Question about Zebra 105SL Thermal Label Printer
Printer is jammed
The printer will not feed, the wheels appear to be locked up. It makes a loud sound like it is stuck.
Paper jams and would not feed
Follow this link to get possible solution: https://h10025.www1.hp.com/ewfrf/wc/document?docname=bud04237&tmp_task=solveCategory&lc=en&dlc=fr&cc=us&product=58720
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Jan 22, 2013 | Epson Stylus T10
Making loud noise ml1650 printer jam paper feed paper feed problem paper jam
Pull out a paper cassette and under you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol
Nov 21, 2010 | Samsung ML1650 Printer
As soon as you press print it acts like it's going to work then the wheel makes a sound and it stops, like the wheel is locked up or something. It says printer error. Remove back access and unjam the...
That usually means that the paper feed rollers are not pushing the paper into the printer. Take a paper towel and some isopropyl alcohol and clean the rubber rollers were the paper is set and feed into the machine.
Aug 25, 2010 | Office Equipment & Supplies
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Clear the jammed paper as follows.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
4. Close the front cover.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
Paper jams after printing and will not exit top output tray
sounds like the gear drive assy faulty.take it back to where you purchased.Samsung should cover under warranty.
May 25, 2009 | Samsung ML-2510 Laser Printer
PAPER JAM
The problem sounds like your rollers have lost their grip. Remove the paper tray and tip the printer up. Push the red lever on the left of the printer down and you will see the feed mechanism with two wheels. Remove the rubbers on the wheels and turn them inside out. Replace them on the wheels with the worn side now inside and the 'sticky" side out. You should get at least another couple of years worth of use before you need to replace them.
Aug 22, 2008 | Lexmark E232 Laser Printer
HP C3150 Printer Continuing Paper Jam Errors
Sometime the ink jet mechnism is out of time or it gets stuck in the lock position. You might want to see if it looks like there crooked in the trays at the end of the printer.
Jul 04, 2008 | HP Photosmart C3150 Printer
Paper feed
Hi there.
First of all pull out the paper jam cover - is behind the printer with a clock-like handle. Pull it out and check for any paper or other objects. If U dont see anything try to manualy rotate the black rubber rollers and check for that noise. Locate it and try to describe what you see.
Jun 28, 2008 | HP PSC 2175 All-In-One InkJet Printer
Paper jam
it maybe one of the feed wheels are jammed, if you can get it apart then have a look at the gears and wheels, there maybe something jamming the wheel itself.
Feb 11, 2008 | Canon PIXMA iP1800 Printer
Error E
Kind of sounds like it. Make sure that there isn't a little piece of paper stuck in there where the paper feeds in. Have seen that happen before. If nothing else try pressing reset button on bottom or machine and see if that helps.
Nov 18, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Zebra 105SL Thermal Label Printer Logo
22 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
