Question about Brother ML-300 Typewriter
I installed the correction tape and it does not correct
I installed a new correction tape properly like I have on other occasions but when I type a few letters and hit correct the typewriter does not make the corrections. I noticed previously that the part holding the ribbon and correction tape would lift when I would hit correct. It no longer does that.
  • 24 Answers
Sounds like you have diagnosed the problem. Remove the correct tape and make sure that it's not the "sticky" type. (it will be hard to unwind if it is). Next try to manually lift the part that's supposed to move to see if it does. If it's sluggish (hard to move) put rags around it to prevent over spray and carefully clean all the moving parts with WD40. Make very sure that the WD40 does not get on any electronic parts! It will also mess up the platen. So, the more rags around the moving parts, the better. I used to work on IBM typewriters, and WD40 sometimes works wonders.
Posted on Jan 02, 2014
SOURCE: Correction function not working
I've found that if I don't use the machine for a few weeks the correction tape that is exposed to the air becomes ineffective. I make a bunch of corrections in a row until fresh tape comes off the roll and the correcting function starts to work again.
Posted on Oct 09, 2007
JUSTOLDJIM
  • 478 Answers
SOURCE: not typing correct letters
Send it back for repairs if under warranty. This is not an office machine it is designed for very light home use.
Posted on Mar 10, 2008
SOURCE: Random letters/correction tape
Hit Alt Operate Return - It worked for the same problem! : )
Posted on Aug 12, 2008
M2Tech1
  • 313 Answers
SOURCE: Typewriter won't type
check to see that when yu replace the ribbon it has not slipped in front of the print ribbon and that you have not got the button for corection pressed by mistake it is using this to print you letters not the ink ribbon
Posted on Jun 12, 2009
  • 3594 Answers
SOURCE: installing new correction ribbon
Go to brother.com click on support a users manual is available there.
DickyO
Posted on Jan 23, 2010
HOW DO I INSTALL THE CORRECTION TAPE? CAN'T GET IT TO CORRECT TYPING.
Theres a manual here that should tell you everything you need to know.
Dec 05, 2014 | IBM Correcting Selectric III Electric...
Changing correction ribbon
First this is old school after hitting the correction you must press the letter you are trying to correct. if you knew this and the correction tape is properly installed and lifts up you may have old supplies, If you want to talk yuo can call me.
DickyO
216-269-3918
Dec 05, 2014 | IBM Correcting Selectric Iii Typewriter...
We understand that your problem is: Dell Latitude D420 - additional memory installed 2GB but the sytem only sees 467Mb of memory, keep getting BSOD on Boot every time. Have re-installed mem chip on...
1) Make sure you have the right memory module type. IE ddr2 ect. check your model with a memory website that checks which modules should be in your particular notebook. Its a tedious task but important.
2) Make sure your type of notebook can handle the amount of memory you have in the laptop. Some types only allow a maximum memory limit.
3)Make sure chip is installed correctly that both sides are clicked in properly.
Jun 12, 2011 | Dell Latitude D420 Notebook
I installed new correction tape, but there's too much play in it. It keeps unravelling. I have no idea how to tighten it up. When I turn the take-up spool, it just unravels it more without tightening...
Verify that you have installed the proper correction tape. The types of tape that can be used with this system are: Item 1030 - Correctable Film Ribbon, 1230 - Correctable Film Ribbon 2pack, 1031 - Multi Strike Ribbon, 1032 - Nylon Ribbon, 3010 - Lift-off correction tapes (to be used with 1030 and 1230 ribbons), 4010 Cover-up Correction tape (to be used with 1031 and 1032 ribbons).
Make sure that the correction tape is installed properly. Pass the tape through the left guide, behind the ribbon guide and out through the right guide. The rough side of the tape should face the platen. Attach the feeder spool to the pin on the left. Attach the take up spool to the pin on the right. Turn the take up spool counter clockwise until a small amount of tape has wound around it. Replace the cassette ribbon and close the case cover. Press [CODE] + [RESET] to move the carrier to the previous position.
Dec 27, 2010 | Brother ML-100 Typewriter
Installed a corrective ribbon on a SL480 typewritter, now I can't get the ribbon back on.
Sounds like the correction tape is not installed properly. Try remving and reinstalling it again. Make sure the hammer solenoid assembly is latched to its home position. After installin the correction tape you can manually operate the lift arms to check the feeding of the tape. If you have a loca dealer you can probaly take your machine to them and they may install the tape for you at no charge.
Nov 15, 2009 | Smith Corona Office Equipment & Supplies
Lift off tape
Does the tape lift up far enough for correction? If so check to be sure the dull side of the tape is facing the paper. Then be sure you are using a correctable ribbon, the feed wheel should be either yellow or orange. DickyO
Jun 02, 2009 | Brother GX-6750 Typewriter
The correction tape isn't working. it's installed properly, i think, but it doesn't erase anything.
Try taking the tape out and re-installing with the "dull" side towards the paper...if that doesn't work try a new correction tape.
May 29, 2009 | Olympia Mastertype 3 Typewriter
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
Daisy wheel not moving
Be sure the correction tape is dry type, if it is a sticky one it will cause you all kinds of trouble.
DickyO
Jan 31, 2009 | Brother SX-4000 Typewriter
Changing correction tape on swintec 2600
Be sure the corr. tape not a tacky kind, then type some thing and correct it watching the mechinism th see which one turns and in what direction. Install the empty spool on that hub thread the L/O thru the guides with dull side facing the paper and then the full on the supply hub. there may be two or more guides depending on the printer.
Hope this helps
DickyO
Apr 28, 2008 | Office Equipment & Supplies
Brother ML-300 Typewriter Logo
99 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
