Question about Kenmore Microwave Ovens
Microwave oven in a combo unit appears to have no power
Have a Kenmore 911.47813202 combo oven/micro wall unit. The microwave appears to have no power, but the oven works fine. Both units are controlled by a joint keypad area. I have changed out the fuse to the microwave, but not that. Sounds to me like the control board for the microwave needs to be replaced? Any other things you might say to look for??
MicrowaveSvc
  • 9098 Answers
SOURCE: Nothing displays on the control panel, microwave won't turn on.
We repair these control panel assemblies for customers nationwide with our guaranteed $39.95 service.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 24, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Dual Wave II microwave oven blowing fuse
It sounds like a shorted high voltage capacitor, a fairly cheap fix. But if it's good, I would suspect the high voltage transformer.
Here are some links you or a friend can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 06, 2008
najah
  • 180 Answers
SOURCE: Kenmore Micro/Oven fuse keeps blowing
Disconnect the connector to the primary winding of the high voltage transformer. Put a new fuse . If the fuse is not blowing the problem may be in the secondary side of the high voltage transformer. Chek the highvoltage diode, capacitor, magnetron respectively. you can also check the primary winding of the low voltage transformer.
Posted on May 24, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave will not turn on -- light does not come
Chances are good that you have a bad door switch.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on May 28, 2010
  • 25 Answers
SOURCE: Have ge Profile Spacemaker XL1800 Microwave Oven.
Check with the Fixya parts department a Board is fairly inexpensive..other problem may exist
Posted on Jun 21, 2010
Can you remove the microwave separately without removing the complete oven/microwave unit? KEMS307DWH4 KitchenAid Wall Oven/Microwave combo unit
Hello Richard;
My name is Peter. I am a retired field service technician.
Your microwave is in a separate housing than your oven. You need to remove the border stripping holding the micro wave in the wall, then lift up in the front and pull out.
Go into the following website, put in your model number which is on a label after you open the microwave door.
You did not tell me what the problem is. Please advise so I can help you further.
Mar 26, 2016 | Microwave Ovens
Electrolux wall mount micro wave oven combo doesn't work
Good Morning Friend,
I understand that your Electrolux wall mount microwave oven combo is not working. I see that the oven is working, but the microwave is not. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please provide me with the model number of your air conditioner. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Electrolux EI30MH55GS Microwave Oven
How to remove Kenmore Quicktouch micro hood
If it's like most above-the-range microwaves, there will be 2 or 3 screws holding it from above, inside the cabinet
While supporting the unit from below, remove screws.
The rear of the unit is supported by hooking onto a bracket that is screwed to the wall behind it.
The rear needs to be lifted, then the unit should pull away from the wall. Requires some muscle.
Mar 02, 2014 | Kenmore 66469 / 66462 / 66464 Microwave...
Jenn-air combo micro and oven
need to open the unit up and look for a fuse to be blown..
Jan 08, 2014 | Microwave Ovens
Door for oven opens freely now.. im looking for a quik way to fix this issue without taking the whole unit off my wall..... Model # KEMS376BTLO
I am confused as to what issue you are having, this unit is a micro combo and which unit are you having issues with? Micro has a handle for a door release and oven has a pull door handle. Please get back to me with more information so I can assist you.
Also Model number is KEMS376 ------- starts with S or T
Nov 02, 2013 | Microwave Ovens
Jennair combo micro wall oven 30" replace microwave?
When a microwave is dead, the most common causes are a blown fuse, or a blown thermostat / thermal cutout / TCO on the magnetron or on top of the oven cavity.
Accessing the oven cavity thermostat for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Jenn-Air (Whirlpool) owner's manuals and installation instructions here.
Dec 25, 2012 | Jenn-Air JMC8130DD Microwave Oven
My JennAir M170 just quit working, nothing.........bought in 1998. Time for a new one? If so, how do I go about just getting the micro for the combo unit? Or do I have to buy an whole new combo unit?
I would at least have a service tech look at it. Here are the comon items to check most of the time when a microwave just quits. 1 the internal fuse. 2 the power diode 3 the large capacitor 4. door open / closed micro-switches 5 the magnetron. The least likely suspect is the control panel yet can also cause the problem. You should still be able to keep this unit in service cost effectively. Until I had it checked out I would not give up on it.
Jan 09, 2010 | Jenn-Air M170 Microwave Oven
How do you un-install a kenmore 665.61639100 microwave?
the link below will take you to the installation instructions if needed.
It is much easier for two people to remove the microhood. If attempting alone, please move the range out so you can get under the micro to support the weight. If the range stays in place, protect the top from damage.
1. make a landing site to the side to protect the floor when putting the micro down after removal.
2. Disconnect the power cord in the cabinet above.
3. loosen the two screws in the bottom front corners of the cabinet above. When removed the front of the micro will drop, be ready for the weight. Busy times, tools in hands microwave coming down in front.
4. tilt the front down. pull the cord out of the upper cabinet.
5. with micro still tilted down in front, lift the back of the unit upward to free it from the wall plate.
6. remove the fasteners in the wall plate and remove.
Congrats, begin celebration.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0211226.pdf
Dec 26, 2009 | Kenmore 62642 / 62644 / 62649 Microwave...
Micro 6654438991 power surge from pole, light works, panel dead
Sounds like you should get estimates and turn in on homeowners insurance. Power surges are very destructive and you have lost the control board at least and maybe some switches. Eric
Aug 08, 2009 | Whirlpool GH7145XF Microwave Oven
No heating or power to microwave oven
You have a fuse in the back that's problem is blown
Mar 13, 2009 | Microwave Ovens
Microwave Ovens Logo
89 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
