Question about 1996-2002 Chevy Cavalier Thermostat Housing for L4 2.4L
How do I change the thermostat on a 1996 chevy cavalier
    Champion:
  • 207 Answers
You will need a socket or wrench set to take the small bolts out of the thermostat, You need to have something to catch any antifreeze in the heater hose as you remove usually the top heater hose. You will need a new thermostat and some gasket sealer. You might need to remove the old gasket sometimes they stick BUT BE CAREFUL do not grove the gasket area. Use a gasket scraper to remove old gasket, if you don't have one you can use a straight blade to remove it JUST BE CAREFUL not to grove housing. Put gasket sealer on one side of gasket and place on thermostat housing let dry 5 minutes. Then use sealer on the top of gasket and place thermostat on gasket let dry 20 min. Replace bolts in thermostat and replace heater hose then start car and check to see if you need to add antifreeze if you lost any. Hope that helps
Posted on Jan 03, 2014
How to override the speed governor in a 1996 Chevy cavalier
that will take some software and knowledge of the engine control module... I.E. not happening
Sep 15, 2014 | 1996 Chevrolet Cavalier
1996 chevy cavalier keeps overheating
You have to :burp" the cooling system.
Rather than me trying to walk you through this with text, just google and youtube yourself through it.
Search for things like "Bleeding the cooling system" and you will find a few different ways you can do this.
Just use caution when the water is hot.
Mar 19, 2014 | 1996 Chevrolet Cavalier
96 Cavalier Auto Trans left turn and stop
Trans fluid maybe low, and/or trans filter stopped-up. Drop pan...change filter...replace fluid.
Oct 03, 2012 | 1996 Chevrolet Cavalier
If my 1996 chevy cavalier has no over head cam on it do i have to fix the timing in it after i change the head gasket?
no you dont have to change the timing chain but if the milage is high i would recomend it
Oct 16, 2011 | 1996 Chevrolet Cavalier
1996 chevy cavalier 2.4 liter engine is overheating. Water pump should be new, thermostat definitely new. Yesterday it started overheating with the heater on so replaced thermostat and today tried driving...
I am having the same problem. I have read that only a GM thermostat may work aftermarket thermostats dont work in some cases. If the top radiator hose is hot and the bottom is is dramatically cooler, then more than likely, the thermostate is not opening. The other part I dont know yet is how to purge the system of air. Trying to find that out now. Good luck.
Aug 30, 2010 | 1996 Chevrolet Cavalier
Where is the thermostat on a 1996 Chevy Cavalier?
Follow the lower radiator hose back from the radiator to the engine - where the hose is attached to the engine, you should find the thermostat housing.
Mar 20, 2010 | 1996 Chevrolet Cavalier
Change a serpentine belt on a 1996 chevy cavalier
Diagram should be under the hood
The auto tensioneris down low and dificult to get to.
If it has not been changed in a while you will need a long thin push stick and a serpentine tool.
Push on the belt hard at the auto adjuster and pop the belt off the smooth pully (located top).
hook up the serpentine belt tool and then mount the new belt
Jan 17, 2010 | 1996 Chevrolet Cavalier
Where is the thermostat on a 1996 chevy cavalier
Follow the upper radiator hose that comes out of the top side of the radiator and connects to a hose barb that is bolted to the engine block. That hose bard is held on by 2 bolts, take those two bolts out take the hose barb off and that is where the thermostat is.
Good Luck
Dec 19, 2009 | 1996 Chevrolet Cavalier
1996 Chevy Cavalier - How to replace the spark plug wires?
one at a time so you dont lose firing order ..which is 1 3 4 2
Apr 11, 2009 | 1996 Chevrolet Cavalier
1996-2002 Chevy Cavalier Thermostat Housing for L4 2.4L Logo
93 people viewed this question
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Tom
Mike Stager
Mike Stager
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
