrate Printer, then press Start.
    3. Wait for your printer to print the calibration sheet.
    4. Place the calibration sheet face down on the scanner glass.
      • For the 5300 AiO printer, place the sheet on the front right corner of the scanner glass.
      • For the 5500 AiO printer, place the sheet on the left rear corner of the scanner glass.
    5. Press Start.
    6. Wait until "Calibration complete. Remove calibration page from scanner glass. Press OK to continue." appears on the LCD display.
    7. Remove the calibration sheet from the scanner glass, then press OK.
  4. Print a demo sheet.
    1. Disengage the photo tray by sliding it towards you until it stops. When the photo tray is disengaged, the main tray is active.
    2. Select Print Demo Page, then press Start.
    3. Wait for the demo sheet to print.
Then call them if issue Persist at these numbers:
In the U.S. and Canada: 1-800-421-6699
In Australia and New Zealand: 1800 793 895
Thanks for using Fixya!
Jun 21, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
236 people viewed this question
Top PANDIGITAL Office Equipment & Supplies Experts
Mike
LP
Are you a PANDIGITAL Office Equipment and Supply Expert? Answer questions, earn points and help others
