Question about NAD T748 Home theater receiver with 3D-ready HDMI switching
Nad T748 Willy not start! power protection lights up! Then shut off! Help?
How do i eliminate amp protection. Unit goes no further. Tried to unplug the unit & plugged back in but problem persists. Please HELP!!!!!
This is a very ambiguous post. When you say that you are having this problem, what are you doing? Please post all the steps that lead to this error. There is no way to disable the amplifier protection circuit. If it senses a short (which could be a bad speaker) then it will be activated.
Dec 12, 2014 | NAD T748 Home theater receiver with...
My NAD T748 shows the message "AMP protection powering off" on startup. The device has not overheated, since it doesn't feel warm. So now, I can no longer turn it on. I've also tried disconnecting power...
Check your speakers and cabling. Perhaps one of the cables has a shortage (mice like to eat cables or cats). Or a speaker is blown.
Eventualy disconnect both speakers before you switch on. If it does not go in protection, connect one speaker and switch on again. Look what speaker, when connected will drive the amplifier in protection.
Jul 11, 2014 | Audio Players & Recorders
Factory reset
I have the same question.
Dec 07, 2013 | NAD Audio Players & Recorders
Will the NAD T748 drive the bose 901 speakers?
Yes, the Bose user manual
http://worldwide.bose.com/axa/assets/pdf/owner_guides/StereoSpeakers/901vi_guide.pdf
says that any amp with 10-450 WRMS is OK. The speakers impedance is given as 8 ohms, so the amp is compatible.
Note that Bose say you have to have the Bose equalizer connected as well.
Sep 04, 2013 | NAD T748 Home theater receiver with...
I've bought my NAD C326BEE amplifier almost two years ago, and i got promised a hell of a good quality and that it would last for YEARS. But ever since i bought the damn amplifier, it has been shutting off...
I'm also a Nad fan. I find this pretty odd that you should loose two in such a short space of time. The cutting out is due to the "protection circuit". I would be inclined to get your speakers checked out as if they are faulty or not "matched" to the amp, it will trigger the amp to "protect itself" and shut off.
Jan 07, 2011 | NAD C326BEE Amplifier
Hello i own NAD 3150, its not working, all the indicator lights ( power, protection and soft clipping glows)
HI...
It's either failed power supply capacitors or one or more power transistors in the output amp have gone bad
Oct 05, 2010 | NAD Audio Players & Recorders
Nad c372 prob
The unit is detecting a problem and shutting down in what is usually called "protect" mode. Look for bad connections on the board near the voltage regulators.
Dan
Sep 05, 2008 | NAD C372 Amplifier
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
NAD T748 Home theater receiver with 3D-ready HDMI switching Logo
473 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
