Question about Whirlpool Water Heaters
Blinking red light on Whirlpool gas hot water heater
Whirlpool gas hot water heater Model # N40T91-403
  • 21 Answers
SOURCE: Whirlpool energy smart water heater
Two flashes means that the high limit temperature has been reached. Once this happens, the temperature control system will shut off. Make sure that all element access doors are in place. Push the "Push to Reset" button to restart the temperature control system. The water heater will self test for ten minutes before it will start to heat. If you get the 2 flashes again then you may need to replace one or both elements. Each element should measure 5-25 ohms.
The "thermostat" is the knob marked "Temperature Control". Make sure that the operating mode is set to 1,2 or 3.
Posted on Jan 13, 2009
  • 152 Answers
SOURCE: No hot water
The code # 11 is a code that warns of "no ignition" and the causes of this error code are too many to list. I would suggest that a qualified tech. perform a diagnostic test and repair.
This is not a task for the "do it yourselfer"
Posted on Mar 25, 2009
john224
  • 1378 Answers
SOURCE: Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
Posted on Dec 17, 2009
SOURCE: i have a richmond gas hot water heater model
lock out code....turn off unit for 1 minute (unplug) press both arrows and hold for 5-10 sec... then enter L R L L ... R L R R...that should reset it.
Posted on Jul 25, 2010
SOURCE: I have whirlpool gas water heater sg1j5040t3nov.
Called whirlpool and explained the problem. They said I need to replace that upper sensor and so they sent me a part in the mail which cost roughly $25. (usd) not including the overnight shipping which is around another $25 or so. This picture is what I received in the mail. Comes with directions of installment. _273.jpg
Posted on Dec 08, 2010
Whirlpool 30 gallon gas hot water heater. does it have a battery
Need the model number to know for sure. I don't know of any waher heater that uses a battery. What is it that makes you wonder if there is a battery?
Jan 23, 2018 | Whirlpool Water Heaters
I have a valliant atmo gas water heater and no hot water just the red bulb flashing
Gas (natural or propane) water heaters require electrical power to make the igniter work. The most common source is two (2) D batteries. When the batteries become weak an visual alarm will be visible, such as a red blinking light. Try installing new batteries.
Oct 10, 2016 | Water Water Heaters
Electrical ignitor on Kenmore Hot Water Heater Not Working
The water heater uses a thermocouple to generate a small voltage from the pilot light. This voltage is used to blink the led and allow the main gas jet to turn on. Either your thermocouple or the wiring from it has failed and needs to be replaced, or realigned if perhaps it moved out of position above the pilot light.
Mar 26, 2017 | Rheem 40 Gallon FVR NATGAS Low WATER...
Whirlpool/Honeywell hot water heater light flashes 5 then 7 times and won't light. Burner is clean and all contacts are good. Out of warranted.
Copy following link to troubleshoot by type of gas control valve, including directions for cleaning air intake screen, and or replacing gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
7 flashes: Gas control valve might be bad.
4 flashes: FV overheat, clean air intake.
Soot indicates clogged air intake slowed combustion venting possibly causing overheating and lockout. Clean air intake screen located on bottom of unit.
Apr 17, 2013 | Water Heaters
Turn on gas water heater
Type of water heater, type of gas control valve, symptoms, approximate age of water heater, location of water heater, information from label on side of water heater, things the technician checked, and technician's suggestions are not known.
Copy following link for general troubleshooting by type of gas control valve:
Some of the service manuals are large files and slow to load.
Jul 27, 2012 | Whirlpool Water Heaters
Lowe's hot water heater pilot light will not stay
If it is one of the new ones with the fancy gas control and the blinking light... does the light blink?? or not??
If it is blinking then the pilot should stay lit...
If it will not blink then the sensor is bad or not in the right place...
Or... the gas control is bad... this is happening alot...
If it is brand new... take it back...
heatman101
Sep 05, 2011 | Whirlpool Water Heaters
Red light flashing on hot water tank, no hot water
More information is needed.
Open following link to help identify your gas valve and access error code.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Add a comment and say which gas valve matches.
Then add what code is blinking for possible help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 31, 2011 | Reliance Natural Gas Water Heater Control
No hot water and low pressure
Your manual will tell you what that code means and what repair must be made.
Apr 04, 2009 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Water Heaters Logo
420 people viewed this question
Top Whirlpool Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
jdthefixer
Mike
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
