Question about Digital Audio 2000 WATTS HIGH CURRENT AMPLIFIER DHC2154 Car Audio Amplifier
Want to connect to older turntable. Does it have to plug into electrical outlet?
Model:da 2012-7.1 I want to hook this loudspeaker to an older turntable. The loudspeaker has two brass jacks in the back (-) & (+). Does it have to plug into an electrical outlet? How do I connect it to my turntable? What types of cables do I need?
2 Suggested Answers
simplemitch
  • 752 Answers
SOURCE: LCD HDTV digital audio output jack
The orange jack is a DIGITAL audio out and cannot be hooked to anything other than a digital input. You want to use the White/Red jacks at the bottom.
Posted on Sep 12, 2007
My record turntable does not turn on.
likely a belt issue if belt drive (slipped or broken)
Is it belt or direct drive? It should say somewhere on it
Sep 20, 2014 | Audio Players & Recorders
Why does Panasonic nn-sn651 usually work; but sometimes, turntable won't start ?
This is an inverter model so there is no diode or hv capacitor.
You must adt. the door latch switch assembly to make sure that the door hooks make contact with the switches. Common problem is that the assembly is bent and must be perpendicular to the door.If it is bent the switch will not make contact with the door hooks.
Place a dab of lithium grease on the tip of the door hooks to ease closing the door. This is the cause of the bent switch assembly!
Aug 31, 2014 | Panasonic 1.2 Cu. Ft. Mid-Size Microwave -...
I dont have the orginal ground wire for my Technics SL-BD20D turntable someone told me i could use rca cables to ground it, i have a pre amp cause my main amp didnt have phono jacks on the back of it.
You don't need the original ground wire for Technics SL-BD20D turntable,
any plain cable can be used for this purpose...
you should connect turntable to your pre amp,should be a "phone" input at the back...
here are some suggestions for grounding....
  • Plug in a surge protector to the outlet, and then plug all the components into that surge protector
  • Connect a ground plug to the surge protector and then plug the ground plug into the main outlet. A ground plug is available at any hardware store, and turns a three prong connection into a two prong. Ground plugs help eliminate 60 cycle hum.
  • Connect the ground wire from your turntable to the ground wire connection on the receiver. If this doesn't work, looking on the back there should be a grounding point,
    Unplug your receiver.. Split a wire and attach one of the splits to the receiver where you will see the text, "ground" or something similar. Attach the other end to something metal such as a pipe that goes into the ground. Secure with electrical tape. Plug in.
    connect the ground wire to a screw on the electrical outlet.
    Take care and please Remember to rate/vote and give me 4 Thumbs Up
    for Helping out the Community :)
    Hope this helps!
    Jun 22, 2011 | Technics SL-BD20D Turntable
    I have an older model Harman Kardon AVR and have started hearing humming from the speakers that are attached to it. Is my receiver going bad or is there something else I need to do to fix this problem?
    you may have a bad Earth power 110 V AC cable connection which makes such hum / buzz even nothing connected..
    Check the connections between components and make sure they are secure before proceeding to the next Step. Sometimes, loose connections can cause a hum.
  • Separate the audio cables from the power cables; electromagnetic interference from the power cables can cause stereo hum. Use cable ties to secure the audio cables away from the power cables.
  • 5 Connect the ground wire from your turntable to the ground wire connection on the receiver. If this doesn't work, looking on the back there should be a grounding point,
    Read more: How to Fix a Hum on a Stereo Receiver ' eHow.com http://www.ehow.com/how_5183193_fix-hum-stereo-receiver.html#ixzz1PpFHs1Mv
    Take care and please remember to rate "AS THUMBS UP" Thanks
  • Jun 20, 2011 | Harman Kardon AVR 85
    I have a Pioneer VSX-515 6.1 system and I am trying to hook up my phono to it. I am not sure which input to use. Right now the only input I have is my CD player.
    Like many newer receivers, this model doesn't have a phono input. I guess manufacturers think nobody listens to vinyl today. You can still hook a turntable to one of the extra audio inputs on this unit, but you'll need a phono preamp. The output level from the turntable is too low to drive a "line level" input directly, and the preamp boosts and equalizes the signal so it will work properly. Radio Shack still carries a preamp; you can order online or find it in some of their stores. Many other sources are available online, and if you have a good stereo shop in your area they probably stock one. Plug the turntable to the preamp input, connect the preamp output to the receiver and that's it. You'll also need an AC outlet nearby as the preamp needs power.
    Mar 21, 2011 | Audio Players & Recorders
    Will I be able to hook up a turntable to this?
    no/ turn tables dont have passive sound output unlike dvd players they need a connection that is 200% more powerfull than an dvd input the only and cheapest way to fix this problem is to buy a cheap audio mixer plug the turntable into the phono of the mixer and the mixer ouput into the video input and it will work great need more advice feel free to email me
    good luck
    Jun 25, 2010 | KLH R5100 Receiver
    The dryer has a four prong male plug and the outlet is a three prong female - which do I change? the dryer cord is the easiest, but how do I connect the leads?
    4 PRONG PLUG WIRING: 2 HOTS(RED&BLACK) 1 NEUTRAL(WHITE) 1 GROUND(GREEN). 3 PRONG PLUG WIRING: 2 HOTS&1 NEUTRAL. YOU MUST USE 2 HOTS & 1 NEUTRAL ON A 3 WIRE PLUG. THE GROUND WIRE(GREEN) WHICH IS HOOKED TO FRAME OF THE DRYER IS NOT USED ON OLDER 3 WIRE PLUGS. IT IS AN ADDITIONAL SAFTEY GROUND ON NEWER MODEL 4 WIRE PLUGS.
    Dec 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
    Im getting loads of feedback through my speakers from my turntables but i havent got a ground wire is that the problem
    HELLO
    This problem is usually caused by the turntable(s) being too near the loudspeakers - a sort of "howlround" effect if you like.
    Make sure that the speakers are as far away as possible from the decks and that your cartridges are set up correctly too. On the back of the turntables, there should be a connection for a ground wire, but that should have nothing to do with this situation.
    Hope this has helped, and good luck! (:-)
    Sep 27, 2009 | Numark TT200 Turntable
    Buzz coming from speakers on phono input
    is the wire loose on either end? sometimes the electrical plugs can cause noise due to resistance, so trying different outlets might help too
    Jun 21, 2009 | Technics SL-BD20D Turntable
    Mitsubishi rear projection TV , Model VS-45603.In the last year it started to turn off by itself. It has no real pattern. It can turn off 2-3 times one day and none the next day. It is hooked up with...
    What kind of cable are you using to connect it with (coax, HDMI, RCA (composite), component, s-video)?
    This may be a grounding problem. Either the cable from the satellite dish is grounded to something with a little electricity running through it or you may have a hot ground in your electrical outlet. Or the cable may be on a different ground than your electrical outlet and by connecting the two it has created a slight electrical current. You can try using a plug adaptor to remove your receiver from the electrical outlet ground. These adaptors are meant for older homes and electrical outlets that do not have a third hole or ground plug. The outer metal part of all video connectors is the ground and this may be causing the tv to act strangely.
    I hope this works.
    Apr 24, 2009 | Televison & Video
    Car Audio & Video Logo
    88 people viewed this question
    Top Digital Audio Car Audio & Video Experts
    Joe Ankney
    Level 1 Expert
    Matthew Spark
    Matthew Spark
    Tom Chichester
    Are you a Digital Audio Car Audio and Video Expert? Answer questions, earn points and help others
