Question about Canon imageCLASS D480 Black and White Copier
Fax stops in the middle of scanning
While scanning the document to fax it, the machine just stops scanning and error light lights up. What do I do?
5 Suggested Answers
SOURCE: Scanning and faxing
clean the glass with soft cloth and smallest amount of water, rub hard to get off the small dots that cause the lines even if you can not see any
Posted on Oct 27, 2008
crayzeetrayn
  • 837 Answers
SOURCE: when scanning document stops halfway through ADF
Have you tried lowering the resolution of the scanned document?
Posted on Nov 24, 2008
  • 92 Answers
SOURCE: Canon will not receive faxes or copy documents
see if you have fax line(conect a telefone in the line to see if you have tone) or if the cable is conected.
Posted on Dec 30, 2008
  • 50 Answers
SOURCE: Canon MF4350d wont fax.
Make sur that the settings are set to tone and not pulse. And make sure the phone line is plugged into the one that is marked Line.
Posted on Oct 14, 2009
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Receiving faxes alright, people receiving faxes from us are getting an all black page
Your document scanner has died. Meaning that the row of LED's that light up to scan the documents you are trying to fax are not lighting up. The result is a scanned document that is read as all black. Make a copy....you will get a black sheet because the same process is used to scan the document when making copies.
It might be time for a new fax machine as these machines have become so cheap to buy new that I doubt you could get this machine repaired for what you can just buy a new one for.
Good Luck and Thank You for using Fixya.
Sep 24, 2010 | Brother IntelliFAX 4100 Laser Fax
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
Cannon MP530 scanner won't scan document it shows error code
hello ! reinstall the machine fax and scanner program cd's may be the installation was not completed or is the machine having issues .
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Sent documents are received black
I bet if you make a copy for yourself, the same thing is true.
The scanner bulb (or led array) is dead - meaning there is no light coming on when you scan your originals to send a fax or copy. You would normally be able to see the light(s) light up, if you peek under the auto sheet feeder as your originals are scanning, if not, then it is dead.
Jul 16, 2009 | Sharp UX 340LM Plain Paper Thermal...
Status Code 19
Look in you menus. Your log print out is probably set to on and set to print out way to frequently. You can turn that feature off.
You can go to Xerox.com, click on Support and drivers. In the search box type in 116 then go to support and then type in Log, There should be an answer there as to how to shut off log printing. You cold also type in code 19 when you get to the support page.
May 05, 2009 | Xerox FaxCentre F116 Plain Paper Laser
In Use/Memory Light Will Not Turn Off
That just means you are scanning documents into memory before they are faxed.
Dec 15, 2008 | HP 640 Inkjet Fax Machine
Send Fax Issue
I have a brother intellifax 770 and I bought it used so their for I do not have the owners manual and I am having trouble setting it up and getting it to work. I can fax out but I just can't recieve faxes I can fax my daughter but when she faxes me she gets an error of 388 but she is able to fax and recieve faxes so we know her end is not the problem.
Aug 20, 2008 | Brother IntelliFAX 4100 Laser Fax
Trouble scanning or faxing
yeppers..that's the mechanism under the glass..sounds like either it's stuck or the belt is going bad..service level issue, I'm afraid.
Aug 20, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Faxing/scanning from AIO 964
throw it in the dumpster and buy a new one
Mar 03, 2008 | Dell Photo 964 All-In-One InkJet Printer
Canon imageCLASS D480 Black and White Copier Logo
18 people viewed this question
old marine
old marine
