Question about Nokia Cell Phones
Nokia 206 probleme 006
Can not access to the service center, please check the connection
Message center number
Message Center Number doesn't belong to any Handset Manufacturer as you mentioned Nokia, but to Network Provider. Different Network Providers have different Numbers. Contact your Cellular Network company's Customer Care and they'll help you with this. (To make it more clear I mention some Popular Cellular Service Providers : Vodafone, Airtel, Idea, Tata Docomo, Reliance, Aircel, MTS, BSNL, MTNL etc.). If you don't know your Company's Customer Care Number, you may just visit their Website or Local Office.
Mar 29, 2014 | Nokia WH-206 Headset - black NOKIA
Device\NTPNP_PCI0027
Troubleshooting :
Cannot access internet in OS using onboard network card bg-country_outline_top.png bg-country_outline_bottom.png Solution
1. Please check the LAN settings in BIOS.
2. Install a fresh OS and the motherboard driver, network card driver in support CD or downloaded from official website.
3. If the network card is not recognized in Device Manager, please contact reseller (service center) for tests.
4. If the network card is recognized in Device Manager, please do some troubleshooting as the following steps:
4.1. If there is yellow question mark or exclamation mark before the network card, please re-install OS and drivers. If the problem persists, please contact reseller (service center) for tests.
4.2. If there is no yellow question mark or exclamation mark before the network card, but in Control Panel/Network Connections/Local Area Connection, the network cable is shown as "un-plugged(X)", please check network cable/router/switch/modem/other network peripherals and network port, or plug network cable to other system for test. If the problem persists, use another computer in the same network environment to check if it can access internet. If the network is not connected to internet, please connect ISP and network peripheral reseller or change network cable.
4.3. If there is no yellow question mark or exclamation mark before the network card, but in Control Panel/Network Connections/Local Area Connection is disabled (grey), please enable(right click and choose "Enable") it for a test. If the problem persists, please turn off firewall, search and kill virus, reinstall OS and drivers. If the problem still exists, please contact reseller (service center) for tests.
4.4. If there is no yellow question mark or exclamation mark before the network card, but in Control Panel/Network Connections/Local Area Connection is shown as "Limited or no connectivity" (yellow exclamation mark)", please do some troubleshooting as the following steps:
4.4.1. Right click and choose "repair"
4.4.2. Unplug and re-plug the network cable
4.4.3. Re-connect the network or access IP
4.4.4. Restart
4.4.5. Check server DHCP settings, IP configuration, seek advice from ISP
4.4.6. Skip router and connected to Modem directly
4.4.7. Turn off other computers in the same network to avoid IP conflict
4.5. If there is no yellow question mark or exclamation mark before the network card, and there is no abnormal situation in Control Panel/Network Connections/Local Area Connection, please do some troubleshooting as the following steps:
4.5.1. Try to access IP or Static IP automatically
4.5.2. Unplug and re-plug the network cable
4.5.3. Re-connect the network or access IP
4.5.4. Restart
4.5.5. Check server DHCP settings, IP configuration, seek advice from ISP
4.5.6. Turn off firewall, search and kill the virus, reinstall OS and drivers
4.5.7. Check MAC address ( You could follow the commands: " Start"-" All Programs"-" Run", please input " cmd", after that you could input " ipconfig/all" to check MAC address)
4.5.8. If possible, use another computer in the same network environment to check if it can access internet
a. If the network connection is OK in another system, please contact reseller (service center) for tests
b. If the network is not connected to internet, please connect ISP and network peripheral reseller or change network cable
Mar 03, 2014 | ASUS SABERTOOTH Z77 LGA1155/ IntelZ77/...
How to export contacts to a Nokia 206
Its possible
go to settings>configuration>personal>add new>synch>
account name: google
server addr: https://m.google.com/syncml
use ur gmail user name and password in all username and password area.
Access point: pop.gmail.com
Done<
then goto sync & backup >synch>sync now.
Jan 09, 2014 | Nokia New Factory Unlocked 206 Dual Sim...
Unlock security code for nokia 206
The default Nokia security code is 12345 unless it was changed.
Mar 10, 2013 | Cell Phones
Nokia 206 ringer problem
salam sir mere pass nokia 206 ki first copy hai chaina main mainy oska ringer change kiya tha lekin phr bi koi farq nahe para mujhe ringer solution btay ringer main sirsarat a rahi hai
Feb 28, 2013 | Nokia WH-206 Headset - black NOKIA
Can't hear callers unless speakerphone is turned on on nokia 6110
Hi.
There is Calling Speaker Problem To solve this Please Replace the Calling Speaker.
Some time there is Strip Problem also which is connected to your Calling Speaker
In Nokia 6610 Navigator there are two Type of Strip one is Connected to the main to your display and other one is connected to front slide there may be problem with Front slid Strip replace this strip it will get Resolved. If your a Mobile technician then only do this.
If your not a Mobile Technician then Please Visit your nearest Nokia Service Center (Nokia Care) or Visit Any Mobile Repair Center they will do it carefully & they they can do it perfectly.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up &
Testimonials //
Jun 27, 2011 | Nokia 6110 Navigator Cell Phone
I am not access internet from my noka e5. packet data not available, check network service
Please Check GPRS Settings if you dont have GPRS settings then Please Call customer care (Service provider) & Ask for GPRS Settings They will provide you the settings you just save it as defult it will get solved.
If not then Please Visit your nearest Nokia Service center (Nokia care) they will solve this.
Regards,
Harish
Testimonials //
Jun 24, 2011 | Nokia E5 Cell Phone
Unlock code of nokia 6070
#pw+104 684 123 206 006+7#
only enter code once`
May 16, 2011 | Nokia Cell Phones
Desperately need to unlock the Nokia 6103b
Model: Nokia (6103 )
IMEI: 352269013999755
Network: 31020000
#pw+304 006 421 220 322+1#
#pw+389 206 107 732 726+2#
#pw+493 547 112 135 063+3#
#pw+924 542 741 265 365+4#
#pw+258 195 773 621 012+5#
#pw+383 246 100 132 664+6#
#pw+135 254 651 352 574+7#
Jul 10, 2008 | Nokia 6103 Cellular Phone
Cell Phones Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
