My Bosch WAE24367 washing machinet
My Bosch WAE24367 washing machine is less than 2 years old.it continues to run even after the time has finished. it show 1 minute left, but still carries on,doesn't stop, had to switch of, but all the water is still in the machine, if i swich it back on and put it to drain it sits there, no fault code comes up. please advise
    Prodigy:
    An expert who has answered 500 questions.
  • Washing Mach... Expert
  • 517 Answers
Check hose from the tub to the exit point you have a blockage
Posted on Jan 02, 2014
catriver
  • 878 Answers
SOURCE: Washing machine stops when there is 19 minutes left!
Jeanna, you are going to have to remove the lower panel and clean the drain pump filter. Easy job, once the panel is removed the filter will be right in front. Get a bucket and unscrew the filter cover and you should find a ton of lint and stuff in there. This model has a pressure switch that detects if there is water in the tub. If so it will do this pause and slow spin. Once the pump filter is clean you should be good...Catriver...post back.
Posted on Oct 19, 2006
SOURCE: Washer not completing cycle
I HAD THE SAME PROBLEM ON A 4 MONTH OLD MACHINE AND I CALLED A SERVICE PERSON. HE SAID THAT I CAN THROW IT AWAY. THIS IS A PROBLEM THAT NOBODY CAN FIX.
Posted on Feb 15, 2007
Noggin
  • 944 Answers
SOURCE: ge washing machine model wip4013srw how to fix the problem
Unidentified buzzing noise in top loader machines is often due to a jammed or seized drain pump, especially if the pump has its own motor - sometimes just opening the front of the pump (usually under a panel at the base of the front, possibly behind a small - 3-4 inch - panel to one side or other) will clear it. behind the pump cover will be a sealed plug or similar, usually needs a half turn to undo. small pieces of wood or plastic sometimes are the cause, and may be "floating" on the drum side of the drain pump so may not be visible immediately. Make sure the machine is unplugged and check with your fingers to see if the pump blades rotate freely - they will have some resistance, but should not feel like you are pressing against something solid. If you still have the manual for the machine, somewhere you would expect to find detailed instructions for a user to clear the pump - it is not usually a difficult or complicated job however some machines have a very different drain system. You may have a certain amount of water comes out over the floor - this is normal. On an optimistic note, many of these machines are still functioning after more than five years with no problems, so it is likely to be minor. If you suspect the electronic control to be the reason for the problem, it may just be that it will not continue a cycle without properly draining, even if the drum appears to be draining adequately - check the drain pump. The pulley attached with string is slightly unusual - perhaps this is as a result of an old bodged repair and needs to be resecured - without more detail or a photo this is hard to say. Best solution for that would be if you could find a similar machine, possibly in a second-hand shop and ask to look at the base to see if there is anything obviously different with your machine.
Posted on Feb 17, 2007
  • 351 Answers
SOURCE: Asko W6461 - will not drain
is the pump comming on look inside the pump with a tourch there may be somthing stuck behind the impeller
Posted on Apr 09, 2008
  • 43 Answers
SOURCE: bosch exxcel 1200 express
need more info what point in the wash does it start to display the code
Posted on Nov 11, 2008
Bosch avantixx front loader leaking underneath machine? machine only 2 years old
  • You will find a small door on the front bottom of the washing machine.
  • Open it.
  • Unscrew the filter and rinse it with running water.
  • Put it back in place and repeat the above steps in reverse order.
This should solve your leakage problem.
Aug 03, 2014 | Bosch Washing Machines
Won't finish the wash cycle
Initially we 1)used less detergent and make sure its marked 'he' . extra soap suds initiates error codes. 2) ran white vinegar with no detergent to clear suds 3) opened, checked and cleared trap.
Everything worked for a time but codes would return or like you would not finish wash cycle until water line in back of machine was made rigid so there was no chance of water or sud backup. So far so good. Good luck.
May 27, 2014 | Bosch Nexxt 300 Series WFMC2201UC
Bosch classixx 1400 express
have you cleared the filter
Feb 03, 2014 | Washing Machines
Wash doesn't progress to rinse and spin
This is one of 3 faults
1 you may have a problem with the heating cycle check element
2 you might have a water valve not working
3 there may be a program fault
These videos on how to change an element and water valve will help
Jul 22, 2013 | Bosch Classixx WFL 2066 Front Load Washer
Machine won't start the wash cycle
All bosch appliances are sold with a two year manufacturers guarantee. Call 0844 872 8999 to arrange an engineer. Sounds like it could be any of the following Heater, PCB, Pressure switch or Motor fault
Mar 24, 2013 | Bosch Washing Machines
2 wks old on a eco wash and after 2 hours still running. is this right?
Hi!
Yes, it is OK, eco wash means less heating energy and less water, but in order to do the dishes clean, it requires more time.
Regards,
Bogdan
Aug 21, 2011 | Bosch Dishwashers
Runs forever! even on Normal wash...help !!
Check to make sure you heating element has not failed. Dishwashers of today heat the water periodically through out the cycle and if the element has failed. The heating delay light is the indicator that tells you that it is trying to heat the water.
Feb 26, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Water continues to fill
you replace 'that'by turning off water going to 'it'remove top of machine,take off hose's on valve,fit them to new valve,with the wireing,do it step by step.buy,eire
Dec 11, 2007 | GE WDSR2080D Top Load Washer
Bosch Excell Dishwasher
drain pump is running all time. cause is a leak. remove bottom front panel and mop out water or can also tilt at 45deg and water shud run out. machine shud then run but you then hav to find leak
Mar 04, 2007 | Bosch 24 in. SHU66C05 Stainless Steel...
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
