Question about Cisco Nexus 7000 Modular Chassis (N7K-C7010=)
How i can configure NTP in my nexus 7000
Need to confiugre NTP in my nexus which will help me in logs time
I want t uninstall the android update how do i do that?
For the CISCO or another device, many times you need to download the factory image and reflash..
Nov 18, 2014 | Cisco Nexus 7000 32 Port 10GBE 80G Fabric...
Issue with time synchronizing(NTP) on layer 2 switch
I know this is probably not going to help you out but you did try going to Alcatel-Lucents web page and search through there or calling them at 800 995-2696? Good Luck! Sorry I couldn't be of some help
Mar 04, 2014 | Alcatel OmniSwitch 6850 (OS6850-48)
Directory key = "no application available", need to store phone #
You need to configure your CS 1000 for Personal Directory / Redial List / Callers List through Element Manager. Instructions for doing this are in the IP Line Fundamentals NTP. You can download the NTP from www.nortel.com/support.
Mar 23, 2009 | Nortel i2004 IP Phone
Setting the time and date
Page 1-16 of the NetworkAdmin Users guide.
In the network settings, select "No" for use NTP to enter manuall.
Log in as administrator though Pagescope Webconnect and set the time manually there easier.
Jun 16, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Can´t CONNET to AD
You have to make sure that the clock of your NAS is synchronized with the ActiveDirectory. Configure your NAS to use NTP. This should be under the clock configuration screen. Enter the IP address of your domain controller(s) as the NTP server address.
Also, it would be a good idea to make sure that you domain controllers are synchronized with a root time source (on the Internet). In order to do that, run the following command on all you DCs.
C:\>net time /setsntp:br.pool.ntp.org
Of course, your DCs must be able to access the internet on port UDP 123.
Judging by your email address, you seems to be located in Brasil. If you are not in Brasil, you may look for another NTP server http://support.ntp.org/bin/view/Servers/NTPPoolServers
Feb 02, 2008 | Intel SS4000-E (SS4000ENA)
Resolution of NETGEAR NTP Issue
NETGEAR and the University of Wisconsin ? Madison have identified an issue with how some NETGEAR routers utilize the network time protocol (NTP) public time service provided by the University. Specific NETGEAR home routers rely on public time services provided by the internet community. If a specific public access NTP server is unavailable, these routers will not be able to synchronize their time with the public NTP server. As a result, features such as logging, email alerts, and time-based URL filtering may experience a degradation in time-keeping. Overall router functionality is unaffected. Network traffic to the specified time server, however increases as the router tries to obtain the time. ?As soon as the issue was identified, NETGEAR worked closely with the University of Wisconsin - Madison to understand the issue and minimize any impact,? said Annie Stunden, CIO at the University of Wisconsin. ?NETGEAR has taken a leadership role in working with the University to ensure a reliable networking experience for its customers and to establish best practices for interfacing with our public access servers.?
Feb 19, 2006 | NetGear RP614 Router
Netgear FR114P Time Checks
Most likely the router if you have the option turned on. Look at Schedule section of the configuration. Another possibility is Windows XP clients, assuming your clients are XP. The default installation has XP checking its time against time.nist.gov. Check the clock setting for this.
Feb 19, 2006 | NetGear FR114P Router
NTP
Step 1: Log into the router´s web utility and click on Tools and select Time. Step 2: You will need to set the time zone corresponding to your location. Step 3: If you set the time manually, select the date/time and set Daylight Saving (if applicable), click Set Time, click Apply, and click Continue. Step 4: If you have the IP of an NTP server, enter that IP address in the default NTP server box, click Apply and click Continue. If you leave the box empty, the router will use its default NTP servers.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
How does the router synchronize time?
The router pulls it's time like any computer. It uses the Network Time Protocol or (NTP). In order to utilize the NTP a valid Internet connection must be achieved. Network Time Protocol (NTP) is a protocol that is used to synchronize computer clock times in a network of computers. NTP is now an Internet standard. In common with similar protocols, NTP uses Coordinated Universal Time (UTC) to synchronize computer clock times to a millisecond, and sometimes to a fraction of a millisecond. UTC time is obtained using several different methods, including radio and satellite systems. Specialized receivers are available for high-level services such as the Global Positioning System (GPS) and the governments of some nations. However, it is not practical or cost-effective to equip every computer with one of these receivers. Instead, computers designated as primary time servers are outfitted with the receivers and they use protocols such as NTP to synchronize the clock times of networked computers. Degrees of separation from the UTC source are defined as strata. A radio clock (which receives true time from a dedicated transmitter or satellite navigation system) is stratum-0; a computer that is directly linked to the radio clock is stratum-1; a computer that receives its time from a stratum-1 computer is stratum-2, and so on. The term NTP applies to both the protocol and the client/server programs that run on computers. The programs are compiled by the user as an NTP client, NTP server, or both. In basic terms, the NTP client initiates a time request exchange with the time server. As a result of this exchange, the client is able to calculate the link delay, its local offset, and adjust its local clock to match the clock at the server's computer. As a rule, six exchanges over a period of about five to 10 minutes are required to initially set the clock. Once synchronized, the client updates the clock about once every 10 minutes, usually requiring only a single message exchange. redundant servers and varied network paths are used to ensure reliability and accuracy. In addition to client/server synchronization, NTP also supports broadcast synchronization of peer computer clocks. NTP is designed to be highly fault-tolerant and scalable.
Feb 16, 2006 | Belkin DSL Gateway Router (f5d5230-4-dl)
Feb 16, 2006 | Belkin (F5D5230-4) Router
Cisco Nexus 7000 Modular Chassis (N7K-C7010=) Logo
56 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
