Question about Polaris Phoenix 200 05 Frame CT New
Drownded motor and wont go forward only backwords
We went through a river and accindentally drownded the motor it turns on fine and it goes backwards but it wont move forwards and we think there is water in the oil
Polaris atv troubleshooting
If you can still go in reverse but not go forwards that means you have a transmission problem
Jan 02, 2014 | ATVs
Why wont my cub cadet 1050 go forward or backwards
the transmission drive belt may have came off.
May 24, 2013 | Cub Cadet Garden
Peg perego train only goes backwards, but doesnt have a reverse and forward button. please help
funny, you can fix this real easily, you just need to flip flop the cables on the motor, currently the polarity is reversed, theres only two wires connected to the motor just switch them around
Apr 19, 2012 | Peg Perego Santa Fe Express Ride On Train
2004 ford escape wont go in reverse Girlfriend got it stuck in the snow then went forward and backwards now only goes forward and reverse when its cold
bad...burned out the trans with the constant slipping, make sure it is not out of fluid, but chances are the trans is toast-sorry
Mar 01, 2011 | 2004 Ford Escape
It wont go in reverse it only goes forward, the steering works fine
Hi
The ESC on this truck comes with a reverse lock out. The reason is that when you're racing, race requirements are that no reverse can be used. Now you may have accidently turned this on. Go to the Traxxas web site and download the ESC manual and follow the instructions for reverse lock out.
May 13, 2010 | Traxxas Stampede Monster Truck Rtrw/Xl 5
Bmw z3 passenger seat goes forward backwards but
It can also be theseat motor since there is seperate motors for up/down & forward/backwards. You can test the switch to see if you are getting power to the connector on the motor by using a multimeter.
If there is power to the motor, I would remove the motor and give it a tap on the ground. Alot of the time the motor is fine, and the tap will free it up again. If it doesn't work you may be up for a new seat motor. Giving mine a tap solved the issue with mine.
Jun 21, 2009 | 1997 BMW Z3 Roadster
94 caravan key wont go forward
I used to own a 93 and sometimes key wouldn't turn forward. While turning key also turn/shake steering wheel. Worked for me as I recall.
Jul 31, 2008 | 2004 Dodge Caravan
Polaris Phoenix 200 05 Frame CT New Logo
22 people viewed this question
Top Polaris Cycling Experts
WTF Chuck.....
WTF Chuck.....
colinat108
Are you a Polaris Cycling Expert? Answer questions, earn points and help others
