Question about Canon Office Equipment & Supplies
Paper jams at heater section in ir4570 in A4, A4R is OK for some time. replaced film but problem not solved. require original fixing film for ir4570 part number
  • shailendra panchal Nov 21, 2012
    my canonir4570 isruning perfectly problam scanining first tray peaper margin2inch
    President:
  • 1,126 Answers
Depending on your voltage requirements; Fixing Film Unit FM2-1793-010 120V FM2-1812-010 230V FM2-1792-020 100V These numbers fit iR4570 and iR3570.
Posted on Jun 15, 2009
Use the selicone oil on heating element
Posted on Mar 05, 2015
How to fix id card fuction
first entered in SPECIALFETURES then
IMAGE COMBINATION then (Machine Ask Original Paper Size)
Select A5R (if the LTR Size Show tuch the AB botton)
Select 2 on one then select A4 paper tray
Then Screen Show Special features
DO NOT TOUCH RESET or Any botton
touch MODE MEMORY select M1 touch STORE then done then OK
Press the Additional Function Bottoan
touch Copy Setting
touch Standred key 1 setting
(in this Window show many botton)
choose modememory Select M1 Select OK
afterthat your home screen show M1 on Bottem Left corner when you touch ID CARD COPY Feature activate Scan 2 Time Front /back Print on Combind one Side Enjoy!!!!
Feb 25, 2015 | Canon ImageRunner 4570 | IR4570 |
Canon ir 4570 paper jaming in heater section what can i do
check your outlet delivery guide or whether your fuser film rotation
Nov 05, 2014 | Canon ImageRunner 4570 | IR4570 |
TOSHIBA ESTUDIO 455,PAPER GETS C FOLD FROM TRAY 2 IN A4R AND GETS JAM IN A4,BUT FROM BYPASS & FIRST TRAY A4R & A4 OK,EXCHANGED FEED ASSEMBLY,FEED CLUTCHES,REGISTRATION CLUTCH EVEN COMPLETE DUPLEX...
Try looking for distorted paper guides and trace the paper passages for any disposition or maybe foreign object stuck on it. try shuffle the papers too.
Apr 17, 2013 | Office Equipment & Supplies
Hi guru, my canon ir4570 had E000110-0001, should I replace the laser unit? and sometimes when copier is ready to scan, immediately had error E0000007-0000 and the paper position is jamm under the fixing,...
code 110 is for laser polygon motor you should replace the unit. for problem 007- check fixing film if it is ok then open the unit and take out fuser film apply mixture of some white grease and fuser oil(silicon oil) and put back the film and unit.hope this helps you.
Jan 24, 2011 | Office Equipment & Supplies
The machine (display ) says system error e007 i dont know how to solve the problems, because every morning if i need to make a copy let say after may be three times working the message come and machine not...
You have problem with fixing film in fixing(heater)unit. The fixing film have small "white" section which is there for fixing film rotation detection.
By the problem, I would say that the withe section is + / - OK but the problem is worn out other end, and the film "dance" on the heater, so you can get few copies but when the film moves away from sensor it reports E007.
There is only one solution replace fixing film.
Hope that helps!
Dec 28, 2010 | Canon ImageRunner 2016 Copier
Canon ir4570 always jam at fuser
To properly solve the jam, you would have to start taking apart the machine, take the fuser out and inspect the paper path, a service manual would be helpful as the machines paper path in most cases is very complex, there are alot of moving parts in the path.
there is possibly a small piece of paper in the path, stuck in a gear or something similar, or a part is out of place or there is something in the path that doesn't belong there.
Aug 15, 2010 | Canon Office Equipment & Supplies
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Paper pick up problem
hi,try to clean feed rolls,sensors.clear any misfeed sheet from paper supply area.send me a result.
thank you.
Jun 01, 2009 | Canon NP 6050 Copier
760 people viewed this question
old marine
old marine
