Question about Dell Computers & Internet
My monitor won't turn on?
My 17" flat panel monitor died for no apparent reason. It won't turn on. I've tried plugging it into different outlets, but there is no sign of life...no lights on the display or anything. It was originally plugged into my surge protector. Do you know what could be wrong with it??? Is it an electrical problem? What should I do?
I'd appreciate any help. Thanks. i have a dell monitor that just wont turn on. theres nothing wrong with the wires. there is just no sign of life. it has been like this since a power cut. could this be the problem and is there anyway to fix this?
  • Dell Master
  • 19,396 Answers
If there is no power at all then it is either the power cable or the power supply board inside the monitor.
The part must be tested before replacement.
Posted on May 21, 2009
Mine did the same. Took it apart. Found three blow capacitors on the power supply board. Went to Radio Shak and bought 3 Capacitors (not the exact same ones 35V 1000 microF instead of the original 10V 1000 microF), installed them and now it works great.
Posted on Feb 05, 2011
How do i factory reset my NEC LCD1712 Monitor?
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 22, 2014 | NEC LCD1712 17" Flat Panel LCD Monitor
Sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
Sep 22, 2012 | Sharp AQUOS LC-22SB28UT 22" LCD TV
Digitalstream LCD HDTV won't turn on
Did you try it on a different power outlet? Have you made sure that the voltage setting is selected correctly?
Aug 21, 2012 | Televison & Video
Daughter unplugged tv without turning it off first. Now, it won't turn back on from the remote or the monitor panel on the front of the tv. It's a Samsung 1080 LCD. Only 6 months old. I've...
hi if you have at least a basic knowledge in repairing in any electronics as my recommendations, since the problem is won't power on.first you need to open the back cover with the use of philip screw driver then start to check the power supply look for the blown fuse replaced with the same amper rated at the part. then check for any burnt or bulged capacitors. also considered the inverter ballast board if their is no burnt connectors or parts. good luck hope it will help you.
Jul 14, 2011 | Televison & Video
Monitor shuts off
Is the monitor light turning off, indicating the monitor is turning off? Or is the monitor/computer going to sleep?
How do you get the monitor to turn back on?
Verify the power cord is securely plugged into both the monitor and the outlet.
Try a different outlet.
Mar 12, 2011 | ViewSonic VX715 17" LCD Monitor
I have a GEM 17" with power issues!
Sounds like your power supply capacitors are causing the power supply to shut down. Or you have a short in the monitor loading the power supply. You should try a different power supply.
Monitor Mike
Apr 24, 2010 | Scanport GEM GL-821A/B 17" Flat Panel LCD...
Monitor setting panel on permenantly
mrjk65, If monitor still has bright, crisp images displayed on the LCD panel your monitor could be worth saving! Unplug unit from wall outlet and plug it back in! If same problem occurs then most likely problem could be a DC voltage is slightly "out of spec" or a settings panel push switch may have failed. My guess is that when STRANGE out of the BLUE things start to happen for no reason, I would suspect the "switch-mode-power-supply" to be the item at FAULT. Visit YOUTUBE for vids of "LCD monitor disassembly" , "LCD monitor repair" . You will be glad you did. Also try www.ccl-la.com/badcaps.htm , www.lcdparts.net , www.badcaps.net for more info. hope this helps. Bye for now. 12fixlouie.
Nov 08, 2009 | Planar PL1700 17" Flat Panel LCD Monitor
There is no power. is there a reset or fuse to look for
No. Try a different power-cable. Try a different wall-outlet.
Is the monitor still under Dell's warranty?
Aug 13, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
My Dell E172FPb flickers & has straight, thin
#1 Connect monitor to another system, make sure the issue is the Monitor, not the video card.
#2 Try a different VGA or DVI cable
If the issue is isolated to the monitor, it is cheaper to replace it than to repair it (Refurb 17" LCDs are $69 on Dell's Outlet
Jul 02, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
i had the same problem i bought two of those exact same monitors, and both died at the same time because the were in the same room, the temperture in the room was to hot and the monitors stayed on all day also very humid it was a small secluded room,the solution is a bit simple if you are up for the work. if your not tech savvy then maybe you can take to to someone and ask them to repair it for you the problem is that the capicitors on the powersupply board erupt bad capacitors due to the heat or most likely the humidity so all you need to do is replace the capcitors which cost about 55 cents you can buy it here https://www.electronix.com the exact one would be the 470 uf 125v capacitors there are about 6 of them on the board and not all of them died for me i only had to replace 3 and you should be good to go. you can email me if your in NYC and you want someone to do it for you my fee is $100 for my time
saturn14@hotmail.com
what
Nov 07, 2007 | Mag Innovision LT782S 17" Flat Panel LCD...
Computers & Internet Logo
320 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
