Question about HP Office Jet 4500 G510n
Not detecting paper on top of the glass - HP Office Jet 4500 G510n
    Problem Solver:
  • 19 Answers
If you are trying to scan/copy a receipt of something else that is smaller, try to tape it to a regular sheet of paper before you copy it.
then the unit can detect the paper size.
Posted on Jan 02, 2014
Black Will Not Print
I installed new ink cartridges but after installation my printer don't align when making copies on top of the glass the paper is not detected.
May 24, 2013 | HP Office Jet 4500 G510n
My IR 6570 feeder only detect A4 paper and not F4/Legal paper and some times misread the paper
check the legal size on the glass and measure it with ur paper.this is common problem as these machines are designed for specific country papers and most times the legal paper of different countries differ .no solution dear .try using the bypass tray
Sep 16, 2011 | Canon IMAGERUNNER 6570 Copier
When I scan a document using the feeder on top, the resulting scanned document has two parallel black lines down the left side of the page. What causes it and what fixes it?
When using the ADF if the glass has dirt on it, as the paper moves over the glass the image is written to the moving paper. The paper is also moving over the dirt specs on the glass causing verticle black lines. It is hard to explain without actually showing you. To fix the problem, lift up the top to expose the glass. Look to the left of the big rectangle glass. There will be a 3/4 inch glass strip. CLEAN IT.
Aug 26, 2011 | HP Officejet 6500 Wireless All-in-One...
SCX 4826FN everything that goe in through the top feeder (scans, copies, faxes) comes out with a solid vertical black line on the paper. All other printing jobs that pull paper from the tray are ok. It...
This black line sounds like it is definately coming from the ADF scanner glass. This is the thinner strip of glass that is located just to the left of the large original glass. You can verify this by making a copy from the large glass instead of using the feeder on top. If the copy comes out clean then it is definately the scanner glass. Just clean the glass well with glass cleaner and a soft cloth. This glass is only used when copying/scanning using the top automatic feeder
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Samsung Office Equipment & Supplies
Problem in ADf while putting a originals on ADF screen shows remove the original from the platen glass , when there is no paper on the glass
There is usualla small sensing switch located at the back of the ADF that detects when you have lifted the cover to remove the paper.
This switch may be malfunctioning.
Dec 23, 2009 | Canon NP 6085 Copier
Misfeed detected but no paper jam
Di 251 is legacy Minolta machine, Minolta is now Konica Minolta
for the image unit try this site
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
as for the adf replace!!! the rollers all three try the same site above
Nov 03, 2009 | Minolta Di251 All-In-One Printer
Can't get the copier to scan only 8.5*11 area on glass
Set your original settings to the actual size.
You are using the auto recognition feature which is over-ridden when you specify the size manually.
It will try to match it to the nearest size it "knows". That is why the stamp is detecting so large.
Apr 09, 2009 | Konica Minolta Di1610 Copier
AFICIO 551 BLACK AND WHITE
Which feeder? Is it in the document feeder or the paper tray?
Could need a pm to replace the drum, cleaning blade, and possibly developer to get rid of the dirty copy and/or the scanner section should be cleaned as well by cleaning the glass as well as the mirrors underneath the glass.
Dec 10, 2008 | Ricoh Aficio 450 Copier
Canon ir5000
hi im jules_09.have you set the paper size first before copying.there is nothing wrong with adf its fine.if you want to use fls go to the program then set the size of the paper and which tray you are going to use each paper tray can be adjusted according to your paper size needs
Nov 06, 2007 | Office Equipment & Supplies
Adf issues
one usefull thing to try - Place a blank piece of paper on the glass. Next, put your hand on top of the piece of paper and slide the paper back and forth across the glass. If you feel the paper sticking, you need to clean the glass with a glass cleaner, then polish the glass with a glass polisher(consult the manual first on this). You also need to clean the plastic between the glass and where the paper enters the glass. if it still doesnt work try to reset the machine, sometimes it takes some rest to reset such problems.
Jan 19, 2006 | Xerox DOCUMATE 510 Flatbed Scanner
HP Office Jet 4500 G510n Logo
24 people viewed this question
Seeker5211
Seeker5211
