Haier Tv no sound
I have an L32A2120 LCD TV and the sound isn't working, but I can see the picture. And it isn't with one channel, it's with all of them and I check to see if the audio is on SAP and it wasn't. Please help.
  • Televison & ... Master
  • 9,845 Answers
Check the setup menu to see if the audio isn't sent to the external audio jacks or the fiber port. Could be something as simple as having the volume muted too.
Posted on Jan 06, 2014
4 Suggested Answers
SOURCE: Haier TV model 42HP25BAT
I have the Haier plasma..Model # 42EP24S and as others it has went to a black screen with only audio...Is there something I can do to fix this....Thank you for all help. Alison
Posted on May 05, 2008
  • 57 Answers
SOURCE: Insignia TV no audio on non HD channels via HDMI cable.
have you tried to change the audio settings to HDMI on tv? when u have HDMI hookd up u have to change the audio to HDMI also
Posted on May 31, 2009
rons_dear
SOURCE: TCL LCD TV L24D10F Channel locked; need password
how to upgrade my tcl lcd tv l24d10f? can u give me a firmware?
Posted on Jan 02, 2012
Haier L32A2120 flat panel Keeps channeling and does not stop when using remote
Sounds like main system control memory IC is faulty. Anyway, do a reset to this set and check. It it too do not help, replace the memory IC
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Aug 23, 2014 | Haier L32d1120 32" 720p Lcd Tv - Hdtv Usb...
Sound but no picture
Contact any service technician. This is a very very bad symptom with LCD TVs.
Jul 30, 2014 | Haier HL26P2 26" LCD TV
Haier LCD picture goes dark, sound only
hi, since your TV is under warranty,It is better to ask for a replacement a new one ..the problem is factory defect.
Apr 02, 2012 | Haier HL15R LCD TV
AOC A15X221 have picture no sound
Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Nov 20, 2011 | AOC A15X221 15 in. LCD Television
No sounds, no picture on tv but cable menu shows on tv and i can change channels
contact your product provider and tell them the problem.. thank you and have a nice day. . .
Apr 30, 2011 | Haier HL32LE2 32" LCD TV
I turn my tv on and I get a white screen on top I have the Haier logo plus multimedia player and on the left side of the screen I have device with a picture of a usb cord underneath I have it says copy...
The tv Tuner signal board have problems.Tries tv and all devices attached to it unplug,replug all back about an hour later.By resetting itself back to factory,the tv should work again now.If have the same problems,than the tv Tuner signal board require replacing.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 27, 2010 | Haier HL42XD2 42 in LCD TV
MODEL HLC 22 R TV/DVD COMBO
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires.Switch input mode Vitally
Mar 26, 2009 | Haier HLC19R 19 in. LCD TV/DVD Combo
Haier 26; TV Tuner
contact the Haier Service center in NY. www.asnyonline.com
May 25, 2008 | Haier HL32BG 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
