Question about Miele Washing Machines
No power Power failure to the whole machine. Machine stopped part-way through a cycle, with no power to any of the controls. Checked the power circuit, checked the socket, checked the fuse, no luck! Any help or suggestions please? Managed to drain the machine and open the door using the 'emergency release', but still no life in the machine.
  • Gooders
    Gooders Jan 02, 2014
    Sorry, this problem relates to a Miele W1716 (6 years old).
  • Gooders
    Gooders Jan 15, 2014
    Thanks aic7, I'll check and feedback when I know any more.
    Problem Solver:
  • 12 Answers
Obviously something electrical. Check for interlock switches - door closed, water overflow, etc. Check for power at the power supply "mains in" and output. Voltage regulator on PS board?
I'm told that these machines are worth repairing and can last 20 years or more with proper maintenance, so they're a good investment.
Sorry I can't be more specific, but I'm just sharing some possible things to search for.
Posted on Jan 15, 2014
Testimonial: "Thanks aic7, I'll look into your solutions and feedback when I have more information."
watugot
  • 290 Answers
SOURCE: Door will not lock to start wash cycl
This sounds like a classic door lock problem. There was a design change in the lock assembly because of numerous problems.
You say you had the door replaced, did they replace the lock assy also?
The control puts power to the wax motor that operates the latch. As the door locks, the latch activates the lock switch that tells the control the door is locked.
What kind of reading are you getting on the lock switch?
Thanks/Mike
Posted on Nov 25, 2007
  • 6 Answers
SOURCE: aeg 72630 update will not rinse during rinse cycle
If the drain lines were plugged, there may have been enough pressure on the pump to fault out. Make sure the sewer line is completely open, as well as the lines at the pump.
Posted on Jan 14, 2008
  • 38 Answers
SOURCE: washing machine DRUM NOT TURNING indesit wdg985w
the lid switch is bad.
Posted on Jun 22, 2008
  • 351 Answers
SOURCE: Asko W6761 Front Loader
check the fuse on the back panel if thats ok check to see where theres power it may be a display board fault.
Posted on Aug 27, 2008
SparkyNZ
  • 43 Answers
SOURCE: Candy Eclipse washing machine blows the circuit breaker
It's possible that the current rating of the MCB is too low to run your washing machine PLUS all the devices plugged into the other sockets on the same circuit. If possible, try plugging in the washing machine on a circuit with fewer or no other appliances plugged in. MCB's are much faster tripping than circuit breakers and are rated to trip at the current rating on them. Circuit breakers, may carry a current slightly over the rated current which may be why it never happened before. The permanent solutions (if the overloaded circuit is the problem) would be to install a circuit solely for the washer and dryer or install a MCB with a higher current rating. The latter solution is not practical, however, since an overload on lower power devices may never reach the current rating of the MCB creating a hazardous shock potential.
Posted on May 11, 2009
I have Bosch model WFB 4000 washing machine. If I start machine in any mode, after going through washing cycle. It stops without draining water.I need help to fix the problem
Some machines have a setting for "drip dry" which stops the drain cycle after rinsing. Check for the wrong setting and hope that is all that is the matter. Use the manual to find out about your model.
You say it stops after washing cycle. Please confirm you mean washing cycle and not rinse cycle (makes a difference to the diagnosis)
Otherwise it could be a pump problem, and that is likely to be (in order) pump motor failed, bad/broken electrical connection to pump motor (an easy fix), controller board relay* failure, other** control board failure.
* It used to be all motors were controlled by electro-mechanical relays, which were in turn actuated by the control board. These days solid state relays are often used. If it is either one of these, an electronics technician will likely be of more use than a washing machine technician because he or she stands a chance of fixing the board rather than replacing the whole thing.
** New board called for. That is a washing machine tech job as an E-tech will find it harder to source the relevant part, and a board fix other than relays is unlikely to be economic.
Dec 28, 2017 | Bosch Washing Machines
Tip
Whirlpool Calypso Washing Machine Error Code Explanations And Repair
Failure - Code Condition - Check/Repair
PF - Power Failure - PF flashes if the washer loses power during a running cycle. The washer does not flash PF when it is first plugged in.
Press START to continue the cycle from the moment that power was lost -OR- Press STOP/CANCEL to clear the display and completely cancel the cycle.
FL - Flood Condition - FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
ER - Processor Reset Error - This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
LF - Long Fill - If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
CE - Communications Error - If there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
  • Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
  • Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
  • Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
  • Drive motor thermal protector has opened.
  • Motor controller is not powered or fuse has opened. Replace motor controller.
LD - Long Drain - LD flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
CA or CL - Average current limit or Instantaneous current limit - If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or CL for instantaneous current limit trip.
  • Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings.
  • Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
OB - Off Balance - If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an OB for Off Balance.
The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load.
SR - Stuck Relay - SR signifies a failure of the relay in the closed position. With this failure, power to the motor controller cannot be turned off by the machine controller.
The machine control board may have a bad relay and may need to be replaced. Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller. This should have AC line voltage when the motor controller is powered.
LS - Lid Switch Error - The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display.
on Jul 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Was doing laundry, machine just stopped. Full of water and clothes. Checked breaker, plugged in.... Will make power up music tone, but no lights on control panel. What to do?
The fact that the machine power up tone is audible indicates that the machine is receiving power which eliminates the fuse problem. I suspect that the main control PC board is faulty.
Apr 18, 2016 | LG WT5001CW 27" Top Load Washer with 5.2...
My washer begin washing but the stop and has the code lp what sim to be the problem?
This are the only codes for your washer. hope this help. WHIRLPOOL Calypso Washing Machine Failure Code Condition Check/Repair "PF" Power Failure "PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle. "FL" Flood Condition "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for "FL" to be displayed
Press STOP/CANCEL to clear the display. "Er" Processor Reset Error This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
Press STOP/CANCEL to clear the display. "LF" Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
Press STOP/CANCEL to clear the display. "CE" Communications Error If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display. "Ld" Long Drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. "CA"
"Cl" Average current limit Or
Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either "CA" for average current limit trip or "Cl" for instantaneous current limit trip.
Press STOP/CANCEL to clear the display "ob" Off Balance If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an "ob" for Off Balance
Press STOP/CANCEL to clear the display. "Sr" Stuck Relay "Sr" signifies a failure of the relay in the closed position. With this failure, power to the motor controller cannot be turned off by the machine controller.
Press STOP/CANCEL to clear the display. "LS" Lid Switch Error The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
Feb 07, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Error code F11
F11 is an indication of a communications problem.
Communications cannot be sent correctly between the machine control board and the motor control board.
Here are some possible causes:
  • Loose wire connection at either the machine control board or motor control board.
  • Machine control board failure
  • Motor control board failure
  • Door lock
  • Motor
Error codes can be caused by a Power Surge or other electrical anomaly, attempt to return the washer to operation by following the Hard Reset procedure below.
In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
  1. Unplug or turn the circuit breaker off for 10-20 minutes.
  2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  3. Press the Pause/Cancel/Stop button twice to clear the display.
  4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Aug 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 11 code
  • Door lock
  • Motor
Jun 17, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore Oasis washing machine is completely dead
discconect power for about 10 minutes,, then plug it back in should fix if not call repair possible control board failure ,,,,,,
Jul 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Machine off balace during washing then stopped working
could be either interface control(pushbuttons and knob) or machine control (gray plastic box)
Jun 01, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Washing Machines Logo
256 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
