Question about Water Heaters
Vokera compact 25hd blowing fuses - Water Heaters
Vokera boiler problem
If it is a gas unit, I am not familiar with that unit, I would get a qualified tec, it sounds like the gas is lightning late and the explosion you hear is real. Sorry I cannot offer more help.
Apr 28, 2014 | Water Heaters
Vokera boiler problems
Check internal fuse un main circut board
Sep 29, 2013 | Water Heaters
Hatco c-9 booster heater won't heat, 1 amp fuse keeps blowing
that is in the control cicut the contactor might be bad and taking out cntrl fuse.unhook contactor control voltage by unplugging from contactor tape off the two wires put new fuse in turn on power if fuse does not blow replace contactor.if it does blow you will have to isolate the next thing in the control circut maybe the light.you can buy resetable 1amp circut breakers at grainger for test purposes.sometimes on people I know I will wire in those breakers for them no more buying fuses.
Apr 11, 2011 | Hatco Corporation Compact Electric Booster...
I have a vokera unica 28 which pulses when firing
your fan may need attension fan runs after boiler shuts down is normal on some Vokera,s too clear fumes out the flue 2mins approx
Oct 04, 2009 | Water Heaters
Low hot water pressure .have A VOKERA MYNUTE HEATER
Sounds like you have debris that is caught in the line or calcium buildup that is blocking the line.
Apr 09, 2009 | ACCO Brands Water Heaters
Vokera mynute 14se lockout reset button on
Has the boiler cool down? Try turn the power off for a few minutes and see if that will work.
Mar 14, 2009 | Water Heaters
Water Heaters Logo
11 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
