Heater control diagram
Only cold air
blueextc3221
  • 15935 Answers
SOURCE: 1986 VW Golf heater blows cold air
The heater in your car depends upon a flow of hot coolant going through the heater core in order to get hot air into the car. If the heater core is partially plugged, it will restrict the flow. If you have a head gasket that is putting exhaust into the cooling system, it will eventually get into the heater core. When this happens there is no coolant in the heater core to make the air warm. If the water pump vanes have corroded away the result will be very poor coolant circulation causing the heater to not blow hot air. If your car is equipped with a heater control valve that is not functioning properly, the coolant flow will be restricted. One or a combination of these factors is likely the culprit in your case.
if the car is not overheating, the thermostat is working fine.... replace or flush the heater core multiple times to try and eliminate sediment build-up.
Posted on Jan 14, 2009
mrgreenz
  • 962 Answers
SOURCE: 1992 es 300 lexus heater is blowing cold
. Yes it could. some are vacuum powered, cable powered (mechanically) or electric powered. If the valve does not open. The hot water will not get to the heater core. It could also be the thermostat not opening.
Posted on Jan 20, 2009
  • 65 Answers
SOURCE: heater blowing cold air
Low fluid or bad therostat if it does it when engine is warmed up.Heater control valve replaced or mixing valve? If so you have a vacuum hose disconected
Posted on Oct 31, 2009
  • 192 Answers
SOURCE: the heater does not blow hot air just cold air all
The first thing to check is the coolant (antifreeze) level in your radiator. If this level is too low it could cause your heater not to blow hot air. Check this when the engine is cold by removing the radiator cap. Do not remove the radiator cap when the engine is hot. If you do, you run the risk of getting scalded by hot water and steam that can shoot out the top of the radiator. The radiator should be completely full. If it's not, fill it up with a 50/50 solution of antifreeze and water. Also make sure the radiator overflow tank is filled up to the full mark. This is usually about halfway up the tank.
If your coolant level is ok I suspect you may need to replace the thermostat. It may be sticking shut and not letting hot water get to your heater core, or it may be sticking open and preventing your engine from reaching its normal hot operating temperature. A thermostat is relatively inexpensive and usually easy to replace. Just make sure you follow the instructions and put it in facing the right direction. If the thermostat is ok then you may have a blockage in your heater core. Replacing a heater core can be a difficult job on some car. If this is your problem I recommend taking the car into a garage to have the repair done. I hope this helps you out.
Posted on Nov 16, 2009
wracefans24
  • 1985 Answers
SOURCE: heater / air stays cold when moving temp control.
possible blend air door stuck,or heater control assembly faulty
Posted on Dec 06, 2009
Water circulation diagram 2002 Lincoln navagator blows cold air
Check the heater hose's going into the fire wall for being hot ! You don't need to know coolant circulation diagram . If the heater hose's are hot , problem is inside , temperature control actuator ! How to Fix Car with No Heat Easy
Dec 17, 2016 | 2002 Lincoln Navigator
Air conditioner blows cool not cold air
- Keep the knob on RECIR and not FRESH.
- Put the air con ON, blower on max speed.
- Open the hood, inspect the inspection window glass located on the liquid line.
- If foam like bubbles are seen, charge the refrigerant gas, till the glass window is seen clear. Never overcharge the system.
- If the problem persists, check the following:
Refrigerant volume
Refrigerant pressure
Heater control base (for Hatchback)
Heater control base (for Sedan)
Air conditioning pressure sensor
Compressor and pulley
Expansion valve -
Air conditioning amplifier
ECM
CAN communication
The following diagram may help you identify the components.
Feb 18, 2014 | 2000 Toyota ECHO
Freezer fine, refriderator is warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll the board.
Part 49 in this DIAGRAM is your air duct.
Feb 05, 2011 | Whirlpool ER6AHKXPQ Top Freezer...
2007 corolla does not give off heat, blows cold. temp shows correct range, heater core hoses hot to the touch inside and out, radiator hoses hot and fluid is sufficient.Would thermostat be at fault even if...
there should be a temperature door, but I don't know if there is a cable or if its electric. turn the temp knob, if it feels like it moves anything? I dont have a diagram here at home, but will monday/
Dec 06, 2010 | 2007 Toyota Corolla
My airconditioner is not blowing out real cold air..my heater is not blowing out heat just cold air
Reasons for lack of cold a/c is low refrigerant. Does compressor engage and spin when a/c turned on??
Reasons for cold air from heater are
Blocked heater cores
Faulty thermostat
Faulty heater controls
Faulty heater tap.
Mar 30, 2010 | 2003 Pontiac Grand Am
Heater / air stays cold when moving temp control.
Nov 28, 2009 | 1998 Plymouth Voyager
2001 chevy blazer, heater blowing cold air
Pull the stereo back out . they have bumped the vacuum lines that connnect to the heater near the rear of the switch ..
Jan 25, 2009 | 1994 Chevrolet S-10 Blazer
2002 Grand Cherokee heater warm on drivers side cold on passanger
generally this is caused by a "blend door " motor (actually a vacuum control) not working. I don't have a diagram on this but if you watch the motors mounted to the heater box under the dash, and operate the control, you likely will find one not moving (check all positions including a/c)
Jan 22, 2009 | 2002 Jeep Grand Cherokee
Heating & Cooling Logo
170 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
